Yay! Congratulations!
Add remote start 2015 Edge
WWWPerfA_ZN0W replied to ljdean200's topic in Alarms, Keyless Entry, Locks & Remote Start
Take a look at candurin's thread here, since you have a 2011-14 Edge http://www.fordedgeforum.com/topic/17035-adding-oem-remote-start-kits-parts-explained-detailed-2011/ -
Dead camera on my 2011
WWWPerfA_ZN0W replied to Shifteroth's topic in Audio, Backup, Navigation & SYNC
Hoping to hear from people who have experimented with "sibling" parts for the Edge, but have not seen anyone try it yet. -
Welcome Welcome to the community, congrats on your newest acquisition, both are lookers 4 sure! The Titanium package is ... packed Ceramic interior should look pretty good, don't know I have seen any red/ceramic combos yet. AWD/FWD?
Rear Brake Rotor Replacements
WWWPerfA_ZN0W replied to jmr061's topic in 2015+ Edge & MKX Generation II
sct tunner is it worth it, dose it make the car a lil quicker
WWWPerfA_ZN0W replied to jmoney23's topic in 3.5L
Ask Torrie. -
mac has been able to gather a lot of data on how the Edge behaves & responds thanks to all the miles he puts on and willingness to experiment ... to an extent. Still won't tune LOL.
Welcome & congrats on finding such a low mileage unit! First Ford, or ...?
macbwt = FWD only. No AWD, and it seems to work out fine! -
HVAC System Question - Vents Stuck ?
WWWPerfA_ZN0W replied to ash042679's topic in Interior, A.C., Heat, Interior Trim
Does your OBD tool scan the MSCAN bus? All of them scan the HSCAN bus AFAIK. The climate control is on the MSCAN bus from what I remember. -
x2! Glad to see the catchcan installed, especially on the 2.0. Prev gen 2.0, should also, but probably too late now LOL.
First, check for codes, as outlined in the attached document. That may provide direction. Pinpoint Test J is I believe what you will be working with. Also verify that the coolant, with engine off & "cold", is at the COLD FULL mark or slightly above. Verify the A/C refrigerant pressures also, the system may be low or have a leak. All kinds of weird behavior can happen when either of these two items are in question. 2008 Edge HVAC Module Ć¢ā¬ā Dual Automatic Temperature Control _DATC_ Ć¢ā¬ā Diagnostic Methods.pdf -
It was a joke, LOL!
- 15 replies
- wheel spacers
- spacers
(and 2 more)
No commonly noted issues that would explain that. Possibly wiring/fuseboxes affected by heavy rain or high pressure carwash? Check PCM for codes tho doubtful it set any. Also make sure fuses & relays are snug in the underhood fusebox as well as the passenger compartment fuse panel.
Routine maintenance *cough hack wheeze* will keep that water pump going. 105K is NOT the only interval Ford specifies for the first coolant change.
There's always these if you want that stick out to not stick out http://www.jcwhitney.com/bushwacker-pocket-style-fender-flares/p2008746.jcwx
- 15 replies
- wheel spacers
- spacers
(and 2 more)
Why not? So we can use our head to focus on other things. -
Does it have the 3.5 or the 2.0Ecoboost engine? I hold nothing against the 2.0, but the 3.5 is a proven performer, requires pretty much routine maintenance to run well & for long. What is the warranty situation on this Edge? You can get extended protection direct from Ford, if that is what you prefer.
Powertrain control at its' finest!
- 668 replies
- 2011 Ford Edge
- Limiited
(and 4 more)
Welcome in, Doug, I do hope you end up buying the Edge Off topic, but are you a Penn State-r by any chance? J/C due to the username.
Sounds like your Edge is tiptop!
Hopefully it does what it says! What do you set it at for synthetic blends? Caveat: Some specialty or extended use oils with high levels of additives, or with metals such as zinc or moly, may give falsely negative results. Examples include Amsoil Signature series, Redline, and non API Royal Purple oils. Always read the reviews for tips to get the most out of the product BEFORE you buy
