Everything posted by CARR142
I hope this helps. 1. Loosen all the mounting hardware. 2. Use some shims on the inside front of the bumper between frame and bumper. You want to push the bottom space out, which will push the top space in towards the fender. Where you place the shims is optional. 3 Then tighten all the mounting hardware. Tedious but rewarding results. Best Wishes! What you use for shims is up to you. I used so hard rubber trimmed to size.
Sorry Folks, I meant to say, That I always mark tires before having them rotated. My bad.
Does it look like this?
Bluetooth not connecting
CARR142 replied to Starting to hate this car's topic in Audio, Backup, Navigation & SYNC
4 APIM and the right Tech and all's well with me. This was with 2011 MKx back in the early days of Sync 2. -
Dealers or independents, "I" always mark tires and check if rotated. (DAMHIK), don't ask me how I know.
https://duckduckgo.com/?q=stud+remover+set&t=newext&atb=v277-1&ia=web
Ambient Lighting half working
CARR142 replied to Mkeefer01690's topic in Interior, A.C., Heat, Interior Trim
Try: https://www.youtube.com/c/MACTFordEdge
Anyone Know how to enter "Test" or "Engineering mode" ?
CARR142 replied to orangecrush70's topic in 2017-2018 Edge & MKX
Right "Ok" button- 3 replies
- engineering
- mode
Edge turns over several times, doesn’t start,,,
CARR142 replied to kapk22's topic in Accessories & Modifications
You could try: "The Vehicle Does Not Start With The Passive Key In Certain Areas Within The Vehicle But Starts Using The Passive Key Backup Location" -
Vehicle won't turn over just a click
CARR142 replied to Bryan_Mccormick81's topic in 2010 Edge & MKX
Consider this issue. -
ENGINE COOLANT OVER TEMP — Displayed when the engine coolant temperature is excessively high. Page 26
+1
"And Away We Go" Best Wishes To you.
I been there before, I would have like to see the expression on my face. Got new wheels, tires, locking lug nuts, plus towing for $250.00 Deductible. Insurance paid Dealer $5134.00. Tires had 26000 miles at time. Two Rims had curb rash.
He doesn't say anything about programing it after the install. You could ask in the comment section. Best Wishes!
Try opening the link in new private window using Firefox. or New incognito window using Chrome. or New Inprivate window using Edge, (Windows) Best Wishes!
Consider This: And this: Ford Drive Cycle Information For all other Ford Vehicles Pre-Conditioning Requirements: · Cold soak the vehicle for 8 hours · No DTCs present · Fuel fill between 15% & 85 % Driving Procedure 1) Start the vehicle and idle for four (4) minutes. 2) Idle the vehicle in drive for 40 seconds (neutral for M/T). 3) Accelerate to 45 mph, using ¼ to ½ throttle (M/T stay in second gear for at least 5 seconds). Accelerate for at least 10 seconds and shift through to 5th gear. 4) Drive with a steady throttle at 45 mph for 30 seconds. 5) Stop the vehicle and idle in drive or neutral for 40 seconds. 6) Drive at speeds between 25 and 45 mph for 15 minutes. Use ¼ to ½ throttle accelerations. Include the following conditions: · At least 5 stops with ten seconds of idle time. · At least 3 steady speed sections of 1 ½ minutes duration. 7) Drive the vehicle between 45 and 60 mph for 8 minutes (use high gear). ? Maintain a steady speed between 45 and 60 mph for 5 minutes. 9) Drive the vehicle between 45 and 60 mph for 8 minutes (use high gear). 10) Stop vehicle, idle for 40 seconds.
AJRoo, Did you disconnect the battery before/during this repair?
Blufish312, Welcome, The painted section is a separate part of the mirror. Take care when trying to separate from lower section or you will break the clips. The lower black section isn't available as a separate part. You could buy a mirror, new or used an switch out the top section to avoid painting.
FYI, My 11 MKx won't remote start with the hood open. Holding down the hood switch it will start.
Disappoinment - PTU drain and fill - capacity
CARR142 replied to flymore's topic in All Wheel Drive (AWD)
a ramp = 1? I would think that the vehicle should be level. -
Another Edge with soft pedal after replacing booster
CARR142 replied to fit1446's topic in Brakes, Chassis & Suspension
Doing it with Forscan is easy, Forscan Lite with your phone, Follow the instructions. I've done on two of My vehicles, from the drivers seat. Best Wishes! -
CARR142 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Yes Sir!
