Moderator-
2013 SEL non sony non nav head unit output?
akirby replied to Randy Johnson's topic in Audio, Backup, Navigation & SYNC
These wouldn't be a bad choice at $150 for 4: http://www.crutchfield.com/p_107DXI571/Polk-Audio-DXi571.html?tp=93 If you want to go even cheaper: http://www.crutchfield.com/p_130TG6845R/Pioneer-TS-G6845R.html?tp=93 -
A cutout would be nice if it worked. Was there also a cutout for the oil filter?
The shield on my Fusion, Focus and Escape are solid and have to be removed to change the oil period. I don't think they used the wrong shield.
It would be against the law if you were forced to pay for the service, but since it was free warranty work it was not illegal. And mfrs can force you to use their parts but only if they're provided free of charge.
I bought one last year and a C-tek charger/conditioner. Now if I can just remember to use them.....
- 9 replies
- Battery
- Charging System
Could be the evaporative purge valve.
Absolutely, and I would find another dealer if they give you those kinds of BS answers.
The Edge will be fine as long as you have all season tires and not summer tires. Whether it's safe for you to drive depends on whether you've driven in snow and ice before.
A little sarcasm is no excuse for a profanity laced personal attack and I've already discussed that privately. So let's all just let it go and move on.
It's all done with a flasher now such as a SCT. You can get tunes from various sources. The 93 octane tunes will advance the timing as much as possible. That's about the only reliable way of getting more power and even then I think it's only going to be 20-25 hp or so. Lots of post about tuners and tunes - use the search bar in the upper right.
@FordService
- 24 replies
No - try twitter.
- 24 replies
Ford's factory exhaust is pretty good these days. I wouldn't expect more than a few hp gain from a full cat-back and probably less from just a muffler. You can change the sound though. If you want a power boost the best bet is a 93 octane tune.
The dealer has to advocate on your behalf with Ford and they usually have to agree to assist.
- 24 replies
My point exactly. If you have 100 problems out of 1 million vehicles, that's a very tiny percentage. The odds would be 1 in 10,000 that you would have the same problem. Those are pretty small odds.
It is possible to have a manufacturing defect that puts too much stress on it but it's fairly rare. You can find sunroofs and rear hatch failures on every mfr and model at some point. Even a few failures could be normal.
I don't think Ford's glass problems are any worse than other mfrs. Glass breaks.
Sport mode in Canadian 13/14 SEL AWD
akirby replied to normcloutier's topic in All Wheel Drive (AWD)
I was just saying that it's not really designed to lock in SS mode like that - it's a glitch somewhere. If it happens again just try disconnecting the battery for a few minutes. -
That doesn't sound right. Adaptive strategy is what the tranny uses to compensate for physical changes over the life of the tranny - it just adjusts shift pressures to keep shifts within factory spec. It doesn't really adapt to how you drive although that seems to be a common misperception among salespeople and service mgrs. My guess is they just reset a module with IDS or just disconnected the battery and it started working. -
The first rule in computer troubleshooting is don't assume the part you just replaced is working properly. Test it first.
It's a common problem.
Up until 2000 or so you did have to take your Ford back to the selling dealer for warranty work unless you were more than 50 miles away. Thank goodness they stopped that nonsense.
