garycrist
Everything posted by garycrist
WTG!!!
We used universals to jack the rear up if it was sagging. As long as the spring seats into the isolator, no grinding necessary. Then grind to fit once more, the isolator if necessary to fit the vehicle's perch. Take a picture of the spring "pig-tail's location relative to the upper spring perch (on the car) on both springs too. Sometimes getting them off may cause a little lean.
Garage Door Opener - Homelink
garycrist replied to OnlySkillz's topic in Audio, Backup, Navigation & SYNC
Yes one may program the "Homelink" to the opener w/o the remote. Put the garage door into learning mode then do the learning mode for the "Homelink". -
It appears Ford has fallen back into the '80s again. Designed obsolescence so that it might make it to the end of the "Payment Book" (I bet the younger group does not know about Payment Books with "coupons"). This is the reason people started buying Japanese!
I have run straight 50 weight and plug anti foulers on an old Thunderbird...Little smoke too.
2022 Edge panic stops and turns hard left.
garycrist replied to Renegadebuck's topic in Owner Impressions
I had to turn as much off as I could. I got tired of fighting for control of the vehicle. Like the OP stated all of a sudden my 22 ST would do some of the same things. He might have driven into a flock of bugs.😉 -
I have turned off all of the STUPID DRIVER assists. They are not ready for prime time. -
I would check the anti-rattle clips on the brake pads.
K&N Cold Air Intake - 2011 Ford Edge SEL 3.5L
garycrist replied to ColinM31's topic in Accessories & Modifications
11.5s😉 -
Tire Rack is Discount Tire! Discount is big enough that it can specify the compounds in the thread section of the tire regardless of the manufacturer. An example was the Yokohama tire line with 3 different selections for the same size tire. I could easily tell one to expect with normal driving 40K+ miles. The next was a street performance tire one could achieve plenty of miles but had hardened over time and have next to no traction (20K-35K)! The last was for racing/street(ha ha), with the better driver getting the fewest miles(5K-12K)! Those were the king in SCCA racing too or, if you were not running them you were not winning. When the auto manufactures buy tires they specify the compounds for the tires they buy. An example was the GM TPC radial specification for tires. They skimped on the width of the steel belts and with the springs sagging as they broke in and the camber going way too positive, it caused excessive outside premature shoulder wear. But then again, people were trading in about every 18 months so, for about 15K-30K for tires.
Some of the things about Discount, they sell warranties as well as tires. (DUUHH) Did you know they have tires made just for them by the same manufacturers who's name one depends. Or in other words, they sell one a tire that will never last long but, you have a warranty and they have a ready made sucker for a customer!
Panoramic Sunroof Cracked
garycrist replied to Sierra's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Water! Just plain WATER! Most people have never watched a glass cutter so they never knew a simple trick. Before they score the glass, they lick their finger, then drag it behind the cutter. That weakens the glass by IIRC 3 orders of magnitude! So, a rock nick, some rain , a big bump, a twist (sounds like I am going to hurt my back again) of the body and out magic a crack zips across the glass. This is one of the reasons to repair "bulls eyes" or stars on windscreens. Just like evacuation of an A/C system, one needs to remove the water before releasing the adhesives. -
Interested in buying a 2015+ ford edge
garycrist replied to bivacci's topic in Buying, Leasing & Ordering
The 3.5L motor Ford put into the Edge is the same engine they used in the 24 hours of Le Mans with different pistons putting out 650 HP! -
Automobiles are a "Crap Shoot". You may even use loaded dice and slide them too, but in the end they can bite you with some out of the blue problem. Something like a rod bolt breaking or a piston skirt crack, real out of the blue unforeseen failures. Buy it, enjoy it and don't worry about it. (215,000 miles on our 08 with only minor maintenance and OE belts ). -
Sitting in Idle and stalls out and oil pressure light comes on
garycrist replied to twmarsh's topic in 2011 Edge & MKX
I'll guess bad battery for $500. (HINT HINT) When I lived in California and worked on all makes, sometimes it was tough to take me seriously when I told some of my clients their carburetors ran out of oil! -
@Waldoyou want to know "How is an engine not running harder on it than running?","Cold starts are hard on an engine, but the auto stop start won't let it turn off when it's still cold." Did you ever think about that little turbo still spinning it's little heart out while the engine is off? How about the heat-soak of the oil in the Turbo that is still spinning (no oil pressure any longer) coking -up. One will NEVER recover $$$ from gasoline savings from "Auto Stop Start" vs the shortened lifetime of the 2 turbochargers!
Have someone do an Ozone treatment.
Every car I've put shocks on, always felt better and drove nicer.Steins are a preimium high pressure gas shock like some of the KYB Gas Adjust or Konis. So the only performance shock for us are Bilsteins. You will love them too. The high pressure gas mono tube shocks, smooth out over springed vehicles.
Pump replacement problem
garycrist replied to FordGuy309's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thank You @FordGuy309 for helping the next person that as a washer problem. Once more buying junk parts from Amazon is a BIG CRAP SHOOT that might work errr most of the times... -
If you have rear washer and no front, then the front squirters are probably plugged up and it"s time to get a new pair. -
I have one of those too.(08) They had a funky shift learning curve. Changing from 1 driver as primary, to another driver will cause it fits. Have you tried a battery disconnect on it yet?
