Moderator-
Brand New Tires Will not Balance Properly...WHY??
akirby replied to Dub City's topic in Wheels & Tires
Absolutely- 25 replies
- tires
- wheel balance
(and 2 more)
I think he was referring to the OP's problem. It could easily be a driveshaft especially since he never feels it through the steering wheel.- 25 replies
- tires
- wheel balance
(and 2 more)
Transmission Rotating Clutch Assembly
akirby replied to Melltimejr's topic in Buying, Leasing & Ordering
It means they probably had either an assembly line problem or a bad batch of parts. Nothing to worry about - if there was a problem they would have fixed it. -
4WD Escape 2017 versus AWD Edge 2016???
akirby replied to CharPatton's topic in All Wheel Drive (AWD)
There is no difference in the escape, edge or explorer AWD systems regardless of what they call it. They're all FWD biased and can only shift torque to the rear for short periods, there is no center differential or locking diffs. There are some smart electronics to manage it in different situations but not true 4wd like your old explorer. -
An Edge Sport and an Explorer Sport go out for a drive...
akirby replied to cjh's topic in 2015+ Edge & MKX Generation II
The 3.5LEB is torque limited to protect the drivetrain in transverse applications - the D3 platform had to be modified to handle it. The 2.7LEB is an all new design and the new Edge platform was designed to handle the power. I wouldn't be surprised if the Edge Sport is putting more power to the ground at most RPM than the Explorer Sport. -
Possibly. Was the A/C on at the time? With A/C on both fans should be running.
Too specific. Sometimes you have to use less words and just look through the results.
I just plugged in "spark plugs" into the search box upper right and it was on the first page of results.
http://www.fordedgeforum.com/topic/18924-spark-plugs/?hl=%2Bspark+%2Bplugs
2015 Edge Sport Towing
akirby replied to built2prfctn's topic in Cargo, Hauling, Roof Racks & Towing
Use the search box in the upper left and change it to "forums" and it will search the entire forum. I don't think the sport hitch problem is unique to the 2nd gen. -
2016 Edge Titanium with 302A package Lease
akirby replied to tpm419419's topic in Buying, Leasing & Ordering
If you mean lower than MSRP just increase the down payment to include the discount off MSRP. Or price a lower MSRP vehicle that matches your expected discounted price. Should be really close. -
Ford build and price gives you a payment calculator where you can plug in different down payments. -
Have you considered it might not be the wheels/tires? If it was and you've swapped the wheels front to rear you should get a vibration in the steering wheel at some point. The wheel balance issue may be a red herring. Check the rotors, calipers, tone rings, etc. next would be the drivetrain especially the driveshaft if it's AWD.- 25 replies
- tires
- wheel balance
(and 2 more)
New Owner! Picked up my Edge Titanium 2.0 tonight!
akirby replied to bspaceman's topic in Welcome Forum!
Be sure to read the OM - lots of neat features, especially the keypad on the door. -
The NHTSA maintains a public database of TSBs with summary information. Don't have a link - just google it.
Bought 2010 Edge only came with one key
akirby replied to ludude1975's topic in Alarms, Keyless Entry, Locks & Remote Start
Beware of locksmiths who are simply cloning your existing key. It works to get 2 working keys but the vehicle thinks it's the same key and you won't be able to add your own key later. -
Loaded Edge Titanium 2016 without sunroof?
akirby replied to CharPatton's topic in 2015+ Edge & MKX Generation II
And probably many other things..... -
2016 Edge rear wiper
akirby replied to Livestrong16's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Should be a normal wiper - just measure it and try an over the counter replacement. Or have the auto parts store look it up. -
It's not available, even as a special order. I don't think they do custom paint either. edit: (at least not for anyone not named Mark Fields) -
You can't add a key unless you have 2 working keys already. The reason is security - if you could do it with just one key then so could a mechanic or a valet and you don't want that. So you have to take it to the dealer OR a locksmith that has Ford IDS access. You can get the key anywhere (ebay, etc.) so you'd only have to pay the dealer for programming. Shop around. -
It's the same as the 2015
Why no towing package offered on Sport Edge 2016?
Aesthetics - the factory hitch won't fit the Sport bumper. Has nothing to do with the engine. -
Offset. Tirerack.com will show you which wheels fit your vehicle so you can figure it out from there or use it to compare.
If it's being held for a quality issue I don't think there is any easy way to get any info. Ford isn't going to release any info about it publicly and in some cases they truly can't give you an ETA if it's sitting in a lot waiting on a repair or an inspection. Ford should at least be able to tell you if it's being held and you would hope they are prioritizing retail (sold) vehicles first but not sure the factory is set up that way. Either way it sucks. Back when they launched the 2013 Fusion and MKZ it was worse - they had thousands of vehicles that had to be held and some were even shipped to Flat Rock for repairs and shipped back to Mexico. That's one reason I'm trying to wait and find a 2016 that's in stock whereas in the past I've always ordered vehicles.
