fishx65
    24
Everything posted by fishx65
  1. Has anyone installed a set of Monroe OE Spectrums??? I'm thinkin that Ford probably uses the cheapest junk out there and almost any aftermarket strut will be way better then stock.
  2. If your Edge is in really good shape a Jasper or Motorcraft long block may be worth the cost. Michigan vehicles can get pretty rusty in 6 years so ya may wanna give it a good once-over before deciding. Just had some good friends put a Jasper in their 90,000 mile 2010 F150 for $6500.00 including labor. I think the motor cane with a 3 year warranty.
  3. That led lights up the gear selector in my 2011. I broke mine when I rewired the center console power point. Been thinking of getting back in there and trying to fix it.
  4. Mac, my 2011's front suspension is starting to knock a little while going over bumps. I already did the swaybar links. What usually goes first up front??? Just hit 90 Grand.
  5. Pretty much any decent aftermarket speaker you use will sound 10 times better then the cheap toys Ford used in the 2011 Edge. These Kickers look decent for the clearance price: http://www.bestbuy.com/site/kicker-ks-series-6-x-8-2-way-coaxial-car-speakers-with-polymer-cones-pair-black/6432048.p?skuId=6432048
  6. Some of those paintless ding repair guys do amazing work and most insurance companies are happy to wave deductibles if you go the paintless route. The guy I use charges $40.00 to $60.00 per ding.
  7. I keep a log and change my oil between 6-7 thousand these days. I don't miss the old 3000 mile days at all.
  8. Got the plugs and PCV changed today on my 2011. Went pretty smooth and took me about 2 1/2 Old Man hours. Plugs still looked pretty good at 90,000 and the gap was right at .065 on all of them. I did reuse the PCV Pipe thanks to Mac's video.
  9. I'm also in the market for new struts and shocks for my 11 SEL. I prefer a softer ride and have been satisfied with Monroe Sensatracs in the past but they are no longer making them. Maybe Monroe just changed the name to OE Spectrum?
  10. Not sure about leather but I consider the 2007-2014 Edge cloth seats some of the most comfortable out there. My 10 was a little softer then my 11. I'm sure body shape, age and injuries have a lot to do with how comfortable a seat feels to each driver. At the ripe old age of 52, I'm starting to like a car seat that makes me feel like I'm sitting on a Lazy Boy.
  11. Didn't see that vid Mac but it definitely answers my question!!!!:) Gonna do the plugs on my 2011 next weekend and now I'll be prepared to swap in a new PCV valve.
  12. Mac, just watched your video about assembling the PCV valve and tube for your 2011. Did you happen to try heat to separate the original tube and PCV so you could reuse the tube?????
  13. I'd stick with a good brand name for a BT head unit. I always preferred Alpine way back in my car audio days but I'm sure Pioneer, Sony, Kenwwod, Clarion and many others make solid head units these days. Crutchfield might be a good starting point.
  14. The 2010 and below Edge's give you a ton of easy aftermarket replacement radio options and most will have Bluetooth. Wish it was easy to slide a new head unit in my 2011.
  15. You would have to switch it manually. Mine is always set to line in because I'm either listening to music through my phone or on a voice call.
  16. If you're just looking to add Bluetooth for calls and music streaming there are some pretty good options that plug into the 3.5mm auxiliary port. I tried a bunch of them and finally settled on the Kinivo BTC-450 because of it's amazing call quality. Not sure if it's still made but E-bay is loaded with brand new ones. There's lot's of cheaper options if voice quality is not a concern.
  17. Just finished replacing the coolant in my 88,000 mile 2011. Hope it wasn't a mistake going with the Ford Specialty Green coolant which is what my 3.5 calls for. To kinda get back on topic, just had two good friends go through engine replacements on their 90,000 mile vehicles. One was a 2010 5.4 F150 and the other a 2010 Toyota Tundra. Cam Phazer locked up on the Ford and a crank bearing went Bye-Bye in the Yota. I've had really good luck with Fords over the last 38 years but ya never know when she's gonna buck-ya.
  18. Just got around to installing the front emblem my dealer gave me under warranty about two years ago. Took me about 15 minutes thanks to HRinkels short write-up. Pretty sad that Ford's "advertising" emblem was peeling after only two years.
  19. I agree. Ford's quality tends to go up and down every few years. I actually feel that the 11-14 Edges had better quality control then the 10- and 15+. The Lincolns seem a lot more consistent but, of course, ya gotta pay the premium.
  20. Man, most of you guys don't even need a subwoofer!!!!
  21. Wow!!! I'm guessing 17 or 18 years old and going to the Ford show with Mom.:)
  22. Get the Eco in your next Edge Mac and see if it can be done!!!!:) Isn't that only about a year and a half of driving for you??
  23. Mac, just watched your coolant change video and that's the way I've always done it. Did you do any research to make sure that Peak is cool to use?? Did you originally have the Ford Purple stuff in there???? Just talked to a mechanic friend of mine at a Ford dealership who said to use Ford Vc-10-a2 Specialty Green coolant.
