Everything posted by omar302
For those with the Ambient Light reset problem, your dealer should be able to fix it: TSB 14-0175 MYFORD TOUCH/MYLINCOLN TOUCH - AMBIENT LIGHTING DEFAULTS TO WHITE OR ICE-BLUE AFTER CYCLING IGNITION SWITCH Publication Date: September 19, 2014 FORD: 2011-2014 Edge, Explorer 2013-2014 F-150, Flex, Fusion, Taurus LINCOLN: 2011-2014 MKX 2013-2014 MKS, MKT, MKZ ISSUE: Some 2011-2014 Edge, Explorer, MKX, 2013-2014 Fusion, Taurus, Explorer, Flex, F-150, MKZ, MKT and MKS vehicles equipped with MyFord Touch™/MyLincoln Touch™ and ambient lighting may exhibit the ambient lighting defaulting to white on Lincoln vehicles or ice-blue on Ford vehicles after cycling the ignition switch. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE 1.Determine the level of software in the accessory protocol interface module (APIM) by navigating to the system information screen on the 8 inch radio display. Select: a.Menu b.Help c.System Information 1.If the last five numeric digits (e.g. 4.30.13171.PRODUCT) are 13171, proceed to Step 2. 2.If the last five numeric digits are not 13171, this article does not apply. Refer to the Workshop Manual (WSM), Section 417-02 for normal diagnosis. 2.Perform SYNC module (APIM) custom programming. Refer to WSM , Section 415-00. a.When the scan tool displays the list of available software, make sure the software version DA5T-14D544-BD (V3.6) has a green check mark. Also select the ambient light settings restore EA5T-14D546-AMA. 1.If the system auto-selects several other applications, proceed with the applications auto-selected. b.Select continue and follow the on screen prompts. c.As the programming is being performed, several reboots may occur. d.Once the programming is completed, return the thumb drive to the scan tool to report software installation to the Ford online database. OPERATION DESCRIPTION TIME 140175A Perform Reprogramming Of The APIM Using The USB Flash Drive (Do Not Use With Any Other Labor Operations) 0.3 Hr. WARRANTY STATUS Eligible Under Provisions Of New Vehicle Limited Warranty Coverage. Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. DEALER CODING BASIC PART NO. CONDITION CODE 14D212 04 Source.
Ambient Lighting '14 Sport FWD
omar302 replied to FtrEdgeOwnr's topic in Interior, A.C., Heat, Interior Trim
There was an update (V3.7.11) released & pulled quickly in early September. So it seems that we might get any time now. Edit: Found out that there is a TSB & your dealer should be able to fix it without the aforementioned update. TSB 14-0175 MYFORD TOUCH/MYLINCOLN TOUCH - AMBIENT LIGHTING DEFAULTS TO WHITE OR ICE-BLUE AFTER CYCLING IGNITION SWITCH Publication Date: September 19, 2014 FORD: 2011-2014 Edge, Explorer 2013-2014 F-150, Flex, Fusion, Taurus LINCOLN: 2011-2014 MKX 2013-2014 MKS, MKT, MKZ ISSUE: Some 2011-2014 Edge, Explorer, MKX, 2013-2014 Fusion, Taurus, Explorer, Flex, F-150, MKZ, MKT and MKS vehicles equipped with MyFord Touch™/MyLincoln Touch™ and ambient lighting may exhibit the ambient lighting defaulting to white on Lincoln vehicles or ice-blue on Ford vehicles after cycling the ignition switch. ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE 1.Determine the level of software in the accessory protocol interface module (APIM) by navigating to the system information screen on the 8 inch radio display. Select: a.Menu b.Help c.System Information 1.If the last five numeric digits (e.g. 4.30.13171.PRODUCT) are 13171, proceed to Step 2. 2.If the last five numeric digits are not 13171, this article does not apply. Refer to the Workshop Manual (WSM), Section 417-02 for normal diagnosis. 2.Perform SYNC module (APIM) custom programming. Refer to WSM , Section 415-00. a.When the scan tool displays the list of available software, make sure the software version DA5T-14D544-BD (V3.6) has a green check mark. Also select the ambient light settings restore EA5T-14D546-AMA. 1.If the system auto-selects several other applications, proceed with the applications auto-selected. b.Select continue and follow the on screen prompts. c.As the programming is being performed, several reboots may occur. d.Once the programming is completed, return the thumb drive to the scan tool to report software installation to the Ford online database. OPERATION DESCRIPTION TIME 140175A Perform Reprogramming Of The APIM Using The USB Flash Drive (Do Not Use With Any Other Labor Operations) 0.3 Hr. WARRANTY STATUS Eligible Under Provisions Of New Vehicle Limited Warranty Coverage. Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. DEALER CODING BASIC PART NO. CONDITION CODE 14D212 04 Source. -
It is a MyFord Touch issue since the last update. The resets to the default blue (white for Lincolns). Hopefully a near future update would solve the problem. -
Don't know how that happened. Apparently, when posting from a mobile, mistakes are bound to happen. Edit: ok, now I understand how it happened, browsing YouTube on the phone's browser keeps the same website link, even when you are switching videos, the url at the top remains the same. The is the video I meant, it's for an Edge but similar to what you found:
Check this video, it is very simple. Also it's the same for the map lights with sunroof switches: http://m.youtube.com/watch?v=8Nys7PfssZ8
The compatibility list includes Lincoln models that offer only MyLincoln Touch (MFT), they also stated that it's coming next week, and since we are already waiting for 3.7 (or 3.7.11) MFT/MLT update, it might actually come next week. https://www.automatic.com/ford/
Is the Tow Package Necessary?
