    343
  1. Website and order guide say it's still available. Probably just a glitch on the build and price website.
  2. Are they using laminated safety glass now? If so it's probably a delamination.
  3. Did you try the 1975 section?
  4. Please don't post the same thing in multiple forums, especially in existing topics.
  5. That's exactly what we're considering but maybe with the 2.0l.
  6. Yes you can adjust the halogen lights vertically. In the past they were usually aimed too low from the factory.
  7. Those are regular halogens. HIDs are brighter and whiter.
  8. Technical Service Bulletin. It's an instruction to the dealers on how to fix common problems. But in this case it's probably a bad tire. Try swapping the tires left to right and see if the pull changes direction.
  9. The average price of a new vehicle is $33K. The average price of a new Ford is $36K.
  10. The old school guys would have just used brake cleaner and a match......
  11. HIDs are available with the Titanium 302A package. I understand your point about the garage door opener - that one's a puzzler. But that's why you have to do research before you buy something.
  12. If those features had been standard the price would have been higher. Cheaper vehicles with those features standard are missing other features that Edge has. It's just a question of how the mfr packages the options. Did you buy the vehicle thinking those were standard without checking?
  13. You can't turn the AC on or off via the steering wheel, but my point was that you don't really need to - just adjust the temp as needed and let the auto climate control do its thing.
  14. They will stay powered on until the door is opened for sure. After that it seems to vary by model. Sometimes one port stays powered and one doesn't. Just test it by shutting off the vehicle and opening the door, then check the ports.
  15. Perhaps the dealer modified or used an existing order. That's really quick!
  16. I don't think it's terrible, but probably a little worse than average. Then again the Edge has not been trouble free either.
  17. In fact yours has probably been inspected much more closely than other Edges.
  18. Yes - it won't remote start if it doesn't think it's in park.
  19. You can see the exploded parts diagram at fordparts.com - might tell you something if you compare the 2014 and 2015
  20. I meant check the one you found online for a 2016 and see if they offer the same model number for a 2014. Not definitive - depends on whether they did actual research or just assumed it fits.
  21. But it's not a separate button. It's one big circuit board. If one button failed on your wall oven do you think you could buy one button to fix it? You have to buy the entire circuit board and whatever it's attached to. Why do you need to turn it on and off manually? Just let the auto climate control manage it. I don't think I've touched my A/C button in years. Auto climate will turn it on and off as needed. I don't know what's underneath the touch button - it might be possible to clean it.
  22. Sounds like yours might be due to something being loose with the driveshaft based on the clunk and that it doesn't always happen - that should be easy to diagnose.
  23. Are you asking whether the frame changed from 2014 to 2015? Most likely since it's a completely different platform. Does the one you found say that it's only for 2015-2016 or does it say it fits previous years? That would be a good clue. Or see if they have the same thing available for 2014 and see if it's the same part number.
