Brake kit works great, but rear shock is leaking
enigma-2 replied to roots57's topic in Accessories & Modifications
Usually wheel size makes a difference. IE shocks for an 18" wheel are different from a 20", which are different from a 21". Aftermarket supply universal only. A compromise. -
Any Windshield Wiper Rec's?
enigma-2 replied to chefduane's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Not certain about other makes, but Tryco makes a line of direct replacment wipers. For my 09 MKX they carry 10 different types (or styles) each designed to fit a hook style connection; mostly without an adaptor. (They also make some that are universal, but I dont use them). However, the back blade is only a universal style. I've used mostly Tryco since I was discharged from the service over 40 years ago. Tried other brands and never found anything that worked better. NAPA carries them if your unable to find locally. I've also found them at Meyers. FYI http://www.tricoproducts.com/Drivers/InstallationVideos?TrVehicleMakeModelYearIdent=8693&TrProductIdent=19&TrArmTypeIdent=1 On my last replacment set, I had a bad blade on the drivers side (It jumped across the windshield creating a thumping, squeeking sound, and didn't clean propetly). Called Tryco and they sent me a new blade immediately. No questions asked, didn't have to supply a sales receipt. Great company to work with. . -
BosCH is excellent, I prefer Tryco. (Tryco is usually what the OEM manufacturers use. But NOT what you get at the dealer for replacment - which can be anything the dealer chooses to stock. Local dealer parts counter told this to me years ago, and verified by service maanger at a later date). To make your blades last, start with a super clean windshield: (I did this nearly a year ago and still beads water) And clean your blades whenever you refill the tank (take the sponge on the backside of the squeegee they provide at the pump and, wet as possible, run it across the length of the blade. To make blades last as long as possible (true of whatever brand you use) spray a coating od 303 Protectant on the blades 3-4 x year. The way blades fail is, the UV causes as chemical reaction in the rubber and they get hard. The Protectant will block the damage from UV. -
Standard stuff, I'd go with stainless steel. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F371459309174
Ur local wally world or hardware will have many varieties of self-adhesive bumpers.
See if this helps https://itstillruns.com/fix-window-falls-down-door-6167627.html
- 1 reply
- 2
The steel has to be completely clean, dry & bonded properly. Problems come from trapping moisture between the coating and the metal. Older coatings split and chip, allowing moisture to migrate between the coating and become trapped there. I had one of my cars undercoated professionally. They cleaned the bottom with steam, allowed to dry for couple of hours then the coating. Had to take it back every year for touchup. Still rusted in spots they could reach.
OM says it's a 590 (or 760 with 2.0L and start/stop).
Guess I'm a little confused. Does the car crank, but not fire, or do you get a no-crank condition?
Deleted. Dup
I would contact Weathertech. Your back sounds defective. Mine lays completely flat.
Best way to troubleshoot weak window wash spray?
enigma-2 replied to TheWilldog's topic in Exterior & Body
Had the same problem a few weeks ago. Here's a link to my write up as to how to fix. http://www.fordedgeforum.com/topic/23597-windshield-washer-nozzle/?fromsearch=1 . -
Restoring leadlight lens with professional results
enigma-2 replied to enigma-2's topic in Appearance - Detailing, Wash & Wax
Can't say, haven't used this product. This is specifically designed for headlights, requires UV to cure. Stuff I use, once/twice yr, only air drys and probably lasts only to first carwash. Don't feel like laying out $$ for a UV light, but this stuff can be cured in strong sunlight when temps are over 70°. Any refetences for using clearcoat on lens? Longevity, damage to polycarbonate over time, etc.? -
Requires special tools and a UV light to cure the sealant, but this looKs like the (one of) the best method to use. Lasts for three years, sane process as used oem. https://www.jbtoolsales.com/presta-137306-headlight-sealant/?gclid=CjwKCAiAtdDTBRArEiwAPT4y-7b4FyCGxLw_rbS3mU0XsRvEICgQc9A870SPwAMa4fJPBmWR4ce7HxoCN7EQAvD_BwE
Just noticed that there is a new OEM PTU for sale on Ebay for $700 (free shipping), in case there's anyone who's looking for one. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F181751271842
Nice, I sort of like the front end (still on the fence, guess it's soooo different). Don't care for the dirty, brown tires though. lol
Where to get struts for rear hatch....non electric hatch.
enigma-2 replied to RJG's topic in Exterior & Body
I would stay with Motorcraft for these parts. Others have reported problems with aftermarket. Ebay has lots to choose from, for example: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F272690460370 -
ABS, Traction Control, and Check Engine Lights
enigma-2 replied to whitedragon551's topic in 2009 Edge & MKX
You should pull the codes to see what the check engine light represents. That she's losing ABS and traction comtrol could be isolated to one or more sensor's triggered by speed. (These systems are very complex interconnected). -
There are dozens available on Ebay. If your looking fie OEM rubber (with the Edge logo), they normally sell for under a hundred for front and back, same for the cargo mat. (Used are considerably less.)Set of front & rear: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F261261960490 Cargo: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F181214913834 There are carpeted OEM mats as well (you didn't specify). Personally I prefer Weathertech due to their "deep dish" design that catches and holds winter slush.
13's are fairly solid cars, the biggest complaint is door ajar light (faulty latch switch). 2nd most reported problem is the shifter.
I'm attaching a copy of the 2015 For Towing Guide for your use. 2015 Ford Edge Towing.pdf
