omar302
    199
Everything posted by omar302
  1. For the front map lights & glove box I used these: http://www.amazon.com/dp/B00AIJY2ZM/ For the rear dome & cargo lights I used these: http://www.amazon.com/dp/B009NOZ5AY/ For the door mirror puddle lights I used these: http://www.amazon.com/dp/B009NOZ5BI/ Reverse light: http://www.amazon.com/dp/B00H8YAX1W I went with the above because of the brand (Philips & Sylvania). Note that you need to make sure you get the 6000K version to get the bright cool white color.
  2. chipworkz, Thanks a lot for the info. I did not know or expected the "Battery Monitoring System (BMS) Reset". How is it rest with the scan tool? Can it be reset without it and without having to wait 8 hours?
  3. First, it's an 8" touch screen, not 5". As for the different readings, it seems to be due to a different rounding when converting from Fahrenheit to Celsius. If you convert the units to English (in the left screen settings) you'll find that both would have the sstreading in Fahrenheit even when they were different in Celsius. The different readings always occur at the same temperature readings. I have previously highlighted this to the Ford IVT member in this forum, but they directed me to the Middle East Ford customer service which useless. Hope you'll be able to highlight it better as it is a simple software issue.
  4. Thanks a lot. So, a fully loaded Sport AWD without 21" wheels and without summer tires MSRP's for $ 49,195/-. Now we need to know what is included in the 401 & Driver's packages, and of course the 2.7 Ecoboost's performance.
  5. Seems like Ford's MyTouch is not the most distracting per AAA: http://m.autoblog.com/2014/10/07/aaa-voice-recognition-distracted-driving-study/
  6. If it attaches to the windshield & you have rain sensing wipers, it might be the sensor for it.
  7. Just for information, the fuel used when remote starting your vehicle is not registered in the trip computer. So if you remote start frequently, actual used fuel will be higher than the trip computer.
  8. You can use voice commands to change air flow to the floor. Sync button > climate > Floor on.
  9. 2011-2012 MFT & MLT have a capacitive button for the hazard lights, just like the other capacitive buttons for the HVAC & media controls. In 2013 they changed to a physical button.
  10. On the 2015 F-150 (probably also the Mustang), you'll need to 're-train the sensors. The procedure is stated in the Owners Manual which can be downloaded from Ford's owner or fleet website. So it seems to be cheaper method, utilizing the existing equipment. It is really annoying that it's not available on current Fords, and super dumb not to include in the 2015 Edge. They should also offer it to existing owners, but that's just a dream.
  11. The 2015 Mustang also has individual tire pressure readouts.
  12. The TPMS in a Lexus shows individual pressure readouts of all 5 tires.
  13. Just checked the Owners Manual and yes, the MKC does have the auto folder feature, unlike the Explorer that manual power folding mirrors.
  14. The Explorer's mirrors do NOT auto fold. You have to press the switch for them to fold or unfold when required, so don't expect to get the auto fold feature in any case.
  15. Like what akirby wrote above, or, if you have MyFord Touch, in the main screen > Settings>Vehicle>Door Keypad Code.
  16. The screen has to turn off & then on for the image to become clear again.
  17. Camera is ok in daytime. It is not that the Camera has been on for a long time, it is the vehicle that has. In all the above samples, the camera was on for less than a minute (mainly to get the photo sample).
  18. An update to this same topic. Had always noticed that at night near my place, the camera display would be grainy, while at my Parents it is clear at night. Then I realized that I park in reverse at my place, meaning the Camera turns on after driving for a certain period, while at my Parents, I would park straight, so when I back up, it would be the 1st thing I do after starting. So after some testing, I found out that the rear Camera gets grainy at night after driving for some time (maybe heat?) but turning off the car (Center display off) for a few minutes (3-5 minutes) then turning the rear camera on (reverse), the display becomes clear!! Pictures speak for themselves! My 2011 MKX: Sample 1, at 9 PM: Same view at 10:43 PM (1:43h later): Sample 2, at 8:49 PM: Same view at 8:51 PM (2 minutes later) A buddy's 2013 Explorer: At 10:29 PM: Same view after less than minute later:
  19. You should not need to calibrate the screen. I suggest taking it back to the dealer. But, since this is a forum with DIY advise, try the calibration menu in the diagnostic mode. To enter MyFord Touch into diagnostics mode: - Make sure there is no CD in the system - Set MFT to AM/FM - Press and hold the eject button and... - Immediately after press and hold the right arrow on the center wheel while still holding the eject button - Hold both buttons pressed for about 12 seconds - Screen goes black and MFT enters diagnostics mode The system defaults to a speaker tone test which starts immediately. You can cancel it on the screen. You should find a screen calibration entry (don't remember it exactly), after finishing, tap anywhere on the screen to exit. Edit: Found the below screenshot, don't remember were I got it from!
