enigma-2
    303
  1. Have you checked your tranny oil level? When was the last time you changed the transmission fluid?
  2. Seen a video on YouTube where a fellow taped a toothbrush to a stick and used it to reach down into the resovior and clean the two sensor elements at the bottom of the resovior.
  3. Yes, new unit, installed by Ford dealer, and under current extended powertrain warranty. (I verified this). As far service, they offered to replace the fluid for $150 (he was thinking that they had to drop it and pour out the lubricant), I objected and got them down to $80 per change.
  4. Mine as well, but his sensor may be coated and needs depth to get it to register (if it can register. Sensor elements may need to be cleaned or changed).
  5. I know that you need to nearly completely refill the washer bottle to turn off the light. Don't think there's a reset, supposed to reset automatically when you refil. Also you can damage the sensor by using Rain-X washer fluid (or any fluid that beads up on the windshield). These fluids coat the two sensor elements and the sensor thinks the tank is perpetually low. (Have to pull the sensor and clean the tabs with Dawn Dishwashing soap).
  6. Back in 2015 the service agent came to me during an oil change and told me they found the seal PTU was leaking. (Nothing on tbe garage floor, had no idea). I THOUGHT they said that they were going to replace the seal. Today however, we were looking over the car's service record (I was asking about replacing the fluid) and found they had actually replaced the PTU at 95k. As it was under the extended warranty, I never seen the bill. (That alone paid the cost of the warranty). Today they told me that they do not service the PTU (I remember them telling me at the time it would be just the seal and cost ~$400 with me paying the $100 deductible). So one more for extended warranties. The service agent also told me they did not recommend my scheduling a flush until it hits 30k miles. Said a waste of money as it's designed to go life (of original warranty). He said they use the differential machine to suck out the old fluid. (Lincoln extended warranty runs out in Dec 2020).
  7. My dealer told me they cannot do the programming as the car did not ship with it. There are other ways however; the easiest is a $150 programming module (don't have the reference in front of my right now). As for a camera, any good camera will work, plan on spending $80 for a metal case and glass lens with decent dpi.
  8. Could that be a mercury switch to trigger on a hood open event? Or perhaps the antenna? I don't know for certain, but perhaps the under hood switch only works with the engine start security system?
  9. I'm here at my local Lincoln dealer getting a piece of trim replaced, thought to ask the service manager about the difference between the AWD and the 4WD. He said the are the same (mostly), both have a PTU, but the only big difference is, the Intelligent 4WD has a switch to turn it off. It's mostly in software as to how it engages. The service rep spoke up and said he has an Escape and it can get a little "squirrelly" at times, not perfected yet.
  10. I read in Car and Driver that the 2017 Escape 4WD can send 100% of the torque to either the front or rear axles. An AWD system can't do that of course. Here's a link to the issue, http://www.caranddriver.com/reviews/refreshed-2017-ford-escape-first-drive-review
  11. http://www.dahlford.com/blog/4wd-vs-awd-model-comparison/
  12. We're down to a single 36 lb. cat. When he rides in the car (in a carrier) you would think we're sawing his leg off. We only take him to the vet, but it's a real fun trip.
  13. Most of the airbags are coming for other manufacturers. I expect mine to be replaced in late 2024 or early 2025. (snort).
  14. There IS a slight difference however. The 4WD uses the same systems as the AWD but is designed for more rugged terrain. https://www.buyfordnow.com/feature/awd-intelligent-all-wheel-drive?gnav=t2-footer-features
  15. This link from the Escape forum mau explain it better. http://www.fordescape.org/forum/engine-technical-discussion/7962-awd-4x4.html
  16. https://www.infotainment.com/collections/all/products/myford-touch-sync-2-to-sync-3-upgrade
  17. Possibly a malfunctioning injector. Head gasket would not be intermittent. Injector malfunction would run the cylinder cold, allowing oil to accumulate.
  18. Sorry to hear this. Once the battery freezes its shot. As to why, are you running short trips in super cold weather? If so, it's possible that the battery had never fully recharged during each trip. May have to use a battery charger to continue to restore the charge. If the car does have a hidden power draw, here's one way to find it. You will need to put a VOM (volt-ohm-milliamp) meter between the + cable and battery + post. (In series). Set the meter to amperes (before you make the connection) and take a reading. It should only read a hundred milliamps or less. If you are seeing a higher draw, you may have parasitic draw. To figure out where it's coming from, start by pulling one fuse at a time and check the meter to see if the draw has stopped. When you find the circuit, you will need to check the schemitic to see where the circuit runs to. Then start by disconnecting each connection, starting at the end of the circuit. This will tell you where the fault lies in the circuit. It could be a discrete device or a short (look at the conductor surface for shorts).
  19. https://secure.ford.co.uk/OwnerServices/Owners-Manual/
  20. My God man, did you this to poor Lulabelle? No wonder she gave out.
  21. .. make certain you have someone holding its rubber before you try this. Twisting nuts is not a game for amateurs.
  22. Hey Dave. Welcome. Man how I hate @$!/^&^×=% round-a-bouts. There's one in front of a local retirement center. Every once-in-a-while you see a car stuck up on the center berm where the driver couldn't figure out which exit to take, so they went straighr. (Bless their souls, I'll be there soon enough.) As to your question, I'm driving a 2009 Lincoln MKX and it's still in perfect condition. Now I drive sensible and do all the maintenance, but if you take care of your new "baby", it will last, and last and last. Just avoid driving near any retirement centers .... Cheers, and welcome to the group.
  23. I would try folding the seat and then slamming it back in the upright position. Also try resetting the reclining position (just in case the locking mechanism is not locked properly. (I hate squeeks as well).
  24. Was at the dealership yesterday, asked the service rep about having the fluid changed in the PTU. He told me they never do that. Told him I've had it done here twice now .... deer in the headlights look.
