SYNC 3 V3.4
Not sure of any plans of an official update, but yes if you have the correct files it will upgrade and work oerfectly fine. Our '19 Edge, a well as my '14 Edge and '17 Fusion are all running v3.4 without issue for a few weeks now. (My Fusion was given an upgraded gen4 APIM and my '14 Edge's SYNC3 gen3 APIM was formatted to take v3.2+)
1 hour ago, redden18 said:
Just downloaded new one for MY18, it is still SYNC 3.0, v3.0.21 build 19205 (currently I have 3.0.14 build 18093)
How to you find the full version number, mine only shows v3.0, and the Ford owners web site says that the v3.0 update is available.
Edited by 1004ron
file Autoinstall.lst contains that info:
; SYNC3 Consumer Assembly Upgrade - Release 3.0.21 - Only for Nav/NA assemblies.
[SYNCGen3.0_3.0.19205_PRODUCT]
Item1 = HB5T-14G386-THA
Open1 = SyncMyRide\HB5T-14G386-THA.tar.gz
Item2 = HB5T-14G386-TCB
Open2 = SyncMyRide\HB5T-14G386-TCB.tar.gz
Item3 = JR3T-14G391-CE
Open3 = SyncMyRide\JR3T-14G391-CE.tar.gz
Item4 = JR3T-14G381-AS
Open4 = SyncMyRide\JR3T-14G381-AS.tar.gz
Item5 = JR3T-14G423-CB
Open5 = SyncMyRide\JR3T-14G423-CB.tar.gz
Item6 = HB5T-14G387-AAB
Open6 = SyncMyRide\HB5T-14G387-AAB.tar.gz
Item7 = GB5T-14G386-AB
Open7 = SyncMyRide\GB5T-14G386-AB.tar.gz
Options = AutoInstall,Delay
  • 3 months later...
9 hours ago, redden18 said:
Here is everithing you need to upgrade from 3.0 to 3.4 as well as get new maps 1.18.
If you have 3.2 and higher the only thing is needed is step 3
https://www.f150forum.com/f118/upgrade-sync-3-v3-0-v3-4-instructions-458828/
Why would you risk installing a bootleg copy of the software and bricking your system?  I didn't see any new features, just a map update and a different look.
First of all, I'm not forcing anyone to install it.
Second, it is not a bootleg copy, but fully legitimate copy of software which Ford is installing on MY19+ vehicles. The way we installing it is not completely legitimate though, but as I said nobody is forced.
Nice bonus of that is having latest maps available for SYNC 3 system for vehicles older than MY18 as Ford did not offered free maps udate for those vehicles which is a bummer!
Do you mind sharing how you updated your '14? I just did the Sync2 to 3 upgrade myself for my '14 and would like to do this as well.
Thanks!
Edit: NVM, think I figured it out.
Edited by HUTCHRED
It's a bootleg copy in that it isn't supplied by Ford or recommended for this specific vehicle, not that the software itself is pirated.     The point is if you brick the system you're on your own - that's a big risk for what seems like very little gain.