omar302 replied to RustyEdge's topic in Cargo, Hauling, Roof Racks & Towing
The Edge without the tow package is rated at 2000lbs. So there shouldn't be any problem towing 1000lbs. -
Taycon, you should your vehicle to a dealer when the screen is dead, try not to restart your vehicle so the screen remains off. The dealer should one of two ways to fix it, a complete reflash of the software, and if that fails, I think they should replace the APIM. The latest 3.6.2 version of the software does cause, normally, cause black screens. Your car getting them means a defect either in the software (reflash) or hardware (replacement), both covered under the 5 year extended warranty of the APIM.
Well since the 2015 Sport has 21" wheels instead of 22", I think it's a good sign of function before form.
Could you tell us what is included in the Titanium that is not available in the Sport?
@Magnetic Edge Is the Sport model listed as an SEL+added options (like previous models) or is it a Titanium+added options? Which is the higher trim level (other than the Engine of course).
My Ford Touch New Software Release
omar302 replied to tjbron's topic in Audio, Backup, Navigation & SYNC
You You can register with the page for USA & the download would still be for your vehicle (export). -
Yep, sorry, it is 365 hp, posting from the phone is a recipe for typos!
Actually it is 465 HP, Torques is the limiting factor with 350 lbs-ft. The F150 3.5 also had 365 HP but 420 lbs-ft. The 2015 Expedition has 370 HP & 420 lbs-ft while the Navigator has 380 HP & 460 lbs-ft.
The 2013 CTS had 2 Engine options, a 3.0 & 3.6 V6. So if it was an AWD 3.0L, then it would probably be much worse than an Edge Sport: 3.7 FWD Edge Sport, weight ~ 4200 lbs with 305hp/280lbs-ft (@ 6500/4000 RPM) 3.0 AWD 2013 CTS, weight ~ 4000 lbs with 270hp/223lbs-ft (@ very high 7000/5700 RPM)
The throttle body is not mentioned in the warranty guide under the extended warranty, so its probably not covered (the below is for a Lincoln, hence 6Y/70K): However, the Throttlebody is covered under the Emissions Defect warranty for 4Y/50K, though I don't know if its failure as a part is also considered an Emission Deffect:
2011 Ford Edge Wont start
omar302 replied to splork's topic in Alarms, Keyless Entry, Locks & Remote Start
Did you have a message in the left cluster screen to shift to Park? Try to put the shift lever in Neutral & try to start. -
Being nearly in the same position, the Edge / MKX do have short seatbelts. My old '08 Taurus was the same, seems to be a Ford thing as the Chevy Cruze we had & Nissan Altima we now have, both have considerably longer seatbelts, and I mean really much longer. As for a solution, you might try a seatbelt extender, there are also OEM Ford seatbelt extenders you should be ableto get at your dealer.
Wiring for Paddle Shifters - Sport & non-Sport
omar302 replied to omar302's topic in 2011 Edge & MKX
Yes, the Sport does not have the +/- button on the shift lever. Nor does the 2013 MKX that has Paddle shifters, you get either the shifter button or the paddles, but the wiring diagram doesn't seem to show it like that, my understanding of the diagram is that the wires for the shifter are the same for all Edges. -
Just need to spare some time to remove the bottom cover of the steering column & look at the wires. The heat is also not helping! -
Wiper blades?
omar302 replied to Bryan003's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I personally tried Trico Teflon SHIELD & am very happy with them. They are now ~ 1.5 years old & still working great, though here we have very HOT weather in summer & no snow in winter. TRICO 20260 (20-260) for the drivers sides, 26" long. TRICO 20200 (20-200) for the passenger side, 20" long. -
Also, it seems there is a weight difference in the 3.7 Engine cause both, the Sport & MKX are ~ 200lbs heavier than a 3.5 Edge (AWD vs. AWD & FWD vs. FWD).
Bluetooth won't stay connected
omar302 replied to trough57's topic in Audio, Backup, Navigation & SYNC
Did you try a Master Reset on the car? When the phone does not connect, did you try to turn off-on the Bluetooth on the phone or restart the phone? Does it then connect? If yes, did you try a hard reset (factory reset) of the phone?- 1 reply
- bluetooth
- connection
From your description, cold when moving & hot when stopped, it is most probably the engine cooling fan(s).
2011, 2012 & early build 2013 did not have an indicator for headlights on. It was added to later builds of 2013 models (and probably 2014). Refer to this thread: http://www.fordedgeforum.com/topic/12089-is-there-an-indicator-light-for-head-lights-on/ This is the base cluster with the indicator on: http://www.fordedgeforum.com/topic/12089-is-there-an-indicator-light-for-head-lights-on/?do=findComment&comment=92994 This is the dual screen cluster with the indicator: http://www.fordedgeforum.com/topic/12089-is-there-an-indicator-light-for-head-lights-on/?do=findComment&comment=92948
