Moderator-
It's based on an algorithm that looks at how you drive (idling, stop and go, highway miles, etc.) plus temps, etc. It's not a fixed value but under normal driving conditions it should be around 7500 miles.
Sync 3 2016 upgrade to CarPlay
akirby replied to tpm419419's topic in Audio, Backup, Navigation & SYNC
Not sure how it connects - it's all internal. It's been available on other models for awhile now. -
Ventilated/cooled seats in the 2016 fixed?
akirby replied to mjonis's topic in Interior, A.C., Heat, Interior Trim
Both but the back isn't nearly as strong as the seat. -
Yes. -
It varies by vehicle but always on seems to be a thing of the past, at least with the CD4 vehicles (Fusion, Edge). Probably have to wire in a separate charger to an always hot circuit. But you have to be careful with running down the battery - these vehicles already have a lot of battery issues.
Depends on how "technical" you want to get, but ok I'll give you that one. -
According to my sources it's a new usb module. Should have more details in a day or two. The price on the 2016 module is $27 so it doesn't look to be an expensive upgrade. -
It's sync connect. You have to add the embedded modem unless it comes with the vehicle. -
Don't get the tip too close.
Take them to the parts dept and have them look up the parts for the seatback and ask them why there is a cooling device in the seatback. -
1 - yes 2 - you have to pull up on it to engage it and you have to hold it to activate it while moving Accidental engagement is not a problem.
I should know in a few hours. -
I've been in IT for 30 years. Nothing would surprise me. Maybe the extra hardware wasn't available in quantity for the 2016 vehicles. -
You usually have to do that after an IOS upgrade as well. -
Iphone charges just fine and it works fine with siri eyes free and as a media player. If there is an added module then it's for apple security. -
Interesting - I still think it must be a usb port upgrade. I'll see if I can find out. -
I don't think external heat is the problem - it's internal heat. But it certainly won't hurt.
They have not announced CarPlay for sync or MFT yet - it's possible. You need to go into the sync connection on your iPhone and turn notifications back on. -
Excessive toe in or toe out could cause excessive wear - did they check that?
- 12 replies
Stages and status in the order processing
akirby replied to luxpow's topic in Buying, Leasing & Ordering
You said to correct you if you were wrong. You weren't wrong. A couple of points to add though. A special order is the same as any other dealer order except for the priority. If the dealer follows the rules then a retail (sold) order has a priority of 10-19 while stock orders are 20-99. When a dealer gets allocation Ford pulls the lowest priority order that can be built (sometimes a paint color or option isn't available that week) and schedules it. If a dealer has no allocation, your order doesn't get scheduled. If there are multiple orders with the same priority it goes by oldest order date first. -
But is the wear even or uneven? Bad alignment can cause uneven wear but it wouldn't normally cause faster wear across the entire tread. On a FWD vehicle (including FWD based AWD) the front tires will wear faster. And if it's worn down to the point of leaking then you shouldn't be driving. I think I got 35K out of the Michelins on our 2008 Edge. On my 2 Fusions I've rarely got more than 25K. So 30K isn't that bad.
- 12 replies
Well that's exactly what they'll do - deny warranty coverage for the repair. But if you disagree that the problem was related to your modifications then you can challenge it legally.
Yes but it's only proof by a preponderance of the evidence, not proof beyond a reasonable doubt. If you're running oversized tires they're not going to cover wheel bearings or suspension components. If they know you had a tune and your transmission shows signs of too much torque they may not cover it.
