JoeVic
Everything posted by JoeVic
Anyone with an ST update to 3.4? Does the screen still show the "ST" logo during start up?
I would get one. This dealer was recommended to me on here and it has some of the best prices that I could find: https://www.floodfordesp.com/?gclid=EAIaIQobChMInunQutKb6wIVxJJbCh0vOA6MEAAYASAAEgJOEPD_BwE
How to carry keyless entry LARGE fob.
JoeVic replied to Snoking's topic in Alarms, Keyless Entry, Locks & Remote Start
I used to have numerous flat car keys on a ring, which were no problem in a pocket. Now I have the large FOB, in addition to house keys on a ring that I have to carry. In the summer my cargo shorts have a small pocket that it fits perfect in. In the winter it goes in a jacket. It is when I am wearing jeans that I have a problem. I have a similar carabiner that I hooked to a belt loop, but it kept getting caught on things. So for now I only carry one FOB at a time and just deal with it in a pocket. -
Do these seat covers cover the side airbag?
txaggie, So the front ones went on without any modification to the guard. Correct?
Unfortunately it seems like Ford is continuing to cut corners $25 to $75 at a time. Those small things like the instrument panel hidden drawer, under-hood insulation, dual compartment center console, etc. that folks have gotten accustomed to, get chopped by Ford. And while they are minor issues, they are things I have gotten used to using and would miss.
OBDLink Announces New Wired OBDII Reader
JoeVic replied to Gadgetjq's topic in Accessories & Modifications
Are you using Forscan as the dashboard on the Kindle Fire? If so can you change the settings to show Fahrenheit and also PSI versus the metric equivalent ? -
i just ordered one yesterday from Amazon. The ScanTool.net sight is still showing none available. -
https://myaccount.carandtruckremotes.com/cyc/search/searchv1.php?searchyear=2018&searchmake=Ford&searchmodel=Edge I have gotten two remotes from this sight. One for an SEL and one for an ST. Programmed both following the owners manual. Have had absolutely no issues at all. Not sure who you used or how much you paid, but the listed products were well worth it.
Did all of the attaching hardware come with it and was it just a direct snap in procedure ? And do you have the part number handy ?
I find they get hot also, but i usually turn them off after they take off the chill.
Changing 2019 Edge's weak single horn to dual horn
JoeVic replied to 9mmbullitt's topic in Accessories & Modifications
I did mine a couple weeks ago. The "B" part made in the USA has two FIAMM AM80SX horns. One marked "H"igh and the other "L"ow. I was able to look up the specs on the FIAMM sight. Do you know what the markings are on the "A" part (Level 3) ? -
Why did my Battery go dead overnight?
JoeVic replied to cleekoguy's topic in Accessories & Modifications
That's what I thought. The original battery on my 2015 SEL died a few weeks shy of 3 years. Just under the wire to get it covered by the warranty. -
It seems the problem is the Service Department's shortcut. I have changed the oil on my 2015 3.5 SEL and have dropped the entire splash shield. I believe it is about 6 bolts and a plastic clip or two. It does add a few more minutes to remove and replace the shield, but I do it properly. I did notice that at least one of the bolts no longer has a tight fit inside the plastic grommet (probably why your guy just used a larger bolt), but since I didn't bend mine down it stays in place. Did you ever get a reply from Ford?
2019 Edge heated steering wheel
JoeVic replied to spsiege's topic in Interior, A.C., Heat, Interior Trim
I assume it is like the rear window defroster. It runs for a predetermined amount of time and then it shuts off. If you still need defrost, you manually turn it on for another cycle. When mine came on with the recent cold, I had to manually turn it off sooner than its cycle because I thought the steering wheel was getting too hot. There was a thread on here explaining how to change the heat settings with ForScan and one of the statements was about how the higher the set temperature the quicker the heating element would burn out. I don't think it is meant to run continuously, but someone with better knowledge may be along soon. -
Some things you can actually see, such as the battery. It is obviously a larger capacity battery. But the starter, starter solenoid, alternator/generator not so sure. And I am sure Ford doesn't want to be replacing starters at an astronomical rate on vehicles with auto start/stop, but I still think there has to be more overall wear on a starter that may activate 25-30 times a day as compared to twice a day. Maybe it is because of my age and experience with older cars. You knew that starter or alternator had a certain lifespan and that was it. Come to think of it, I haven't replaced a starter since an '85 Dodge Diplomat.
Amazing cleaner for car leather .. and cheap
JoeVic replied to enigma-2's topic in Appearance - Detailing, Wash & Wax
Any update to this? First time I will have to take care of leather seats and I am wondering what everyone uses. -
I bought mine in the early Fall so I haven't had any sustained extreme temperature conditions to judge the climate performance. What I did observe was a non factor. The startup is slightly more noticeable than other brand vehicles that I have driven with auto start. An Escape I rented in Los Angles I had no problem leaving engaged. I don't mind the engine shutting off for a minute or more, but every block for 5-8 seconds sometimes is annoying. And you can't tell me that there isn't more wear and tear on the components utilized to constantly restart. I do try to leave it engaged as much as I can, But I am glad we have to option to disable it.
I hate when I am pulling up to a red light and I can see from the countdown pedestrian timer that I will only have the light for a second or two and then the engine shuts off, only to have to immediately start two seconds later. I find myself quickly shutting off the auto-start when I see this scenario.
My 2015 Edge's OEM battery died a couple weeks short of 3 years. My 2004 Crown Vic's batteries would last almost 6 years. Sounds like you have some sort of issue with the vehicle that is affecting the battery.
- 10 replies
Do you know what your vehicle's build date is?
Are you able to take that ST for a test drive?
Bought my 2019 in September 2019. Built August 2019. It has the Trans issues, but I haven't had a chance to get back to the dealer yet. Only have 1,000 miles on it and waiting to see what else the dealer has to address. Other than that, I am happy with it.
Keyless Entry 2017 SEL
JoeVic replied to Needle's topic in Alarms, Keyless Entry, Locks & Remote Start
As long as you have two programmed fobs, you can program a third one yourself. I would look at places like https://www.carandtruckremotes.com/ to buy a third fob. Much cheaper than the dealer. I bought from them and had no issues at all.
