onyxbfly
    40
Everything posted by onyxbfly
  1. Here you go. Here two decent videos that should get you most of the way if not all of the way, take a look at the PDFs I attached for clarification if needed. HTH https://www.youtube.com/watch?v=y0geWzK18WwFront Bumper Cover.pdf https://www.youtube.com/watch?v=acVcO-11BtQ Front Bumper Cover RI.pdf
  2. Not unless you have glass coverage specifically in your policy. State Farm has 0 deductible, glass insurance, built into their full coverage policies. Unfortunately most do not.
  3. Quick heads up in regards to the FMIC cold pipe upgrade! RamFab is no longer making the cold pipe upgrade. He has passed on the tools and materials necessary to DTP Fab! DTB Fab can be reached via the following: https://dtpfabworks.com/ or https://www.instagram.com/dtp_fabworks/?hl=en If you had a hot side pipe fabricated, I believe that you would be the first to have one. Let us know how it works out for you. I may have a cold side pipe available for sale.
  4. Happy Good Friday Guys and Gals, Quick heads up in regards to the FMIC cold pipe upgrade! RamFab is no longer making the cold pipe upgrade. he has passed on the tools and materials necessary to DTP Fab! DTB Fab can be reached via the following: https://dtpfabworks.com/ or https://www.instagram.com/dtp_fabworks/?hl=en Hope this clears up some confusion!
  5. Happy Good Friday Guys and Gals, Quick heads up in regards to the FMIC cold pipe upgrade! RamFab is no longer making the cold pipe upgrade. he has passed on the tools and materials necessary to DTP Fab! DTB Fab can be reached via the following: https://dtpfabworks.com/ or https://www.instagram.com/dtp_fabworks/?hl=en Hope this clears up some confusion!
  6. I understand the hesitancy in regards to not wanting to spend monies for something that may or may not used more than once. I also understand that we have to work with the budget that we have available to us. Point your browser in this direction.... OBDLink-EX-FORScan Adapter This adapter was exclusively designed by the FORScan team. The main difference between the adapter and the one that 1004Ron mentioned is that this adapter is limited to FORScan use only. Although it is fully compatible and compliant with all OBDII specifications and fully bilateral. You may or may not have to pay for 3rd party apps to diagnose other vehicles. Unfortunately you do not get access to the full diagnostic suite that comes with the OBDLink MX.
  7. That's bizarre! Sorry to hear that you're still dealing with this! Usually removing the negative cable does the trick! Personally, I would get the code reader because, I like to have an idea of what of I'm potentially dealing with when going to any mechanic. There are lots of knowledgeable folks on this forum. Perhaps they can shed some light! @WWWPerfA_ZN0W @1004ron @enigma-2 @jmr061 @omar302 @macbwt
  8. The error code that you have their in your pic speaks to the exact problem that your facing! THE FCIM is the interface with the buttons that do not work for you. Have you tried disconnecting the negative cable for 10-20 min to see if that will reset the modules? Some have even left it disconnected over night! If you search the forums you will see that some people have had success disconnecting the negative cable. Good Luck!
  9. You can reset your BMS with FORScan and the appropriate OBDII adapter. Lots of members including myself use this one here: MX OBDII Bluetooth Scanner
  10. Here you go... Call and ask Dan if his Sport lens are backwards compatible. If not the other tail lights look great as well! HTH https://drivebright.com/product-category/ledtaillights/?filter_model=edge&filter_make=ford&filter_year=2010
  11. Personally I would go with Fords ESP warranty. That's not to say that they're aren't any other skilled mechanics or other good warranties etc. Ford ESP will cover your repair at any Lincoln/ Ford dealership in any city in the country and Canada. Pay for rental coverage as well. Yes the stealership has held my edge hostage. Yes it can take longer than anyone would like to have their repair completed. Things happen. It's not the norm but the exception. As we are all aware there is a national shortage on parts for various manufactures. If the newish looking truck that you previously mentioned was there for service, it could be possibly due to whatever part needed to be replaced etc. When my car was at the dealership and it took them longer than a few weeks to replace the BCM. They needed a "Ford Engineer" to do some programing for it that the dealership techs were not able to complete. I work for the city and I drive from location to location. I can do as little as 0 miles a day or 50 depending on whatever the schedule for the day is. I paid $5/ day to cover regulatory rental fees etc.... I also had a new hybrid fusion.... The money I paid was pale in comparison to the money I saved in gas and the mileage I saved on their dime. I was also to recover the majority of rental fees from Ford Corporate. What other warranty/ company will do that?
  12. I guess I'm the only one surprised that the fuel door doesn't lock when the truck is locked? My coworker said someone drilled a hole in his daughters gas tank....Found the leak when his daughter called him and said the car wouldn't start despite putting gas in it before parking for the night..... He gets to her house with his emergency can.....poured gas in....gas poured out. I said aren't you glad that we have locking gas doors? He has a Nautilus. He said our doors do not lock.... I had to go check for myself..... SMDH Definitely learned something new today. I wouldn't even bother with the locking gas cap. Compare the price of R&R a new or used gas tank.... If a thief can siphon my gas without getting caught, they won the day! Just leave my gas tank alone!
  13. Someone feel free to correct me if i am wrong..... Your MY would use MFT/ SYNC1. Those units tend to die due to a variety of reasons. Don't feel as if you made a bad choice. next gen has similar not the same issues and they eventually die. You could reinstall the previous touch screen and find and or pay someone to program it for you. There are a few people here that can help you. That would require buying an OBD2 adaptor. I use this one.... OBDLink MX= OBD2 Bluestooth scanner You would also need to use FORScan. Or you can do as Enigma suggested and go aftermarket.
  14. Still looking for a used set......
  15. Are you referring to the rear seats? I don't think their is an option available for the edge to make them fold back up.
  16. @TXFRDOwner Can make you the correct harness for you. Point your browser in this direction for more info on the 4"to 8" conversion. http://www.2gfusions.net/showthread.php?tid=4050 HTH
  17. I have the one in the video. While it's not that obnoxious to remove and install, it can be a pain in the @$$ at times!
  18. I think you might be better served by buying an antenna and going to a body shop. They can paint it and install it for you. Should not take more than two hours including prep.
  19. Personally I prefer all season tires unless I'm in an environment that warrants dedicated winter tires. Where are you located?
  20. Here you go..... https://www.ebay.com/itm/353372449080?fits=Year%3A2016|Model%3AEdge|Make%3AFord&_trkparms=ispr%3D1&hash=item5246a3a938:g:FcwAAOSw-kphr67c&amdata=enc%3AAQAGAAAA8ESGYwuytvfDo4TnuR99VwiZdquph33ZabS1KBRDIjBi6tnxmpJcyc5xdeK%2BEpZu6LYEU3s1Wj%2FLn29hrcIyQmJjARjWZ4Y%2BHwVhuFPSZXjthUWmhmmtgZmcd%2FEqX8vHn8n7lShlhVnX5jc0nsAMXrivOdg24UyGFA4Q3Nfl%2BXTsFJac0xaKm6tsmOZFWblcqHC5Esf7OEKOMGX0xFsLlGsVqT1Eu2HLkfftj%2FxkRSfeLz4VhhvvXPhGzzG%2BemAmQY54Z9OXJPB0ySm2SZ4Xx2CGKvY7Qf%2FDAt4W6jcKJgwLnPotb%2FixOUcvtvrAi17Dzg%3D%3D|tkp%3ABFBM2LmMlrtf
