enigma-2
    294
  1. Should just pull right off. Did you remove the oil filler cap first?
  2. Only the latest models have a drain plug. On earlier units (like mine), the only fluid is sucked out through the fill plug. A lot of dealers don't like this procedure & claim it's not a ford authorized process (it is actually, under the "special operating conditions" requirements at 60k miles). However most all reliable transmission shops will do the procedure. Insist on a quality lubricant (go Motorcraft if your not certain as to what's best).
  3. My Escort MAX2 has never failed me yet. Excellent distance and rejection. Warns as I approach a red-light camera location, air patrol area and speed camera. Uses the cloud to let me see what other Escort drivers are getting alarms on (within 30 miles). Tells me what frequency is triggering the alarm (some frequencies in the Ka band are false triggers such as car blind spot radars). Tells me the speed limit of thr street I'm travelling. Download firmware and database updates via the Internet. Connects via Bluetooth to my Android phone.
  4. Reese Towpower 7052500 2" - 1-1/4" Receiver Adapter (7" Long) https://www.amazon.com/dp/B00U1LIG90/ref=cm_sw_r_cp_apa_AfNbAbXM6JXNP
  5. There's an estimated 500,000 flood damaged cars, all of which could be sold on the open market under a salvage title. (Salvage title means the car costs more to repair than its worth). It's legal to sell a car with a salvage title if the seller discloses this before the sale. However it's not required for a private sale. Many of these cars may end up on Craigslist or a fly-by-night car lot. Carfax just opened a FREE FLOOD CHECK tool at www.carfax.com/flood To use it, you will need the car's VIN.
  6. Be darned, never knew that was there. BTW, where is this? Doesn't show up on the list of forums.
  7. Honk at the wrong person and get shot. Not to mention that's it's ILLEGAL IN ALL STATES. All states have a line in their vehicle laws and regulations that states a car horn can not emit an unreasonably loud or harsh sound. Not all of them have that exact wording, but they all make the same point. So why would you spend $500 on something that you can never use, and risk an expensive ticket if you ever did? Just to scare the shit out of a person riding a bicycle in your way? They have an equal right to use the road. Locally we have a lot of horse and buggies on our roads. About the speed of bicycles. They also have an equal right to the road. What your suggesting is just plain mean.
  8. Responded in the message you left in Alarm, ....
  9. enigma-2
    Block Heater
    I found this on the Web 2011-11-19_221938_11_edge_block_heater.pdf
  10. I remember that the service tech told me I had gold color coolant and they were suggesting going to green (think it was green). They said they had to drain, flush with water, then with a cleaner then flush with water again and finally a fill with the new coolant. Said they had to remove all traces of the old coolant. Something about the gold not offering adaquate protection due to corrosion. Mentioned water pump and heater core. This was around ~78k if I remember.
  11. If you follow OMAR302's video link above, you might also consider sanitizing the HVAC housing and kill any remaining mold. Lubegard 96030 Kool-It Evaporator and Heater Foam Cleaner works well: https://www.amazon.com/dp/B0007PHD0S/ref=cm_sw_r_cp_apa_kDKaAb1X536FN Youtube video on how to use:
  12. My dealer checked my coolant during one of the oil changes and recommended I change immediately. (2009 MKX, gold coolant). They will use the latest coolant whenever you do a change. I do a change more often than the maintenance (100k & 150k) schedule to protect the water pump.
  13. Others have reported this. Turns out its the spash/noise panel under the car. Sometimes the push fasteners fall out, brake or juse come loose. Crawl under and tap the panels until you find the loose one.
  14. Forgot to add the product I use on the filter to improve its efficiency. (Use it on my furnace filter as well). PuraClean Filter Spray https://www.amazon.com/dp/B0145I072I/ref=cm_sw_r_cp_apa_dtHaAbYFE7QR6
  15. Personally I would never consider reusing a filter. The fine pores will retain molds and pollens. I prefer using charcoal filters, regular filters take out the pollen and other small stuff that get through the exterior filter, the charcoal will help on some other pollutants like diesel exhaust, burning leaves (doesn't eliminate the odors, but everything helps as wife has ashma). I also use a filter enhancer to turn it into a low-micron filter. For puroses of comparison, you can buy Motorcraft filters for under $14 https://www.amazon.com/dp/B000LPTGAE/ref=cm_sw_r_cp_apa_zFlaAbR8V90E4 These are the filter I use: https://www.amazon.com/dp/B004A6NBO2/ref=cm_sw_r_cp_apa_-HlaAbHNM48M5
  16. This link describes how to program a 2017 MKX with a Linear opener. http://www.homelink.com/program/video
  17. Excellent how-to-do-it video. Liked the fact that your were able to get good camera angles and show everything. ?
  18. The correct replacment is a number HIR2 for Halagen bulbs & D3S for HID bulbs. Here's an excellent video from Mactfordedge on changing headlights.
  19. Sounds like you blew a strut. If you forcefully rock the car up and down does to continue to rock on? Have to do this on all four corners to be certain.
  20. Tell us WHEN this occurs, ei when your turning, accelerating or braking? Is it coming from the front or the rear? That being said, the most common cause of creaking noises in the suspension are sway bar bushings. With age and cold weather the rubber hardens and the sway bar tries to bind on the rubber. This will cause creaks, groans, squeaks, etc. You can fix this by lubricating the sway bar bushings with grease (synthetic) or by replacing them. If you choose the lube them you may have to so annually. Best to just replace. Try pushing down real hard on the top of each front fender and note if you can hear the noise. If you can, most likely it's the sway bar bushings. Other causes can be tie rod ends, control arm through bolt bushings , ball joint sockets, etc.
