MrHappy Posted February 13, 2023 Report Share Posted February 13, 2023 Awesome, thank you everyone. I couldn't clearly tell what they were due to the rust but this gives me a good point to go from. Pretty sure they don't sell the nuts by themselves based on when the passenger side was replaced under warranty. (Same issue) The dealer had to order the entire replacement shield kit. (Seemed wasteful then too). Thanks again! Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 13, 2023 Report Share Posted February 13, 2023 1 hour ago, MrHappy said: Pretty sure they don't sell the nuts by themselves based on when the passenger side was replaced under warranty. @1004ron posted a link to buy them from Amazon. Also, I was able to find it on TascaParts (link). 1 1 Quote Link to comment Share on other sites More sharing options...
MrHappy Posted February 13, 2023 Report Share Posted February 13, 2023 I saw the Amazon assorted kit but didn't find you're second link until you posted it, thank you!!! Quote Link to comment Share on other sites More sharing options...
Double George Posted March 25, 2024 Report Share Posted March 25, 2024 I have same issue on my2020 edge, however there are no plastic clips on my covers. There are only the stamped metal nuts along the edges. How can I eliminate the rattling? I thought about pool noodles slid between panels and bottom of car. Would this work? Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 26, 2024 Report Share Posted March 26, 2024 12 hours ago, Double George said: I have same issue on my2020 edge, however there are no plastic clips on my covers. There are only the stamped metal nuts along the edges. How can I eliminate the rattling? I thought about pool noodles slid between panels and bottom of car. Would this work? They're recessed so unless you get right below them you might not see them - also possible that Ford made a change with your Model/Year - maybe @Haz can confirm. Quote Link to comment Share on other sites More sharing options...
Haz Posted March 26, 2024 Report Share Posted March 26, 2024 (edited) The following Underbody Shield images from the 2020 Edge Workshop Manual depict retainer types, quantities, and locations... 2.0L EcoBoost 2.7L EcoBoost PDF versions of these images are attached below... Underbody Shield Image #1 - 2.0 EcoBoost - 2020 Edge Workshop Manual.pdf Underbody Shield Image #2 - 2.0 EcoBoost - 2020 Edge Workshop Manual.pdf Underbody Shield Image #3 - 2.0 EcoBoost - 2020 Edge Workshop Manual.pdf Underbody Shield Image #4 - 2.0 EcoBoost - 2020 Edge Workshop Manual.pdf Underbody Shield Image #1 - 2.7 EcoBoost - 2020 Edge Workshop Manual.pdf Underbody Shield Image #2 - 2.7 EcoBoost - 2020 Edge Workshop Manual.pdf Underbody Shield Image #3 - 2.7 EcoBoost - 2020 Edge Workshop Manual.pdf Good luck! Edited March 26, 2024 by Haz 1 Quote Link to comment Share on other sites More sharing options...
bhamraS97 Posted March 26, 2024 Report Share Posted March 26, 2024 (edited) 15 hours ago, Double George said: I have same issue on my2020 edge, however there are no plastic clips on my covers. There are only the stamped metal nuts along the edges. How can I eliminate the rattling? I thought about pool noodles slid between panels and bottom of car. Would this work? Hey, as from pictures from @Haz, my 2018 Ford Edge has similar layout as 2.7L model. All I did was, removing the loose middle clips on the side panels on both driver and passenger side and keep the good ones. And for the good ones I added double sided tape inbetween clips and frame to act as cushion and that worked for me. Driven 160 once and no rattle at all. Hope this helps Edited March 26, 2024 by bhamraS97 Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 26, 2024 Report Share Posted March 26, 2024 1 hour ago, bhamraS97 said: Hey, as from pictures from @Haz, my 2018 Ford Edge has similar layout as 2.7L model. All I did was, removing the loose middle clips on the side panels on both driver and passenger side and keep the good ones. And for the good ones I added double sided tape inbetween clips and frame to act as cushion and that worked for me. Driven 160 once and no rattle at all. Hope this helps And what 2018 model is that? Please add that to your profile signature - Settings - Ford Edge Forum Quote Link to comment Share on other sites More sharing options...
bhamraS97 Posted March 26, 2024 Report Share Posted March 26, 2024 10 minutes ago, 1004ron said: And what 2018 model is that? Please add that to your profile signature - Settings - Ford Edge Forum Done Added the signature, right now don't have access to laptop so will double check later but it's a 2018 Ford Edge 3.5L V6 Quote Link to comment Share on other sites More sharing options...
