Beezz Posted August 3, 2016 Report Share Posted August 3, 2016 For me: Bottom of seats cool when the AC system is running, backs do not When the AC system is off, the backs cool, the bottoms do not I am beyond confused. Going to have my dealer take a look soon, just concerned about seat damage as other posters have been. Quote Link to comment Share on other sites More sharing options...
t0lkman Posted August 8, 2016 Report Share Posted August 8, 2016 Confirm, for me as well - when AC is turned off, I feel backs are being ventilated Quote Link to comment Share on other sites More sharing options...
MichBiz Posted September 19, 2016 Report Share Posted September 19, 2016 Took my 2016 Ford Edge Sport into the dealership today because the back of my seats didn't feel like they were cooling. After a day in the shop, the service advisor called to tell me that the seats are working as designed. Cooling to 50 degrees on the bottom and 70 degrees on the back. I told him that I didn't feel any air coming from the back or cooling at all and he said he didn't know what to tell me. My Edge was built 5/16 after the service bulletin... I guess I should send a complaint to Ford? Quote Link to comment Share on other sites More sharing options...
akirby Posted September 20, 2016 Report Share Posted September 20, 2016 Known problem. There is a TSB but most say it doesn't work. You're pretty much stuck with the way they work until Ford redesigns it sometime next year (hopefully). There is a person on the f150 forums who 3D printed a part that supposedly works much better but it's expensive and you have to install it yourself or pay somebody. Quote Link to comment Share on other sites More sharing options...
cjh Posted September 20, 2016 Report Share Posted September 20, 2016 The only way I know the back is cooling is when I forget to turn the cooled seat on when it's warm outside. After 5-10 minutes, I notice I'm a bit warmer than normal. 1 Quote Link to comment Share on other sites More sharing options...
Paul Proefrock Posted September 20, 2016 Report Share Posted September 20, 2016 (edited) I had the TSB performed and didn't solve the problem. Owning a F150 with cooled seats, I was intimately aware of the issue and the fact the seats are almost identical. There is a lot of discussion of the problem on the F150Forum, which led to someone finally coming up with a solution. I installed Tim's fix and it did solve it. Thanks alot, Ford. Why did I have to buy components to resolve YOUR warranty issue. This is a link to his site. SeatGuru It can be fixed, but unfortunately, it isn't inexpensive. Paul Edited September 20, 2016 by Paul Proefrock 2 Quote Link to comment Share on other sites More sharing options...
jwm22222 Posted September 24, 2016 Report Share Posted September 24, 2016 Fwiw I do note that the cooled seats on my 2016 Edge Sport are functional but barely. When my back is a bit sweaty I can definitely feel the cooling from the seat backs. That's the only time I can feel it but under that circumstance I do find it helpful. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 16 hours ago Report Share Posted 16 hours ago (edited) After all these years and summer almost here I'm looking at improving the backrest cooling. See below F150 thread on the topic - is this still the best option? I downloaded the 3D printer file from the link and will ask a friend to print it for me. https://www.f150forum.com/f118/heated-cooling-seat-fix-upgrade-preventative-fix-440863/index12/ https://www.mcmaster.com/6519N15/ Edited 15 hours ago by 1004ron Quote Link to comment Share on other sites More sharing options...
omar302 Posted 4 hours ago Report Share Posted 4 hours ago (edited) 11 hours ago, 1004ron said: After all these years and summer almost here I'm looking at improving the backrest cooling. See below F150 thread on the topic - is this still the best option? I downloaded the 3D printer file from the link and will ask a friend to print it for me. https://www.f150forum.com/f118/heated-cooling-seat-fix-upgrade-preventative-fix-440863/index12/ https://www.mcmaster.com/6519N15/ The fix posted is only for the intake side so that it can take in cooler air. But the exhaust would remain to the seat back cavity, so eventually the seat back will heat up to a point where it can no longer be cooled by the TED. The best fix is to have both, intake & exhaust routed outside the seat back. However, your Edge is a 2017 model. Midway in 2016 Ford added a "sock" for the intake so it can take in air from under the seat. So your Edge is good on the intake side. To improve your seat back cooling you need the exhaust side. Unfortunately, the guy (Tim) who used to sell those kits doesn't seem to sell them anymore. But I remember some F150 owners making their own fixes using duct tape and tubing. But I couldn't find any searching now. Also, the F150 thread you linked talks about another issue some are facing with their seats, it is an electrical issue, if it happens causes the whole cooling/heating function to stop. Edited 4 hours ago by omar302 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted 2 hours ago Report Share Posted 2 hours ago Thanks @omar302 Now that you mention it I can see what appears to be that "sock" without pulling the upholstery up. I only use the seat cooling for 5 minutes max 10 minutes and can feel the seat cooling and very minimal on the backrest - I can hear the backrest fan running. Now to search for the MacGyver fix for the exhaust. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 1 hour ago Report Share Posted 1 hour ago (edited) Searching I came up with the below threads, and still searching for the 3D print files so that my friend can do those for me. https://www.road-reality.com/2016/11/03/how-to-and-review-seatgurus-2015-f-150-seat-fix/ https://www.road-reality.com/2016/11/03/how-to-and-review-seatgurus-2015-f-150-seat-fix/3d-printed-part-and-tubing/ Edited 1 hour ago by 1004ron Quote Link to comment Share on other sites More sharing options...
