Plug could cause the misfire and lean condition but the other code is specific to an injector problem.
The spark plug should probably be changed though.
In my experience longer battery warranties don't yield longer life batteries, just more up front cost which might be recovered in proration.
I just get the cheap ones and they last 3-3.5 years - same as the expensive ones.
YMMV
See if you can get the service guy to ride with you in your mkx and another AWD edge or mkx back to back in the same conditions. That's the best way to see if it's normal or not. If it was the PTU I'd expect it to happen any time rear torque kicks in - like WOT launches.
Most buyers won't know about it or care. Only techophiles are going to care. And don't forget the 2015 Edge was originally supposed to be on sale last fall and was delayed.
If it's important to you - wait for the 2016.
It hasn't launched yet and they haven't started building customer orders yet so it's a little early to be too concerned. If there is a problem with a specific option that will be communicated to the dealers.
There is no danger if you use the spare that comes with the vehicle. Ford has taken that into account with the AWD software. If something failed it wasn't because you used the factory spare.
Yes there is something different - in some cases a faulty park detector switch was at fault.
But it could also just be a bad battery - they seem to be more common nowadays - not sure why.
Looks like a dealer might be able to change it with their IDS tool. Here is an example:
http://www.justanswer.com/car-electronics/3hy1g-buy-2011-mustang-gt-premium-5-0-usa.html
That may not work with all radio types though.
QNX has nothing whatsoever to do with the design of the application (user interface). You could run sync 3 on windows or MFT on QNX (with modifications but the same user interface).
Uh-oh. If you're sure you pulled the right fuse then it might be fubar.
I would try pulling the negative battery cable just to be 100% sure that everything got reset. If that doesn't fix it I think it's hosed.
