My guess is product differentiation. Can't have the same trans in the Edge as in the Explorer/Flex. Why have we been limited so far?
The engine isn't the issue, it is what is attached to it that's the issue. You could probably get a few more ponies out of it with a tune, but would have a hard time putting it to the ground. Right now, you can squeeze out 25-35% out of a 3.5L EB TT with only a tune, but then the trans has proven to hold up to it. Not the case with the Edge AFAIK. The PTU is still the weak point, so maybe going with FWD might be better for performance-seekers. The amount of fluid in the PTU is just laughable, assuming it is even filled correctly at the factory.
I believe the 2.7L EB is reserved for the Sport? At least it's a V6 I don't think they are really building headroom into the powertrain for performance-izing the engine (due to trans limits), so it will be WYSIWYG, as with prior Edge iterations.
I bought mine off EBay a year and a half ago (manual liftgate). They started acting up again this year once the colder weather set in. I think I have a 2 year warranty limited lifetime warranty from the seller, let's see how a return/replacement goes http://www.ebay.com/itm/370924078321
It is possible that the Restraint Control Module has been damaged (even if airbag did not deploy), and you should make sure that is among the parts replaced. The harness to/from it should be checked for shorting also.
EBay is the easiest way to get it, but there are other sites that sell the manuals at full price. The alternative is to buy a subscription to the information online (such as at mitchell or alldata). Maybe motorcraft also provides access online, not sure.
Probably referring to a PCV vent? Might be as simple as replacing the valve & hoses?
- 4 replies
- 3.5L V6
- Casting Porosity
This is what the OM has to say about it: Heated outside mirrors (if equipped) Both mirrors are heated automatically to remove ice, mist and fog when the rear window defrost is activated. Do not remove ice from the mirrors with a scraper or attempt to readjust the mirror glass if it is frozen in place. These actions could cause damage to the glass and mirrors. Do not clean the housing or glass of any mirror with harsh abrasives, fuel or other petroleum-based cleaning products.
Wow, not good! I certainly hope Ford has mitigation in place, as that is a definite and known fault with the engine/production process. They seem to have known about since at least March 2008? Wow. Most reports of leaks have been PTU related, either a seal failure or the PTU vent spitting up its' lubricant.
- 4 replies
- 3.5L V6
- Casting Porosity
Passenger side seat back is vibrating
WWWPerfA_ZN0W replied to Nichole Johnson's topic in 2007 Edge & MKX
Check the seat track bolts from underneath the Edge, they may need to be tightened. Is the ratcheting mechanism firmly seated in the groove? Maybe move to a different notch?- 1 reply
Good luck!
charcoal air cabin filter
WWWPerfA_ZN0W replied to richy's topic in Interior, A.C., Heat, Interior Trim
Instructions for cleaning: http://www.knfilters.com/video/Cabin_Air_Filter_Cleaning.html http://www.knfilters.com/instructions/18685_Inst.pdf -
Please remember to post pics & sound clips! -
Got mine in the mail today as well.
Ouch! Glad you are ok, the Edge may have taken a hit to the BCM or relays, it looks like. Check underhood fuses to see what might be blown.
I saw an Engine Oil Pressure warning but not an Engine Oil Life display in the 2010 Owner's Manual. I think your mom is doing a great job! But if using Ford SynBlend, 5K/6months whichever comes first on a normal duty cycle should be fine. Extreme conditions, like repeated stop-n-go in city traffic, 3K/3 months would be better. Aftermarket full-syn oils can last longer.
WE WANT APPS ON MY FORD TOUCH!
WWWPerfA_ZN0W replied to CinnamonEdge's topic in Audio, Backup, Navigation & SYNC
Have seen a guy "transplant" a Sync3 system into a Sync2 SHO. Supposedly everything works except the nav display in the gauge cluster area. Even that may be resolvable, they think, but that might require a dealer to turn on a thing or two via IDS. -
Ask Benny (LevittownFordSuperCenter) to see if anything can be done about shipping? If the second shaft you picked out isn't corroded, maybe it can be lathed smooth. But I wouldn't know how tight the clearances are with the seal, so it might still leak.
Random thought
WWWPerfA_ZN0W replied to PrinzII's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Are they available in the style you need? Not sure what the bulb collar means, but I see H4/H13/9004/9007 listed as options. These seem to be HI/LOW type bulbs. Since the Edge uses a shutter (right?) for high beam, would you be running LOW all the time, or HIGH all the time? Worth a phone call to vLED. -
Hope you can hit the 500,000 mark in this fashion
