I'm confused. You have HID headlights and want to replace with LED, or a different car with halogen?
The extended warranty on the door latch expired on July 10, 2020 (with <120,000 miles) for the 2011-2014 Edge. MC-10169994-0001(1)(1).pdf
Missing Cabin Air Filter Screws
enigma-2 replied to Correy's topic in Interior, A.C., Heat, Interior Trim
I was talking to a fellow on another forum and he said they ALL come without screws. The screw holes are provided for screws should the tabs on the side break off. He didn't know what the thread or size was however. -
May need to see your local Ford dealer. Not showing up on any parts site. -
Water leaking passenger side ford edge fan noise
enigma-2 replied to edgeguy08's topic in Interior, A.C., Heat, Interior Trim
Here's an updated link: Lubegard 96030 Kool-It Evaporator and Heater Foam Cleaner https://www.amazon.com/dp/B0007PHD0S/ref=cm_sw_r_apan_glt_fabc_TP9KVSKCAN83PRPYNXJ4?_encoding=UTF8&psc=1 -
Anytime you have water backed up in a warm, dark place, nasty things grow. I'd still recommend shooting some Lubegard (post above) into the vent, which leads into the a/c , heater housing. Better if you go up through the drain, but easier through the dash vent). If there is mold in there, your breathing it whenever your driving in the car. Cheap insurance. -
Adaptive headlights
enigma-2 replied to Itsdjellz's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
It's grayed out when the headlights are in the "auto" position. Is it still grayed out if they're in the "on" position or can you select "off"? -
This should fit your Edge, https://www.ebay.com/itm/NEW-2015-2020-Ford-Fusion-Edge-DRIVER-Side-Door-Handle-BEZEL-COVER-OEM-/233615592870?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=711-127632-2357-0
245/50-20". I'd consider the Perrilli Scorpio AS Plus 3. Around $210/tire.
He can't get warranty on the problem as he modified the wiring (grounded the green wire). As the wire is grounded, it must be broken further up. You should be able to pull a code from the body control module, which may or may not help. But I seriously doubt the PCM is responsible. Wire breaks usually occur where there is flexture involved. This is why I would suspect the wire breaking near the door hinge (could still be inside door). One possible fix is to parallel the green wire through the door to cowling area.
I think the purpose of this part is to apply upward pressure on the glass when closing and closed. They're described under the primary seal section of the service manual. They're described as "concertina blinds". P/N: FT4Z-78500A66 for the passenger side, FT4Z-78500A67 for the drivers side. Price is around $95 + shipping & tax. (This p/n covers Ford Edge/Lincoln MKX, for 2007-2014). I DON'T think they are responsible for keeping water out. (That's the job of the rubber seal that runs around the top between glass and frame). The procedure to change is; 1. Open the roof opening panel to the VENT position. 2. Detach to top of the concertina blind from the moving glass frame. 3. Open the roof opening panel to the OPEN position. 4. Detach the bottom of the concertina blind from guide track in the most forward position. 5. To install, reverse the removal procedure. (Return to living room, tell wife "phew, that was really a job". Have her get you a beer and see if there's a NFL pre-season game on).
- 1 reply
Losing brake fluid - ABS module ?
enigma-2 replied to Icewiley's topic in Brakes, Chassis & Suspension
Years and years and years ago I had this happen to me. The mechanic didn't tighten the bleed screw properly. -
FWIT General Motors announced that they are stopping all manufacturing of 2021 car due to lack of parts (chips mostly). Blamed it on COVID-19. Actually Ford just announced the same thing. "Until further notice ". https://www.cnbc.com/2021/04/08/gm-cutting-production-at-several-plants-due-to-chip-shortage.html Actually may be worth waiting as when the 2021's get chips next year, there will be a glut and you'll have your pick, perhaps at a good price inasmuch as they will be "last years model". !!!!
Did you check for corrosion on the fuel injector electrical connection?
Power liftgate intermittently doesn't open 100%
enigma-2 replied to ypodolyan's topic in Exterior & Body
The purpose of the motorized strut is to get the hatch to start the lift. The purpose of the struts are to push the hatch all the way open. If it's just balancing, I'd say the struts are starting to get weak. (No matter where you leave the hatch, the struts should take it from there to all the way open by themselves). If the hatch opens, say 75%, and you can manually lift it the remaining way, the struts are weak. Good struts will open the hatch 100% open. Weak struts will not. -
Manufacturer recommended change interval for the 2011 is 100k, but it can be done earlier. If you're considering doing the 100k at 90k, then definitely spark plugs, followed by transmission and coolant. (If you haven't already changed over coolant to new type, then definitely have it done.) Full inspection on hoses and belts. Probably the engine air filter as well. Not as critical but I changed brake and pwr steering fluids as well. (All fluids go bad over time.) Good time to check tire pressure on spare. (Usually overlooked and spare looses air just like any other tire. I checked mine couple of years ago and it was flat. Turned out the valve cracked and needed changing. Would have turned out to be a tow if I had a flat tire.) If your Edge is AWD, then change fluid in the PTU. (Very important, but not all dealers do this as its not part of Ford's recommended service. Dealers can pump out old fluid using same equipment they use for rear axle). One item often overlooked is the cabin air filter. This is a simple item for the owner to change (and often forgot about). If the shop does it, its usually a high markup item. The seat filters on the 11 are just screens and usually don't need checking, but doesn't hurt to pull them and check for dust bunnies or whatever.
2018 titanium Front Receiver
enigma-2 replied to Gardenman's topic in Cargo, Hauling, Roof Racks & Towing
Nothing shown for the 2018 edge. Why not a rear mount hitch or roof carrier? -
Read this thread: https://blueovalforums.com/forums/index.php?/topic/69236-20192020-ford-edge-horn/
Man that's expensive. $330? I looked on Amazon and this one sells for $43. https://www.amazon.com/dp/B093R3C3FJ/ref=cm_sw_r_cp_apa_glt_fabc_4HK9DFM45Z3PZSDR6CMZ
USB port sees the USB flash drive for 10 seconds
enigma-2 replied to BaZZaD's topic in Audio, Backup, Navigation & SYNC
At this point it sounds like the ports are the problem, either something entered the openings (beer, coke, etc. which is periodically shorting ) or dirt (which doesn't allow the usb drive to fully seat, becoming intermittent), or, the cable on the back of the hub is not quite seated fully. If the ports are clean and clear, I'd pull them and check the connection. Have the ports ever worked properly? Its also possible that the APIM is the cause, but if so it would throw codes. Easy enough to check, expensive to fix. -
Is your Sync updated to the latest version? Is your USB drive formatted to FAT32? How about exFat? How old is the druve? What you're describing is a somewhat common complaint across many platforms. Try master reset or reformatting the drive and reloading the music. -
Never seen anything like it. Looks like a great weekend getaway bedroom. Is the mattress confortable? Use sleeping bags?
I'd add, first things first. Change transmission fluid, coolant (to new green after flush), change plugs (if it hasn't already been done) and change PTU fluid. (These are important). Followed later by changing brake fluid, differential fluid, power steering fluid and don't forget to change the cabin air filter. Great buy! Should get many good years out of her. Named her yet?
