Everything posted by handfiler
2013 Ford Edge SEL AWD - AWD Not Working
handfiler replied to fknfrds's topic in All Wheel Drive (AWD)
Easy to find out; drain some of the diff fluid. I suspect you'll find metal mayhem. -
First he was vanquished, then he simply vanished.
Second from the bottom on the main page. Classifieds
The Ultimate 2.7TT Aftermarket Parts Thread!
handfiler replied to Special_K's topic in 2.7L EcoBoost
Is "JC Performance Development " a secret club? A web search turns up zilch. -
Those tires are rated for temperatures above 7 degrees celcius (45 F). They are down right dangerous at temperature below freezing.
The OP referred to it as a:
It's the original battery. No idea what the replacement cost is.
It's less than 5% over the rating so well within manufacturing tolerances. The Mustang battery as old as it is is only 5% under spec. I think it's fair to say that low usage, favourable climate conditions and a maintenance charger are key to it's longevity.
Just received it this morning from Amazon. It can test AGMF, AGMS, Conventional, Gel and Deep Cycle batteries. It also does starting and charging system tests. I tested it out on my Mustang which has the original 11+ year old battery rated at 590 CCA. It tested at 558 CCA (OK) Then I gave it a try on the Nautilus which has a 800 CCA rating. It tested at 839 CCA (OK). With 3 cars and a motorcycle I figured its a good investmet at $55. SOLAR Digital 12V Battery and System Tester
I installed the Redline strut kit on my Mustang in 2011. They're still working great.
$34 each at Autozone. $28 - $30 at most online Ford parts websites. I typically buy from my local Ford dealer. They always match the online pricing. The reviews for the Autozone struts were less than favourable.
handfiler replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
"We tested the 2021 Ford Mustang Mach-E GT Performance Edition, and it reached 60 mph in 3.7 seconds on its way to a 12.7-second quarter-mile at 101 mph. It was 1.2 seconds quicker to 60 mph and 0.9 second quicker through the quarter-mile than the standard Mustang Mach-E we tested, but the GT Performance recorded a lower trap speed. We noticed that the GT Performance started to severely limit power after about 80 mph, and was actually 2.1 seconds slower to reach 110 mph than a lesser Mach-E 4X." Mach-e 0-60 @ 1/4 Mile Times So basically unleash a bunch of current instantaneously and then dial it back down gradually. To make it feel fast in daily driving and maybe occasional 1/8 mile stuff. Quicker than my Nautilus, slower than my Mustang. Might be an option when I consolidate my vehicles down to one...................when I turn 80. -
Glad to hear they were able to locate one for you ?.
I'm in complete shock that such a major driveline component is obsolete after 7 years. WTF Ford?
May taxpayer dollars that go into financing the CBC depresses me.
Group 65 Battery in 2nd Gen Possible?
handfiler replied to omar302's topic in 2015+ Edge & MKX Generation II
Confirming that H7 is original equipment in the Nautilus. Battery tray and most everything else in the engine bay appears to be the same configuration as the Edge. -
Ford Active Noise Control
handfiler replied to niceonept's topic in Interior, A.C., Heat, Interior Trim
White Noise -
I'm not sure if it's normal but I hear it too under those same conditions. ?♂️ -
They didn't have room for the water pump, never mind a pair of snails. ?
Actually its the 2.7 that is turbocharged.
