Everything posted by omar302
2016 Sport, ~ 37K miles.
Adaptive headlights
omar302 replied to Itsdjellz's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
It is a simple As Built data change to remove it! -
open windows with key fob?
omar302 replied to mrmikesdeuce's topic in Alarms, Keyless Entry, Locks & Remote Start
It is included in the US manual, at least it is on the 2016 model. http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=3972&languageCode=en&countryCode=USA&Uid=G1721749&ProcUid=G1721750&userMarket=USA&div=f&vFilteringEnabled=False -
Adaptive headlights
That's a new level for Ford. Describe something that's clearly wrong as normal! They should either enable the selection or remove it from the IPC. -
On the 2011-2014 Edge, no. Not even with ForScan. It does work on the 2011-2015 Lincoln MKX. -
One more thing on the 2015+ models, the remote window opening does not work while the vehicle is remote started. The engine has to be off. Another note, with ForScan you can also enable remote closing of the front windows. -
Fixed sunroof glass
omar302 replied to niceonept's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I remember reading the same issue in the Forums. Even the newer Edges came from the factory without the laminated sunroof glass. Did you notice any sound difference? -
What @Cerberus stated. Just make sure it is enabled under vehicle settings in the left instrument cluster screen. I think it is referred to as "Global Windows" or "Remote Windows". -
Learn something new. Maybe look if there replacement stem mounted TPMS sensors that replace the band style sensors.
My '20 Edge ST Towing Experience
omar302 replied to poontanghooligan's topic in Cargo, Hauling, Roof Racks & Towing
Ford's ECU measures to protect the AWD has been present since at least the 2011 Edge model year, yet many PTUs have failed. Ford even made later versions of the PTU with oil drain plugs to allow for oil changing on some newer models. -
If I were you, I would definitely drain & replace the PTU & Transmission fluids, maybe even the RDU. Getting 11.6 mpg driving 62-64 mph over 1000 miles means your Edge was really working hard. -
0.8 mpg is nothing. it can simply be different fuel, driving style, ambient temperature,...etc. For the name/brand, I don't remember that there is any Ford "approved" intake cleaning brand/method. So if the brand you used claimed to be "approved", they should be called out to warn others.
- 11 replies
- 2
- crc
- valve cleaning
"No Key Detected" and Car Won't Start
omar302 replied to Shockwavesix's topic in Alarms, Keyless Entry, Locks & Remote Start
For me it sounds like a bad vehicle battery. I wouldn't even be doubting it. The "click click click" sound is typical of the starter not receiving enough voltage to crank. Being a 2 year old battery, start by replacing it before trying to diagnose it as another cause. Also, this is not related to the "no key detected". -
@ANoid: Electronic Stability Control. From the Edge Owners manual:
Congrats on or new ride and welcome to the forums.
Power Locks not completely working
omar302 replied to LM1989's topic in Alarms, Keyless Entry, Locks & Remote Start
If I remember correctly, Pre-2015 (Gen 1 & 1.5) Edges, the rear doors do not open like that, they have to be unlocked either by the power unlock or by raising the lock "knob" by hand. Front door locks open simply by pulling the door handle. The "Pull twice" for the rear doors is applicable on Gen 2 Edge (2015+) & MKX (2016+) -
It depends on how hard you drive & how much you let it idle because it affects fuel mileage a lot.
If @akirby's suggestion doesn't work, try to disconnect the vehicle's battery for about 10 minutes then reconnect it. Also, a low voltage battery would prevent remote start, so that's also a possibility. A long drive should recharge the battery sufficiently.
Windshield NOT acoustic Glass ?
omar302 replied to DNBush's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Seems that Carlex & Carlite used to be different companies, both related to Ford, but eventually Carlex purchased Carlite. Found an article in this AGRR Magazine about it. Too complicated and I don't know what that means to this issue, but if your vehicle never had a windshield replaced before, then it has to be acoustic glass as it is a standard equipment on the Edge, regardless of what is written on the glass. On another note, the side glass might be "branded" as acoustic because it is not standard equipment, hence the differentiation. What puzzles me more is that the 2021 Edge does not show acoustic glass anymore in the Order Guide.- 10 replies
- windshield
- glass
Maybe a tire tread starting to separate?
How to remove liftgate panel
omar302 replied to Starting to hate this car's topic in 2015 Edge & MKX
See this: Liftgate Trim Panel.pdf -
As per the 2020 Edge Order Guide, the acoustic windshield is standard equipment. Seems the 2020 windshield is made by AGC Automotive, while the previous models were from Carlex and the "Soundscreen" branding is apparently part of Carlex. AGC Automotive also makes acoustic glass as per their website.- 10 replies
- 4
- windshield
- glass
What is written on the windshield? Does it say "Soundscreen"? Here I had posted a photo of the windshield on my 2016.- 10 replies
- windshield
- glass
Locking Out Higher Gears without being in Sport Mode
omar302 replied to chipdog4's topic in Accessories & Modifications
Keep it in Sport mode without pressing any of the paddle shifters, the transmission should hold gears more & would lockout the highest gear or two.
