Could be unrelated but I thought I remembered reading about something similar on the site. See if this sounds simular to the problem your having. http://www.fordedgeforum.com/topic/3586-2007-edge-unexplained-stalling/
Beginning to wonder about a faulty fuel pump or some other part in the fuel system starving the car for fuel. Codes?
Check for corrosion on each of the sensor connectors.
- 1 reply
Glove compartment door
enigma-2 replied to edgemaster's topic in Interior, A.C., Heat, Interior Trim
I loozed at my 09 mkx and there doesn't appear to be any adjustment. I would suggest spraying the lock mechanism with silicon spray. The locking mechanism may be binding, not allowing the lock to fully engage. Alternatively you can buy a new latch ($20 ebay) or complete glove box off ebay ($50 ebay, used). -
I agree with Crutchfield being a good place to start. Good selection and good backup. Here's a link with 2009 Ford Edge selected. (Steering wheel control harness will run an extra $30). https://www.crutchfield.com/g_462550/Double-DIN-Car-Stereos.html?tp=72406#&avf=Y&nvpair=FFSize|Double-DIN&nvpair=AG_Radio_Features|FFHD_Radio_Tuner_Built@in&nvpair=AG_Radio_Features|YCRadio_Data_System&nvpair=AG_Steering_Wheel_Control_Compatible|FFAdapter_Required&nvpair=AG_Front_Panel|FFFace:Fixed
As the car was originally registered in a hot, humid climate, you should have had the air bag changed already. Ever ask the dealer why? One letter I got stated that these cars took priority and would get changed first.
Another possibly is a clogged catolitic converter.
IF your considering changing from one coolant type to another, you may be interested in the official Ford procedure for doing so. It's for 2007 through 2009 (my car) but should provide guidance as to Ford officially recommends as any mixing of different types will create a clogged cooling system. 2009 MKX Cooling System Corrosion.pdf
Attached is a chart showing what models/years came with what coolants: coolants.pdf
I thought the highest risk areas were down south in hot, humid climates?How would Connecticut qualify?
When you turn the key on your hot-soaked car, does the instrument cluster gauges respond, the warning indicators light? (Ignition switch controls them as well).
2012 Edge Lmtd possible brake problems
enigma-2 replied to jumpsteady's topic in Brakes, Chassis & Suspension
Possibly one of the pads warn past min. Even though they were checked, pads can break and you may be metal-to-metal. I would have it checked at local dealer asap. Ford website should have coupon for free brake inspection. -
My guess is they have already repaired those at the most risk and the rest of us are at low risk.
This is Lincoln's official stand on it: "Based on currently available technical data, the Lincoln Motor Company understands that the vehicles involved in the recent Takata recall are safe to drive while you are waiting for replacement parts. You should have the repair completed as soon as possible after you are notified that parts are available."
For $30/day you'll probably get a Mitsubishi Mirage or something similar.
Personally I would stay with Motorcraft as I really don't know if the others are better or not. But if you do change, even if it states it's compatible, I would still do a complete flush. Not all coolants play well together. Also if you change, consider labeling the coolant fill with the actual coolant being used. Memory fades over time.
$30 on Amazon (free prime shipping). https://www.amazon.com/dp/B000NUB132/ref=cm_sw_r_cp_apa_loikBbVH9MHWB My 09 MKX came with gold from the factory. Dealer told me they needed to change it when they discovered it in an oil change. Told me Ford had discovered that it didn't have sufficient protection to prevent rusting or corrosion, and they needed to use a special flush to remove every part of the gold when going to green.
My Kids Chose Japanese Competitors
enigma-2 replied to pintokid's topic in Competing Crossovers & Vehicles
Your right about the Highlander, it's one ugly car. -
After reading the Ford coverage again, I see that it was extended to five years from initial service date. So I imagine it did end in 2017. Even though you still have to pay, there is still one good point it makes. And that is to make certain you are running the latest update. As it's not currently working, I would imagine the dealer will need to do it. The Ford letter required the dealers to check the software (latest or reload) prior to going further.
Before you install the engine, I would recommend changing the water pump, guides, timing chain, spark plugs, PVC, and anything else you can think of prior to placing it in the engine bay. These engines are "good-used", not rebuilt. Who knows what parts are good now only to fail in 5k? And while it's out, how about the TSS & OSS in the transmission? Easy to get to now.
Hi Edward, this site has an article and pictures describing the spark plug seals and offer more info on their replacment. It's on a 2009 Ford Flex, but same 3.5L engine. https://www.fordflex.net/forums/viewtopic.php?t=7809
Try shifting the gear shift through all the gear positions, and then back to park. Just the see if you have the dreaded shifter not recognizing park position. I was thinking that it was the shifting into neutral that allowed the NSS to engage and not that pushing it backwards had anything to do with it.
Fweeeeeeettttt. Foul, you can only have ONE hate. Rules are rules.
If your certain that the Accessory Protocol Interface Module is at fault, I'd talk to your dealer first. There's an extended warranty on your year's Edge. https://ford.oemdtc.com/1745/12m02-warranty-extension-covering-accessory-protocol-interface-module-apim-software-and-hardware-2011-2014-ford-lincoln .