Dalton elsea Posted September 25, 2024 Report Share Posted September 25, 2024 Makes a strange noise almost like something is flapping around, looked under car nothing is loose, only makes the noise sometimes and only while driving IMG_5244.mov 1 Quote Link to comment Share on other sites More sharing options...
Przemo Posted March 30, 2025 Report Share Posted March 30, 2025 Hello. Ford Edge 2019 2.0 EB. When driving at a speed of about 120 km/h, rattling and crackling occur. It seems as if from the passenger side in the back. On słów drive, it stops. I am sending a link to the video: https://1drv.ms/v/c/ac2852c806fe5972/EVzwwHLUATtKnvsbyxXNbukBsFZ0RYo5JyxDcZmEmxHsOw Quote Link to comment Share on other sites More sharing options...
STBEAST Posted March 30, 2025 Report Share Posted March 30, 2025 Based on the video it sounds like something is loose on the outside or underside of the vehicle. Most likely speed/wind related. I would start by feeling around the outside and under the vehicle to see if something is loose. Also maybe sit over there and have someone else drive. It might help you pinpoint the location. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 30, 2025 Report Share Posted March 30, 2025 Passenger rear: easy checks — rear mud flaps, air shields under car lost a fasrener or two. Sounds like a piece of tape or paper. I'd also look at the right rear dust shield on the rear brake. Best thing to try is what @STBEAST wrote. Have someone else drive and crawl around the backseat and rear compartment, while finding where should is loudest. There was a guy on YouTube who used wireless, magnetic mount microphones in various locations. Allowed him to quickly work down where the sound was loudest. Quote Link to comment Share on other sites More sharing options...
Przemo Posted April 1, 2025 Report Share Posted April 1, 2025 Thank you for yours help. It turned out that I had the lower cover mounts https://www.sklep.autohobby.pl/product-pol-13355-KOLKI-MOCUJACE-OSLONE-PODWOZIA-EDGE-2015-_-2209369-_-H2GB-19E524-AA.html?gad_source=1&gclid=Cj0KCQjwna6_BhCbARIsALId2Z2mAsocDAiFzBL7hIoydybkckAqeI76La0JTD9s9NudD-TbHbDq1I4aAg1iEALw_wcB 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 1, 2025 Report Share Posted April 1, 2025 @Przemo I replaced those fasteners on my 2017 Sport and after a few months the rattle was back. Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted April 1, 2025 Report Share Posted April 1, 2025 I gave up on the Ford parts, both original and updated. I use TOGGLER TC wall anchors. I cut off enough of the vertical fins, that help grab drywall, to allow the toggle to go through a 3/8 inch fender washer. I hot glued 1" OD x 1/2" tall x 1/2" ID nylon spacers (McMaster #94639A876) to the inside of the covers. I inserted the toggler where the old Ford part was and then used the toggler tool to set the toggle. I did this two years ago and all are sill holding strong. 3 Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 10 Report Share Posted January 10 Quite a few weeks back during a monsoon rain I went through some fairly deep water and the flutter/rattle has been there since. Today I found that two of the plastic posts on the left and one of them on the right had popped out the body. Inserted them again and added thin cable ties between the felt shield and the plastic post. The plastic posts seen in the images @Haz posted look significantly different to the ones on my Edge - is there a later version available? Quote Link to comment Share on other sites More sharing options...
