Your headlights suck
enigma-2 replied to foghelmut's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
What brand/model bulbs were you replacing?. -
Had the same question on my last update. Dealer technician told me it's not just updating Sync, they are also updating other modules that require connection through their computer. These modules need to be updated prior to loading new Sync software.
Years and years ago, my uncle dug a pit about 4 ft deep, and dropped his transmission by squatting in this pit. For an engine I would imagine you would need to get down at least 6 ft. (But, yea, you "can" do it without a lift). Hook a portable engine lift to the engine, pull the fasteners, drop it into the pit, push the car back, pull to old engine out of the pit, drop the new engine into pit, push the car back and hoist the new engine into the engine bay. .
Aerospace sealant. Can verify that it makes windshield wiper blades last.
I haven't named my MKX, but have named my septic tank.
I use 303 on a lot of things, bUT never thought about using it to double, triple or quadruple tire life.
is it ptu unit build with drain plug or should we make our own hole.
enigma-2 replied to cephas's topic in Welcome Forum!
Only the latest models have a drain plug. On earlier units (like mine), the only fluid is sucked out through the fill plug. A lot of dealers don't like this procedure & claim it's not a ford authorized process (it is actually, under the "special operating conditions" requirements at 60k miles). However most all reliable transmission shops will do the procedure. Insist on a quality lubricant (go Motorcraft if your not certain as to what's best). -
Radar Detector installation - direct wire questions
enigma-2 replied to shumax's topic in Accessories & Modifications
My Escort MAX2 has never failed me yet. Excellent distance and rejection. Warns as I approach a red-light camera location, air patrol area and speed camera. Uses the cloud to let me see what other Escort drivers are getting alarms on (within 30 miles). Tells me what frequency is triggering the alarm (some frequencies in the Ka band are false triggers such as car blind spot radars). Tells me the speed limit of thr street I'm travelling. Download firmware and database updates via the Internet. Connects via Bluetooth to my Android phone. -
Upgrade from 1 1/4 to 2" Receiver
enigma-2 replied to pintokid's topic in Cargo, Hauling, Roof Racks & Towing
Reese Towpower 7052500 2" - 1-1/4" Receiver Adapter (7" Long) https://www.amazon.com/dp/B00U1LIG90/ref=cm_sw_r_cp_apa_AfNbAbXM6JXNP -
Mobile site is different.
There's an estimated 500,000 flood damaged cars, all of which could be sold on the open market under a salvage title. (Salvage title means the car costs more to repair than its worth). It's legal to sell a car with a salvage title if the seller discloses this before the sale. However it's not required for a private sale. Many of these cars may end up on Craigslist or a fly-by-night car lot. Carfax just opened a FREE FLOOD CHECK tool at www.carfax.com/flood To use it, you will need the car's VIN.
Be darned, never knew that was there. BTW, where is this? Doesn't show up on the list of forums.
Honk at the wrong person and get shot. Not to mention that's it's ILLEGAL IN ALL STATES. All states have a line in their vehicle laws and regulations that states a car horn can not emit an unreasonably loud or harsh sound. Not all of them have that exact wording, but they all make the same point. So why would you spend $500 on something that you can never use, and risk an expensive ticket if you ever did? Just to scare the shit out of a person riding a bicycle in your way? They have an equal right to use the road. Locally we have a lot of horse and buggies on our roads. About the speed of bicycles. They also have an equal right to the road. What your suggesting is just plain mean.
Responded in the message you left in Alarm, ....
I found this on the Web 2011-11-19_221938_11_edge_block_heater.pdf
I remember that the service tech told me I had gold color coolant and they were suggesting going to green (think it was green). They said they had to drain, flush with water, then with a cleaner then flush with water again and finally a fill with the new coolant. Said they had to remove all traces of the old coolant. Something about the gold not offering adaquate protection due to corrosion. Mentioned water pump and heater core. This was around ~78k if I remember.
Here's the video
Cabin air filter issue? Mildew smell occuring
enigma-2 replied to Ericalan350's topic in 2013 Edge & MKX
If you follow OMAR302's video link above, you might also consider sanitizing the HVAC housing and kill any remaining mold. Lubegard 96030 Kool-It Evaporator and Heater Foam Cleaner works well: https://www.amazon.com/dp/B0007PHD0S/ref=cm_sw_r_cp_apa_kDKaAb1X536FN Youtube video on how to use: -
My dealer checked my coolant during one of the oil changes and recommended I change immediately. (2009 MKX, gold coolant). They will use the latest coolant whenever you do a change. I do a change more often than the maintenance (100k & 150k) schedule to protect the water pump.
Rattle coming from the center of dashboard...
enigma-2 replied to WingNut's topic in Interior, A.C., Heat, Interior Trim
Others have reported this. Turns out its the spash/noise panel under the car. Sometimes the push fasteners fall out, brake or juse come loose. Crawl under and tap the panels until you find the loose one. -
Forgot to add the product I use on the filter to improve its efficiency. (Use it on my furnace filter as well). PuraClean Filter Spray https://www.amazon.com/dp/B0145I072I/ref=cm_sw_r_cp_apa_dtHaAbYFE7QR6
