garycrist
Everything posted by garycrist
This is a whole lot easier than changing fluid on a C4. Then bumping the engine over to find the drain plug and draining the Torque Converter. Not to mention somewhere between 10 to 13 Quarts. Did I forget the refill procedure? To lazy to type it out! These things are easy to DIY just HOT!
Also Valvoline Protect and Restore the oil.
https://tiresvote.com/articles/tires-have-same-size-yet-fact-they-are-different-how-possible/ https://agtiretalk.com/why-do-tire-specs-vary-by-manufacturer/ And last but not least. https://kevinsautos.com/faq/how-much-difference-in-tire-size-is-acceptable-on-awd.html
Tread depth is not the way to measure tire diameter! A tire's diameter CAN NOT be determined by the it's size on the sidewall! Even the same size tire of a different design made by the same manufacturer may not have the same diameter too! Measuring from top to bottom will not give diameter measurements that are valid. If you want to know the diameter of a tire in question, go to the MFG.s site and find the revs per mile for your tires and compare. As for asymmetrical on one side vs the other in the front, under normal conditions, you will never be able to tell the difference! Not only was I a tire store manager but, I owned and operated 22 tire and brake stores and was the largest distributor of Yokohama tires. I even owned the next 6 months of production at 1 time. But that is another story for another time.
I did this for my wife. She loves it too.
2017 Ford Edge Sport 2.7 shuts off while driving
garycrist replied to jlbarrett's topic in 2.7L EcoBoost
Thanks for the video! After watching the tech compare the fuel pump spring difference, I now understand the extra noise (sounds like a clicking lifter) a failing fuel pump would display. -
Back when I worked in a SAAB dealership, some of the cars were plagued with some strange happenings. One involved a certain area in Boston MA. The others, random happening all over the US. The common denominator was they all started after being towed back to the dealerships. No problem found!! The problems were found to be not enough RF shielding. The Boston problem was found to be the antennas for the radio and TV stations were located where the car conked out. The others were found to be at "radio controlled" intersections. If the car was stopped there, it was towed from there. But, if the light was green, the car only sputtered it's way through the intersection. These were the early days of Bosch EFI. So with all of the "computers" in all of the vehicles, "No problem found" will continue, So, it's best to turn it off and restart and smile because you know more than a whole bunch of Technicians. Because it's poor or not enough RF shielding and YOU got glitched! DE KI6FG
Compass module location and questions
garycrist replied to ChucklesMcHaHa's topic in Audio, Backup, Navigation & SYNC
Right! That's why I said replace the mirror. The fun hold your breath is getting the old one off. Some blow-up the wind-screen I had no problem but, I can't remember the special tool I used... GL Gary -
Compass does not work
garycrist replied to edgemaster's topic in Interior, A.C., Heat, Interior Trim
Replace the mirror. I had to do mine too. 2008 Limited -
Looks like good stuff with PEA. Also look for Top Tier fuel or Shell and Chevron to name a few They all have PEA too. A 20 oz bottle of Chevron Techron with a fill-up will also slow down the crud. As for oil check out Valvoline Protect and restore. I would like to know if it will melt one's plastic manifold too.
Monroe or any current model New Strut Bad out the box
garycrist replied to EdgeAWD's topic in 2009 Edge & MKX
If you like KYB, you will love Bilstein. Now if they had Koni for my ST....... FYI the High pressure gas shock helps tame the spring. It fools your butt into thinking you have a softer ride from "sport springs". The downside is, it is easy to die on a wash-board dirt road due to loss of control! It was a local trip for me to the KYB when I lived in Cali. I had all kinds of KYB stuff. -
2020 Edge Titanium Battery Recommendation...
garycrist replied to DNBush's topic in 2019-Current Edge & Nautilius
I have had mine (2022 ST) replaced already (AGM) in less than 1 year. From reading all over, it appears that there were a bunch of bad ones for that model. My date of production was 11/22 and replacement 8/23! -
2008 Edge AWD - loud noise - wheel bearing?
garycrist replied to ADC's topic in Brakes, Chassis & Suspension
I assumed the OP does not have a lift so I was offering a simple DIY for a quick help. As you know, most people can't tell where most sounds originate (F/R L/R). On most client's claims of sound origins, I would Inspect the exact opposite corner first. In a higher percentage of times, they were wrong thus cutting my time and the $$$ they spent with me! (WIN WIN) With these cavernous insides of these Edges, put the seats down and boy do they get LOUD! For years, I did Rattles,Squeaks and Bitches with "Grandma's Grocery List" a mile long! I have ridden all over a car in search of a client's satisfaction of a noise elimination. From riding in the back seat ( aahhh heating and A/C in the right season), multiple trunk rides for several miles inside and outside, clinging for life in the hood was the most scary! But, I never tried holding on with a stethoscope!𤣠-
I'll have to disagree! This is why one keeps "Old Farts" around! Sometimes during transport on the trains along time ago, we learned wheel bearings can be pounded down and create a divot on the race where the roller pounded on it and 1 roller not round! You can't feel it but, you sure can hear it! -
Have you done a factory rest yet ? Soft is Power and seek up buttons simultaneously for 5 seconds (>>I seek up button) Or, do a master reset from general settings of the radio menu.
How are the engine mounts? "there is a loud clunk when going from drive or park to reverse unless you completely come to a stop" From your video, you varied both speed and RPM simultaneously. It is tough to tell the culprit. Have ALL 4 wheel bearing been replaced? I suspect a bearing too but as you state which one! A remote mic coupled to your cellphone, secured close to each bearing would allow you to pin point the right spot for less than $50. GL -
Sure sounds like good old fashion vapor lock. I also wonder if the fuel strainer, if it had one, was plugged up or restricted. With low flow, a vapor lock condition, it would take some time to purge the fuel system of vapor to start injecting liquid fuel.
- 34 replies
- hard start
- ford edge
(and 2 more)
Edge sways all over the road above 70 mph.
garycrist replied to ibChuck's topic in Brakes, Chassis & Suspension
Time for a bunch of you to look-up "TRAMLINING". Selling tires way back when, taught us all about that problem with the grooved freeways in S. Cali. Especially with the wrong sidewall configuration. -
This exemplifies the "Waddington Effect". I bet you have to look this one up.......š
Moral of the story often repeated, Never open the pano roof and never encounter a problem.
I remember some Mfg.s had an indicator to let one know when to service the filter.
Wanting to spend a few hundred dollars wisely? Drive through the poor section of your town and drop 30 $10 dollar bills out the window or, pick an Angel off the Christmas Tree @ the mall. Watch the video before you spend your hard earned $$$$!
It is bad rubber molding The crap just falls apart due to UV and heat. I know as I have an 08 Limited. At 1st it was an air leak I fixed with a length of vacuum line to hold the window in and stop the air leak. (Driver's side)
