Super easy. This video will show you how.
Dual Climate Control Repair
enigma-2 replied to finzup's topic in Interior, A.C., Heat, Interior Trim
Try resetting the HVAC controller module. Press the climate control power button and the defrost button (on some systems iys the "auto" button) at the same time, hold a couple of seconds, then press the power button one more time. A code of 88 88 means it's working properly. . -
You REALLY need to change this filter as soon as you can. Although you knocked out as much dirt as you could, it's still full of pollen and bacteria. And with the increased airflow, your now inhaling this. Don't know what Edge you are driving, this is what I use and I get it in 2 days. https://www.amazon.com/dp/B000LPTGAE/ref=cm_sw_r_cp_apa_i_uDYdBbZSJK0SV
Wonder what the reference to "Front; w/ 18 In. front Vented and 17 In. solid Rear" is all about?
Backup Camera replacements that work, Please post
enigma-2 replied to hilokamper's topic in Audio, Backup, Navigation & SYNC
The correct camera Model for your car is model number ET4Z-19G490-A. (There's an earlier model that's also listed for the 2013). About the only one you can be certain of is OEM (abet the price). https://www.tascaparts.com/oem-parts/ford-rear-camera-et4z19g490a/?c=Zz1lbGVjdHJpY2FsJnM9ZWxlY3RyaWNhbC1jb21wb25lbnRzJmk9TVMxMTE5NzUmcj0xJmE9Zm9yZCZvPWVkZ2UmeT0yMDEzJnQ9c2VsJmU9My01bC12Ni1nYXM%3D -
Snort.
This video from Mactfordedge should help show how to R&R the fan asdy. He makes it look.easy by doing it in 9 minutes.
Once every 5 years? You think it's safe to let it go that long? .
Any Windshield Wiper Rec's?
enigma-2 replied to chefduane's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Responded in your other post ("wiper blades") with a video on how to install Reflex blades. -
Bumper and door sill protection
enigma-2 replied to PackPariah's topic in Accessories & Modifications
Probably a Chineese Edge. Because it's 7-passenger they probably mount the spare under. -
Wiper blades
enigma-2 replied to Darren2828's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
See if this helps.- 1 reply
Nice looking car. But I would not put off changing the plugs, if they haven't already been changed. Going through the summer with plugs this old is really asking for trouble. If they haven't been changed, you are probably weakening the coils right now. Call you local dealer and give them you VIN. Ask them to check the history they have on the car and see if they have any records of what kind of maintenance has been done. If your lucky, the previous owner(s) took it the Ford for service.
https://www.amazon.com/dp/B001OJCIMO/ref=cm_sw_r_cp_apa_i_Q3cdBbPDEE4C4 Secure with a wire tie.
Ah rat-a-fratz. Never read the description. You're right about the Pirelli's. The SCORPION VERDE ALL SEASON has a "would buy again" rating of 5.6. That's low. The SCORPION ZERO ALL SEASON PLUS, arn't rated yet but one of two reviewers wrote he was on his wear bars at less than 20k miles. I did find two other ALL-SEASON tires in this size however. First is a Achilles Desert Hawk UHP All-Season Radial Tire - 265/40R21 105V. Never heard of this brand and no reviews to go on. $176.73 with free shipping. https://www.amazon.com/dp/B075XSCL9R/ref=cm_sw_r_cp_apa_i_dPTcBbYT4BBX5 The other one sounds like it has promise. Michelin Latitude Sport 3 All-Season Radial Tire -265/40R21 101Y. $320.70. Free shipping for Amazon Prime members. Too new, not rated yet. https://www.amazon.com/dp/B011OAWCU0/ref=cm_sw_r_cp_apa_i_jRTcBbH0STB6Z Iffen it were me, I'd go with the Michelin's.
Didn't realize they did this. Why wouldn't they go across the board and all cars? Huge step up on Longevity.
We're not going to see you on Live PD, are we? (groan)
Their rated as poor. Why wouldn't you go for the highest rated tires on a CUV so expensive? The Michelin Pilot Sport 4S are numbet one rated and will set you back $1600+ but that's cost of running 21"tires. Tires are too important to run garbage. https://m.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Sport+4S&partnum=64YR1PS4SXL&vehicleSearch=true&fromCompare1=yes&autoMake=Ford&autoYear=2017&autoModel=Edge+FWD&autoModClar=Sport&autoMake=Ford&autoYear=2017&autoModel=Edge+FWD&autoModClar=Sport
If you havent already checked out this site, here's another option for a replacement engines. (Free shipping). https://m.powertraindirect.com/3-5-liter-ecoboost-engines-for-sale/
Uhhhh, so you drive left-handed?
Advance trac, abs, trac control
enigma-2 replied to Jeramie630's topic in Brakes, Chassis & Suspension
The first thing to check is the codes (as Akirby stated). All of these faults are related to the PCM. If the service AdvanceTrac warning indicator light comes on, this could be an indication of several issues. A faulty wheel-speed sensor A faulty steering-angle sensor A faulty rotational-speed sensor An issue with the steering rack Something that is lodged in one of the wheels The AdvanceTrac system needs to be reprogrammed -
Honesty I don't know. Tires are rated Treadwear: 640, Traction: A, Temperature: A. If you look at the ratings on Tirerack.Com, you'll see all the categores are in the green. Very few tires are rated this high (and can maintain it over theit lifetime).
Because of its age/milage, consider changing all fluids, starting with the coolant and transfer case lubricant. Also if they haven't already been changed, changr the plugs. Make this your 1st priority. Plugs should be changed around 90k and as they age, the gap widens, the plugs draw.more current, heating up the coils. When they get too hot, they fail (possibly taking the PCM with them $$$).
Looked up the LED reference. There up to $14 each now. Love the description "shine good. match body. but not made latch size not защелкивает. it have depart small. its попытаюсь pull hair dryer. hope help."
