boostededge
Everything posted by boostededge
There is simply no aftermarket support for these vehicles. You can't even find an intake kit for it. AFE was going to make a cold air intake but they rather make diff covers for Raptors. About the only thing to do is a tune.
Is it just the 1 TSB to rule them all as far as the shifting or is there multiple they need to apply? Mine does the thump from Park to Drive or Neutral to Drive but also basically sucks at all shifting. If I tell them to apply the 19-2313 is that all I need?
The new flash is released?
My new Edge ST vibrates at idle, coming from dash area, usually only when cold. Could it be related to any of this?
Have them do a leak down test. Does your coolant level go up a lot after you've been boosting hard? White smoke no bueno.
I didnt want my Edge to sound like garbage rattle box like every other vehicle I've seen with stop/start feature after some mileage on it, so disabled it with Forscan. The Edge ST to me is OK but could be a lot better. Transverse layout makes it difficult to work on. Plastic oil pan. If you get too Hoonigan and find a curb with your oil pan its destroyed. Plastic everything, intercooler pipes, intake manifold, this thing should cost $38 as its mostly made of plastic Small two piston brakes up front, single pistons in rear. For the price, weight, performance it should have two piston rear, 4 piston in front. No paddle shifting other than on steering wheel Needs another 50 ft/lb torque everywhere Needs some updates to the tranny shifting points Other than that its very quiet and luxurious so I can see why a normal Edge owner wouldn't care about anything I listed above
Didn’t it take a bunch of posts on Facebook to get the v3 tune in the works for last years edge? Might help if we all hassle them ?
My owners manual says SP-542, but when I went to the dealer they tell me these plugs are superseded by the SP-578 plug & they dont have any information as far as heat range or material. A couple of googles also really didnt produce any factual data about this new plug. Does anyone know what the difference is and which one is optimal? Other than "tuners recommend 542" once all those plugs are gone we will be stuck with the 578's good or bad.
boostededge replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Installed FORScan. disabled stupid auto stop start filled up on 100/92 mix for 93 octane Looked at evo thought I was fast -
Someone buy this man a beer. Changing the spark plugs doesnt look so bad now
Forscan 100% compatible adapter
boostededge replied to boostededge's topic in Accessories & Modifications
Lol you know what I mean One shouldn’t have to press the buttons each ignition cycle. -
Ordered! Thanks for the assist. -
Thanks! I wanted to stay with a cabled solution but I guess Bluetooth would be fine too. -
I'm trying to find a cable I'll only have to buy once and wont give me any errors. I want to disable the auto-start using Forscan on the 2019 Edge. I dont know if the toggle switch one will give me issues or will limit me from updating some parameters? https://www.amazon.com/Sojoy-FORScan-Scanner-FT232RL-Vehicles/dp/B07BLRMG3R/ref=asc_df_B07BLRMG3R/?tag=hyprod-20&linkCode=df0&hvadid=312064691975&hvpos=1o2&hvnetw=g&hvrand=13112709089528001400&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9033275&hvtargid=pla-701577955637&psc=1 or https://www.amazon.com/gp/product/B01F0GVBWY/ref=ox_sc_mini_detail?ie=UTF8&psc=1&smid=A3HT224M59LA1C Cheers!
I had a lot of the same questions as you as far as which tuning solution I’m going to use. Coming from Ecuflash which is free and has a huge community support, looking at the tuning options for this car or even US cars in general is daunting. On the plugs, you would want to run a closer gap only if your getting high rpm misfires. Otherwise running a wider gap will make more power. Colder plug would help on pump/race gas if your making a lot more whp than stock. Stock/hotter plug usually works better for E85-100.
Thanks! I’m guessing the Ford Performance 70mm for the 2.3 EcoBoost fits as well. Although spendy.
Rear Motor Mount (RMM) (2016 Edge Sport)
boostededge replied to snmjim's topic in Accessories & Modifications
For example on the Evo replacing the rear mount causes more NVH than replacing the front mount, so majority just go with the front mount and OEM rear/sides unless race car. Filling the OEM mount comes from the DSM crowd where filling with $10 of urethane was cheaper than buying an aftermarket mount but was also a good trade-off of NVH vs the aftermarket mounts higher durometer rating. Trying to have your cake and eat it too with stiffer bushings and NVH is often not possible, I understand. -
Yea aftermarket support seems to be pretty poor from what I've gathered. I wish there was something like Ecuflash support. I'm not a fan of canned/off the shelf maps but also not a fan of doing pulls on the freeway. My local dynojet shop doesn't want to tune it unless Cobb has an AP for it so I guess its Livernois or Unleashed for me. The throttle body looked like an easy mod though even if its only good for a few whp.
So it appears the Mustang EcoBoost and several others have the same Ford part number for the throttle body as the Edge ST 2.7? From the info I gathered people are running the BBK Mustang Ecoboost TB on the Edge. Are there any 70mm + options that are also compatible without modifications?
Why does this require the fans to be adjusted?
Rather than making a new thread I thought I'd bump this one. Has anyone tried filling the OEM motor mount with 3M window sealant or the like? Is the front motor mount too difficult to get at? In other FWD-based AWD platforms the front mount is usually the first to be replaced. I can tell the engine/drivetrain shifts back and forth a lot and could benefit from better mounts, however, its not a race care and is supposed to be a comfortable, quiet daily driver. -
Anything new on this? *Edit* Called aFe and they said its still on their R&D list but didnt have any other information. Probably before end of year I'm guessing.
- 2 replies
- cai
- cold air induction
(and 2 more)
