MLTEdge
Everything posted by MLTEdge
If the car won't function safely, ask for a loaner until fixed.
- 1 reply
3.5.3 just arrived.
I'll check, but pretty sure it is. Just got an update preparing for the Alexa upgrade. Is this what you are referring to?
Noticed I'm still on am older APIM Firmware. No issues, and looks like over the air updates don't address this (since I get them all). Question is, do I assume this is like computers and newer drivers for hardware (where some recommend if it isn't broken, don't update)? Should I go to Ford dealer and update or leave it alone since everything seems to work?
Voice guidance stopped workig
MLTEdge replied to MLTEdge's topic in Audio, Backup, Navigation & SYNC
Thanks. I disconnect battery overnight and working again. Strange. -
2021 ST. Use Google maps sometimes, but recently started using built in navigation. Voice guidance is on, toggled it between tone and voice. Reset APIM, still starts giving starting navigation drive safe message, then no more guidance commands. Anyone else? Car did just download an update telling me getting ready for Alexa update, but not sure if that's what killed it. Called Ford, they said can't help, take it for service. Stupid.
2007 edge with no crank no start no communication with pcm
MLTEdge replied to Brackin's topic in 2007 Edge & MKX
Have you looked for any bad codes? If none, just a guess, and pretty obvious, sounds electrical, since after a detailing, which could just be coincidental. If car has now completely dried out, and I mean everything outside, under hood, under car... And still not running, my first guess is not a short since water no longer acting like a conductor, but could still be. So I'd start simple with battery and terminals wire check, ground wire , then make sure all pins in the pcm connector are good, and making good connection. If still not good, and no crank, maybe look for a short in a harness or connector. Good luck, hopefully someone else will help out if they have a better solution. Electrical is a real pita in modern cars. May be best to get a diagnostic from a dealer if simple things don't find it. -
Yes, plugs, wires, fuel filter, injectors, gas, water in tank, tire pressure, compression loss, dragging brake, age, prior owner messing with vehicle or chip, kids syphoning, towing an elephant... Many things can cause poor mpg. Bad mpg can be difficult to nail down without a full vehicle diagnostic. Rarely is it something simple though unless only off by 1-2 mpg. On a funnier side.... My sister a few years ago bought a c class Mercedes. She took it to dealer 2 or three times over several weeks complaining the mpg was too good, or the gauge was broken. She'd never filled it and drove 900 miles . Turned out her husband was dumping extra gas for his generator in the car so he could store a fresh supply. A good laugh... For everyone but my sister.
Decent payload but I’d rather have a truck…
MLTEdge replied to 14AWD3.5's topic in Cargo, Hauling, Roof Racks & Towing
Funny. Use to have a 2000 Vette. The looks I got at home depot loading the hatch back were priceless. Even a few thumbs up. -
2017 Edge had to unplug battery to make is start
MLTEdge replied to Dutch 66's topic in 2017-2018 Edge & MKX
Not sure about your year model, but most newer vehicles have, and need the 'BMS" reset when replacing a battery. Basically it a small computer board or chip that monitors battery. Just take your car to an AutoZone or similar shop and they will check your current battery for free before you spend the money. If you buy a new one from them they should be able to determine if you have a BMS and if it needs resetting. -
Two things come to mind, if new battery, was a reset done? Second, if older battery, could be as simple as bad battery terminal connection such as loose or corrosion. possibly even loose wire. Removing connectors and retightening may have fixed it, but I'd consider pulling again, inspect wire ends, clean posts and terminals real good, and put back together. Besides baking soda or official battery cleaner, use a battery terminal/connector brush. Inexpensive and available most anywhere. -
Thanks for the reminder. I carry a DC portable pump for just such an emergency. Keep it next to the spare tire. Got in the habit since I use to carry one on my motorcycle. That pocket on the left over the wheel well, with the accessory plug under it holds my lithium battery backup/car jumper too, always plugged in for a full charge. Really love all the pockets and accessory plugs on this SUV. Oh, I also carry a rubber mallet for flat tire changing. Sometimes those lug nuts are on really tight. Interestingly I've used all these more to help stranded drivers.
Had to pick up over 20 bags of stone recently. Each bag was 50 lbs. Was just under GVWR with me inside. Handled it fine, but did drive slow home. Was harder on me loading and unloading then the Edge. If I did it a lot, I would want a midsize or small pickup. -
I also experienced this on my old Titanium. My bucking was at slightly higher speeds, 45 range. Dealer kept telling software issue, finally took to another dealer who confirmed TC and replaced along with a complete transmission rebuild since it took 49k miles to properly confirm. Transmission was burned up. I became proactive to fix since warranty was about up. Just like you found myself driving differently to avoid kick so I could live with it.
- 9 replies
- 2020
- transmission
(and 3 more)
Increase Tow Capacity 2008 Edge SEL
MLTEdge replied to Johnrg2's topic in Cargo, Hauling, Roof Racks & Towing
Ha! Good catch. So much for clicking on unread. -
How often does she tow? If not much you could rent a pick up for a day or too. Not all have a hitch or allow towing, so you'd have to check that. Otherwise, get an older pick up just for home depot, landscape, towing... You can even insure some of them at Hagerty as a third car collectable. We had a third car, Mini Cooper Coupe and put it with them and it was very inexpensive since they know you have daily drivers. -
Sales of Edges have been strong. Recent reports showing them outselling other brands, Mercedes, Toyota.... Part may be lower price, part may be simply more available, no way to know. Brand loyalty has been through the roof though. Even I came back after a lemon. It was one of the most comfortable suvs I ever owned or drove. While Ford admitted closing plant, they are introducing a new one in China, believe based on the Explorer platform. Rumors are now surfacing they may offer in other countries later, including US. Problem is, changing the size and platform makes it a different vehicle, and probably more in the price range of the explorers. Don't think it will be successful competing against the third row for slightly less. People like it the way it was designed, mostly its crossover size and on a car platform. Very solid performer all around.
Improve The Quality Of Your OEM Sub For $5
MLTEdge replied to gjb89's topic in Audio, Backup, Navigation & SYNC
My older Edge with the Sony system was terrible on all sound levels. My new one with the B & O is really pretty good. Even the bass. Jazz listener so I like it tighter, not boomy. If I turn it up too much it rattles things in the car. You guys must be rap fans ? -
The 2021 and 2022 ST are called 7 speeds. In reality they reprogrammed them to skip 2nd, as it was causing a shudder or poor shift. Solved tons of issues. So yes, its a 7 speed by nature, but actually has 8 gears in the tranny. 2021 Ford Edge ST Gains New 7-Speed Automatic Transmission (fordauthority.com)
MLTEdge replied to omar302's topic in Recalls, TSBs & Warranty
My old Titanium had a bad booster and I took it to dealer to fix. Didn't fail, but it would throw you through the windshield if you weren't super easy on the pedal. Dealer said not defective. I told him to replace anyway, not risking the life of anyone in the car, warranty or no warranty. They ordered part at my expense. After install service manager said there was a new part number Rev B, and they covered it since it corrected the issue. Don't risk lives over a part you know will fail, fix it and fight the company after if you must. Part and labor, back then, was less than tires.