  20. Try switching to tow mode DTE calculation & then back and see if changes it. Also, the low fuel warning will come at 20 km to empty & at zero. When at zero, the gauge turns to red color. You'd still have a few kilometers to go, I think the max I went was 4-5 KM after zero, but never ran empty.
  21. The TSB content was posted in this thread: http://www.fordedgeforum.com/topic/13168-ambient-lighting-problem/ The fix seems to be related to version 3.6.2 only. So i'd guess this means other software versions are not affected.
  22. A DIY was posted in the Explorer forum which have the same turn signal stalk: http://www.explorerforum.com/forums/showthread.php?t=395191
  23. To OP, do you do a lot of remote starts? I do & noticed that the fuel used during remote starts is not calculated in the Trip Computer so the actual fuel used is always going to be more than what is registered in the Trip Computer. Actually, I wish they had a fuel economy gauge that would only calculate the actual mileage without the stops where the engine is only idling. I think it would give a better feel of the "driving" fuel economy. I previously owned a Chevy Lumina (an '05 Australian Holden) that when idling, would show fuel consumption rate in Liters/hour & while driving it switched to Liters/100km. Good idea instead of the useless 99L/100km (or 0 mpg for US) while idling.
  24. Edge Sport brakes are the same as regular Edges. Only in some years, don't remember which, some FWD Edges had smaller front brakes.
  25. For those with the Ambient Light reset problem, your dealer should be able to fix it: TSB 14-0175 MYFORD TOUCH/MYLINCOLN TOUCH - AMBIENT LIGHTING DEFAULTS TO WHITE OR ICE-BLUE AFTER CYCLING IGNITION SWITCH Publication Date: September 19, 2014 FORD: 2011-2014 Edge, Explorer 2013-2014 F-150, Flex, Fusion, Taurus LINCOLN: 2011-2014 MKX 2013-2014 MKS, MKT, MKZ ISSUE: Some 2011-2014 Edge, Explorer, MKX, 2013-2014 Fusion, Taurus, Explorer, Flex, F-150, MKZ, MKT and MKS vehicles equipped with MyFord Touch™/MyLincoln Touch™ and ambient lighting may exhibit the ambient lighting defaulting to white on Lincoln vehicles or ice-blue on Ford vehicles after cycling the ignition switch. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE 1.Determine the level of software in the accessory protocol interface module (APIM) by navigating to the system information screen on the 8 inch radio display. Select: a.Menu b.Help c.System Information 1.If the last five numeric digits (e.g. 4.30.13171.PRODUCT) are 13171, proceed to Step 2. 2.If the last five numeric digits are not 13171, this article does not apply. Refer to the Workshop Manual (WSM), Section 417-02 for normal diagnosis. 2.Perform SYNC module (APIM) custom programming. Refer to WSM , Section 415-00. a.When the scan tool displays the list of available software, make sure the software version DA5T-14D544-BD (V3.6) has a green check mark. Also select the ambient light settings restore EA5T-14D546-AMA. 1.If the system auto-selects several other applications, proceed with the applications auto-selected. b.Select continue and follow the on screen prompts. c.As the programming is being performed, several reboots may occur. d.Once the programming is completed, return the thumb drive to the scan tool to report software installation to the Ford online database. OPERATION DESCRIPTION TIME 140175A Perform Reprogramming Of The APIM Using The USB Flash Drive (Do Not Use With Any Other Labor Operations) 0.3 Hr. WARRANTY STATUS Eligible Under Provisions Of New Vehicle Limited Warranty Coverage. Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. DEALER CODING BASIC PART NO. CONDITION CODE 14D212 04 Source.
