lildisco
Everything posted by lildisco
2.0 ecoboost..how is working in the new Edge?
lildisco replied to garrett62's topic in 2.0L EcoBoost
Got better mpg's on the way up from southern Ohio, but there was a lot less wind & weather. Car said i averaged 26.8mpg,but calculated was 25.7mpg. Remember that here in Ohio, we're still on winter mix fuel. We also were in some stop & go traffic at times as well. I'll probably drain the catch can this weekend & see what it caught through 2 tanks, roughly 700 miles. -
So far, no real change in fuel economy. Car says I'm at 25.6mpg. It's a 300 mile round trip, so we'll see what we get when we get back to town. BUT, i would like to add that it was very windy on our way down. We battled a snow storm when we were leaving home, got an hour away from home & delt with rain & about another hour later, dense fog. Ambient air temps were hovering around freezing most of the trip till the last hour,then was around 35. I will say at this point, mpg's seem to be not effected. Maybe i caught the coking in time to prevent any more problems from happening? Only time will tell. -
Will do. Keep in mind that premium fuel doesn't necessarily mean that it's a Top Tier fuel. Read up on it here: http://www.toptiergas.com I would recommend changing your oil ASAP & switch to a full synthetic. I believe that the factory oil is synthetic blend. Plus you get a lot of the 'break in' stuff out & fresh clean oil in. As for the Catch Can, all depends on the dealer. Some are more understanding than others. Most will understand its purpose, others just want to make a buck. You could always ask your preferred dealer & get their thoughts. They may want to install the product & should take around an hour and a half to 2 hours to install. Worth every penny in my book -
WeatherTech splash guards vs Ford OEM splash guards
lildisco replied to scaredycat's topic in Accessories & Modifications
I don't know why there wouldn't have been an OEM option. My 2016 has them & i don't think they redesigned them in 2017 -
All depends on that right foot, what grade/quality fuel you're using (Top Tier Preferred), winter mix fuel, tire pressures, driving style etc. Most people forget that this is a turbo engine & is around full boost around 2,300 RPM (Don't have the exact figures in front of me) & need to 're-learn' how to drive in order to get the best MPG's out of the 2.0 Ecoboost. Accelerating to stop lights/signs is a very good way to burn fuel in these things. Just keep an eye on the fuel economy mode on the left side of the Speedometer & you'll see what i mean when you accelerate to stop. If you gradually get up to speed & coast to a stop sign, you're MPG's go way up. Anticipating stop lights or 'knowing' the cycle is also a good way to increase MPG's as you're not wasting fuel idling when you're getting 0 MPG's. I've also seen a 2-4 MPG difference between a Top Tier station & a non Top Tier Station. Gas just isn't gas any more. Different Gas Stations have different additives in the fuel & some are worse than others. Speedway Gas Stations are the worse & I avoid them at all costs unless it's an emergency to get me a few miles up the road. When my wife drives the car, she can't get much above 25-26mpg in the summer on the highway. When I drive, we get closer to 28-29. In the winter, she can barely get 23-24, but i get 25-27. We're taking a road trip over the weekend & it'll be the first road trip with my Oil Catch Can installed, so maybe we'll see an improvement there as well. -
Here's a link to the Catch Can install that I did on my 2.0 Ecoboost, Post #21 is the actual install pictures. http://www.fordedgeforum.com/topic/22063-oil-catch-can-on-the-20l-ecoboost/page-1 Here's what it caught after around 400 miles with the Catch Can installed:
lildisco replied to jmr061's topic in Audio, Backup, Navigation & SYNC
lildisco replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Not too far away, I'm in Oberlin & go out to Strongsville every so often. Nice to see some 'enthusiasts' around -
It was 70 like 2 Fridays ago, lol. I'm out on the west side in Lorain County, where bouts are you located? -
I installed the OEM front & rear splash guards. Total time was under 30 minutes. Only 2 holes need to be drilled on the fronts, per the instructions. The rest are really easy reusable push pins Has really made a difference with dirt and debris getting into the bottom of the front doors. -
Doesn't appear to be a charcoal filter. I don't have the filter any more & i'm too lazy to look at the filter in the car, but I want to say that the part #'s were the same between the two filters. Maybe in the next few days I'll pop open the glove box & compare it with the above picture. The owners manual on my 2016 does call for a FP-71
Factory Part # is FP-71 http://www.fordedgeforum.com/topic/22115-check-that-cabin-air-filter/?do=findComment&comment=166419
& here i thought that paying $365 for a catch can was high. Just at a glance, it looks like a decent kit, but 20-30 install time seems a little far fetched.
