dolsen
Everything posted by dolsen
MPG Tanked!!! Any help Greatly Appreciated...
dolsen replied to Pascale007's topic in 2017-2018 Edge & MKX
Disconnect the battery for 30 minutes and reconnect -
I always though it was pretty amazing how quickly he responded to all of my purchases and even post purchase questions. Even a year after my first purchase he responded to a question I had within a couple of hours
So revisiting this, I recently filled up the edge with E85 and 87 octane because the gas station was out of 93. So to make up for the lower octane fuel, I added a gallon of E85 on top of what my calculations were to fill up the tank (I think it was supposed to be 9 gal E85 and 4 gal 87, so instead I did 10:3). Based on our conversation I assumed my vehicle would pull timing and be slower due to the decreased octane used, so my preconceived notions going into this was that it would "feel" slower. But it turns out the opposite was the case. The car felt faster and felt like it pulled harder. This is likely due to the increased ethanol content. Does the octane of the fuel make a difference in how much timing advance there is in an ethanol tune? sure. But as the concentration of ethanol goes up, the octane of the fuel used to mix becomes more and more negligible. If you're fine tuning a pure drag car, sure the octane is likely very important, but for an ethanol tuned DD, I find it hard to believe that fuel octane matters, at least on an E50 tune. Maybe and E30 the octane of the gasoline is a much bigger deal, but not so much on a powerful, but conservatively tuned E50 DD.
I could be wrong but I think he is referring to the ST-Line (2.0L turbo), not the ST (2.7 TT)
I have never used any of those tuners besides Unleashed, and I have nothing but good things to report as far as performance, drivabililty, and reliability, but that is not to say the other 3 are not worth your time or money. After the reading and research I have done, I would choose ZFG next if I couldn't have unleashed. That's my 2 cents
There are very few tires in 265/40/21, so the choices are slim. I have never run anything other than the OEM Perelli verde, but I feel they leave a lot to be desired. The only other tire I have really considered is the Uniroyal Tiger Paw, because I need all season tires.
Hey man, I understand that. Gotta figure out what your time is worth, and if it's worth spending the money to get more time with the family, then I am 100% on board with that
If you have any mechanical inclination at all, spark plugs are very easy to replace yourself. I am a big guy with big hands and I did struggle a little to get the back side plugs, but with plenty of extensions and swivel sockets, it really wasn't a bad job. I cannot speak for the t-stat
So from a purely chemical perspective, octane is an 8 carbon hydrocarbon and ethanol is a 2 carbon hydrocarbon with an alcohol component attached (an OH in place of an H). With that said, maybe the butchered government definition of octane is different, but octane ratings and ethanol content are not one in the same, but I could see how you can draw an equivalent octane cooling capacity and translate ethanol content to octane (hence the fact that E85 is the equivalent of 113 octane). So, short of redefining octane, I do not agree with your statement, and if I am running an E50 tune, I expect to be able to run a combination of 87 octane fuel (with 10% ethanol content) mixed with E85 (85% ethanol content) to the appropriate mixture to get E50 fuel. However, I still mix 93 and E85, because I am not a chemist and I do not fully understand how it all works. I'm frugal not stupid ?
I have long wondered, does the octane of the gasoline you use, matter when mixing for an ethanol blend? For example, is there a difference in using 87 gas vs 93 gas (assuming both have an ethanol concentration of 10%) when mixing with E85 to create E30/E50 etc?
You also have to consider that there are several vehicles taken off of the assembly line every day that go for a long drive on the road (referred to as the 20 miles drive) or are sometimes driven by Ford management. Ford management is allowed to take cars off the assembly line to drive home and back to the plant the next day (must live within I believe 30 miles of the factory). And in turn they have to write up a report for any defects or issues they find. It's another layer of QC, which I believe is a good thing. Frankly I wouldn't worry about mileage until you get into several hundred miles. You don't know how many test drives these things go on, and I think they can still be sold new so long as there are less than 5000 miles on the odo.
I don't think you can mod anything as much as you can a mustang... except maybe a Jeep lol. I had a 2011 Mustang GT that I recently sold. Bought it brand new, but I drive my edge way more and I enjoy it almost as much.
2015+ Brake Caliper Question "Brembo"
dolsen replied to Breze84's topic in Brakes, Chassis & Suspension
No clue but I'm following along to see if you get answers -
There are several good reviews for several tuners. At the end of the day, it comes down to where you want to spend your money and how much you want to spend. I have an Unleahsed 93 and E50 tune, both of which are incredible. Ask 10 different people with 10 different tuners and you'll get 10 different answer on which is best. I would tune for the highest gasoline octane readily available in your area, and if you're feeling squirrely, you could get and ethanol blend tune.
Is this a troll post? Or am I missing something?
Rear caliper wont retract
dolsen replied to fordedgenashvilletennessee's topic in Brakes, Chassis & Suspension
My 2015 also has screw in calipers. I just replaced the rear brakes on mine about 2 weeks ago. -
Lol I have no idea, I've never heard of that one myself
Is it normal that the 2021 Edge isn't on the Ford website yet? It's Dec 28!
dolsen replied to ben senise's topic in Lounge
I would love to see if that Sync 4 could be swapped into my 2015 Edge... Most likely not but it would be pretty cool. I'm dumb enough to upgrade my 2015 edge sport for the 2021 based on the Sync 4 and 7 speed trans alone. Those gauges are terrible though. Maybe you could actually swap the all digital Nautilus cluster into it. -
Looks like the 2021 Edge is up on the build and price website. -
dolsen replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Well I got a little lazy with my maintenance so I am making up for it now. I replaced the spark plugs around 105k miles (currently at 120k, bought it at 75k) but I have never replaced to PTU or RDU fluid. So I had to PTU and RDU both changed 2 days ago and I purchased a new paper air filter, cabin air filter, rear wipe blade, and brakes for all 4 wheels from Rockauto (still waiting for all of those to arrive). Rears are squeaking and the fronts are vibrating from warping. Also had my oil changed at it's normal interval. I have not flushed the coolant or the trans fluid yet, but I need to look at doing both very soon. -
After reading a little on the website, I am interested in this product for the lubricity properties. I'll have to do a little more research, because while it all seems great, I am also getting all of my info from the guy trying to sell me something. Thanks for sharing
I'm curious about this, can you expand on this please? I think there is pretty solid evidence that DI engines do not have the ability to clean the back side (top side?) of valves, but if there is something else that prevents this build up, even in a non-port/DI combo, then I think it is worth discussing. To be frank, I don't think anyone is going to just "take your word for it" or call Brian. I am not saying you are wrong or that you are a liar, but it's awfully hard to go on blind faith on this topic.
I find it very hard to believe you will be ok with a 40 minute round trip for more than one or two fill ups. I don't think the performance gain would be big enough to justify it.
LIncoln MKX to Ford Edge Instrument Cluster Swap
dolsen replied to onyxbfly's topic in Accessories & Modifications
Deleted, because I think my information is more harmful than helpful- 110 replies
- digital instrument cluster swap
- digital dash swap
- (and 3 more)
Where are you located?
