Sorry to hear, nc_edge! Is the battery pretty new? If it is more than 2-3 years old, it should be replaced. That's where I would start. These random problems start at the battery most times, especially with cooler weather moving in. If that that doesn't fix it, we can look at other possibilities. Please provide update on service history, mileage, etc.
Wiring Diagrams for 2013 SEL "6" Speaker System
WWWPerfA_ZN0W replied to Rmmcgrew's topic in Audio, Backup, Navigation & SYNC
If you made the entire factory manual available for free/sale, that might be a problem. I think you are ok as is, chipworkz -
What size Winter Rims & Tires for 2013 Edge AWD
WWWPerfA_ZN0W replied to Sprocket2324's topic in Wheels & Tires
Tirerack.com will point you in the right direction as far as wheels/tires for winter. I don't change the setup for the winter, running OEM 18" wheels with Nitto tires. Works fine for me, but then we don't experience deep winters here (usually). -
Congrats & welcome! Put up some pix of your new P&J
Aw phooey! Hope they repaint the entire panels, and properly.
Sorry to hear about the scratches, that's gotta hurt! I think I will follow suit with the dielectric grease the next time I get to pop 'em suckers off
What Edge Trim Level Did You Choose and Why
WWWPerfA_ZN0W replied to carjock's topic in Owner Impressions
Welcome & congrats! Do put up an intro in the New Member section -
how about changing interior to red..?
WWWPerfA_ZN0W replied to ibrahim1415's topic in Interior, A.C., Heat, Interior Trim
If it is a two tone like you have pictured, and one of the colors matches your paint color, that would look pretty good! Otherwise, as an accent color, probably just OK or even odd as omar said. But remember it IS your choice first & foremost. -
Bit the bullet on a '13 Edge Limited AWD!
WWWPerfA_ZN0W replied to careercadaver's topic in Welcome Forum!
If you get the MKT, get the EcoBoost engine, tune it and beat the crap out of some tuned WRX's J/K! -
Congrats! Awesome to have another Edge rolling down the road in style -
Performance mods you would like to see for the Edge/MKX
WWWPerfA_ZN0W replied to WWWPerfA_ZN0W's topic in Mods & Tech
I know of one person that has a transplant project in the works (SHO -> Edge). Has been taking some time because the engine is being upgraded at the same time. No idea on completion date. Then there is the issue of the drivetrain. I assume we'd have to get the whole kit & kaboodle (engine/drivetrain/electronics) transplanted. The 6F55 has been pretty stout, noone's really tested the 6F50 transmission.- 32 replies
- Engine
- Suspension
(and 3 more)
I thought they just send them to the crusher straight away. -
Yes, just a teensy weensy bit Oil is now given far greater importance than ever, and that is a good thing!
No Power Leaving From Red Light and Check Engine Light
WWWPerfA_ZN0W replied to tamugrad2013's topic in EcoBoost Mod & Tech
Looking forward to a report of success! Did they say where the coolant leak was? -
2015 Order Guide: Update 4/2
WWWPerfA_ZN0W replied to Magnetic Edge's topic in Buying, Leasing & Ordering
x2 on the congrats, rmmick! -
PTU leaking after axle replacement
WWWPerfA_ZN0W replied to iamovertheedge2's topic in 2007 Edge & MKX
Please send your info to FordService via PM as advised in post #3. Hope they can help you out! -
Wow, that is quite the brushoff! Either they never expected this problem, or they simply are further back in the cycle with this than they are with the throttle body.
Probably wouldn't hurt to change the oil filter every 5K miles though, plus the 1 quart of oil that necessitates. Bascially, follow the lower of oil filter/oil recommended change interval.
Long wait! Hope it will be a bright, sunny, dry day when you take delivery
Sounds like a bad climate control module. Blend door could be sticking, but doesn't sound like it. When the cool air blows, is it really cold air or just medium cool? If it only gets so-so cool, may want to check coolant level and whether the radiator fans are coming on.
Led Puddle Lights
WWWPerfA_ZN0W replied to Muser99's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Looking forward to those pics -
Pretty darned long power outage at the dealership, glad they figured out the ON switch! Good luck, and keep us apprised.