Just a few miles over 400 since catch can was installed & decided to drain the can to see what was caught. I will admit that I spilled a little bit getting out from underneath the car, but still a decent amount for the mileage. We don't really beat on it & we mainly drive city/country roads with very little highway. Also have used full synthetic oil since around 2,000 miles.
Here's what my Catch Can has caught in 400+ miles on my 2.0 Ecoboost. Well worth the investment to not have this being regurgitated back into the engine. We usually don't beat on the car & usually city/country roads with very little highway & full synthetic oil since around 2,000 miles. Currently around 12,500 miles.
It's called coking & seems to be a problem with most ecoboost's due to direct injection. As stated above, it's a common issue with direct injection period as gasoline doesn't clean the valves anymore when fuel is injected directly into combustion chamber & not through the intake manifold. Check out my post about adding a catch can to a 2.0 Ecoboost: http://www.fordedgeforum.com/topic/22063-oil-catch-can-on-the-20l-ecoboost/ You also might want to look at this to get a better understanding of ecoboost's & blowby: http://teamrxp.com/p/instructions I checked my catch can with about 70 or so miles with the catch can on & it gave me 3 or 4 drops of yellowish oil like liquid. I now have close to 500 miles with the catch can & very curious to see how much crap is in there now. A catch can on ANY forced induction vehicle is a must in my opinion.
Mud Flap Splash Guard - OEM or 3rd Party ?
lildisco replied to 1004ron's topic in Accessories & Modifications
I do know that the rears are different on a non-sport. I picked up my rear set from a member with a sport who said that they didn't fit. I believe that the fronts 'might be' the same. They look decent & have noticed a lot less debris on the front doors since i installed the OEM splash gaurds -
Keeping wax residue off textured panels...
lildisco replied to unca waldo's topic in Appearance - Detailing, Wash & Wax
If you ever get wax on the plastic parts, easiest thing to do is use an old school rubber eraser to get the wax off. My father in law decided to wax my mother in law's cx9 a few years ago because he was bored & ended up waxing EVERY THING. Took me some time, but eventually i was able to remove all the wax residue off all the textured body panels. -
Definitely would check it. It may also help to note that neither of us smoke, but the wife doesn't like having the windows down while going over 55 due to the wind noise, so we do use the blower function a lot. Chef, never used a reusable cabin air filter. How do you tell if it's dirty or not or when it's time to clean?
It didn't line up with with anything. But i believe that the new filter had the same markings. Neither had FP-71 mentioned anywhere.
It hasn't been officially a year since we purchased our '16 Fwd 2.0 Ecoboost & i was curious about how dirty the cabin air filter was. Mind you, the car is in a garage most of its life & has a little over 12,200 miles. This thing was FILTHY. I mean nearly black. I don't know if it's a good thing, or a bad thing, since it kept all of that from entering further into the cabin. I believe it's supposed to be changed once a year according to the manual, but i may do twice a year by the looks of it. The filter is a Motorcraft FP-71.I purchased mine from Amazon for $14.44 +tax. Well worth the investment!
2013 SEL Smartphone Remote
lildisco replied to Dave33's topic in Alarms, Keyless Entry, Locks & Remote Start
That's not a Ford Corporate issue, it's an Apple Ford issue
