Rick369
Double horn beep after closing door while vehicle is running
I have a 2017 Titanium AWD. I updated Sync 3 to version 3.0 a few weeks ago. After the update, I noticed that I no longer get the double horn beep after closing the driver front door after exiting, while the engine is still running. The key is in my pants pocket and not in the vehicle.
Edited by Rick369
Share this post
Link to post
Are you sure your second key isn't somewhere in the vehicle? The Sync update should have nothing at all to do with that setting.
Share this post
Link to post
Rick, consider yourself lucky. A lot of Ford vehicle owners are very annoyed by that "double honk" and have to have someone turn it off by using a laptop with the Forscan program…. You got it for free! :thumbsup:
Claude. ;)
Share this post
Link to post
I just went out to the Edge and tested it twice. There is no longer a double honk after I exit the Edge while it is running with the key in my pocket. All the doors are fully closed. My wife has the second key in her dresser drawer, which I verified is there. The double honk stopped after I updated Sync 3 with version 3.
Edited by Rick369
Share this post
Link to post
My double honk is back. I got to thinking that maybe my horn was not working and that is the reason for not getting the double honk. I went out this morning and after starting the Edge I tried the horn. Nothing! I went to my local Ford dealer and the wiring connector for the the horn was not fully snapped in and secured. The dealer said it could of been that way from the factory and it got jostled around after going over numerous bumps over the past year. The wiring connector is secured and snapped in place now. The horn works and the double honk is back. Sync 3 version 3 update and the horn not working were just coincidence.
Edited by Rick369
Share this post
Link to post
How do you disable the double horn honk, if you briefly get out of vehicle with the fob in your pocket, in order to not wake the neighbors?
Edited by cabin393
Share this post
Link to post
Yes, but how do you disable the double horn honk if you get out of vehicle, for any reason, while leaving fob in cup holder?
There should be no double honk if you leave the fob in the cup holder.
Share this post
Link to post
He is probably talking about trying to lock the fob in the car with it running. Use the keypad on the exterior to lock it.
Share this post
Link to post
The easiest solution by far is simply to not close the door all the way.
Option 2 is turn off the vehicle. It's already in Park so that's not a big deal unless you want to leave it running for hvac.
Option 3 is to leave the fob in the vehicle.
Option 4 is to use Forscan to disable it.
Share this post
Link to post
On 10/18/2018 at 1:15 PM, akirby said:
push  same time for lock and unlock button  time 3 sec  It was comment about disable honk on web my mechanics.com   to reactivated door again
Share this post
Link to post
Guest Georgia
Just making sure... If I leave the fob in the vehicle and close the door then I will need to use the key pad to get in right?>
Share this post
Link to post
Only if you lock it with the keypad or another fob.  It won't lock with the fob inside just using the inside lock button.
You can unlock it with the keypad or another fob.
Share this post
Link to post
Thanks all for your responses. I had never heard of Forscan. Now I downloaded a copy and have ordered an ELM327 adapter. It will be interesting hacking into the Edge. Professionally I do something like that for Tesla vehicles (mostly Roadsters and S) which are loaded with electronics. I just wanted a nice vehicle for family use but it looks like I just can't avoid the reverse engineering role.
Share this post
Link to post
Share this post
Link to post
If you still have time, might want to consider the OBDLink EX adapter that was developed with input from the ForScan team. I think they even benefit from it which which then support their work.
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
