Engine Cranks but don't start says Low oil pressure
enigma-2 replied to Looking for Help's topic in Mods & Tech
Ummm, reminds me of a set of twins back in high school that ..... -
Type and grade of engine oil change for 2011 Edge SEL FWD 3.5L
enigma-2 replied to Edgingage's topic in 2011 Edge & MKX
Gas brands will mix a cold water antifreeze in the gas for winter blends. The problems with gasline freeze ups comes from running a fall mix into winter months. The switch over occurs in anticipation of freezing weather, but often an early cold snap can catch the oil companies off guard and get fall gas (no antifreeze) in a winter situation, leading to freeze ups. A can of HEET is useful in late fall to dissipate free water. -
Try this. Go into the menus and turn OFF everything associated with the rear camera. Then touch the HOME button and put car in reverse. If tbe camera is now working, go back in and turn on all the camera controls (camera, lines, etc.)
After look at your refernces, I agree, it's actually a bait and switch. Here's an article on Ford's strut and spring assys. They call them "loaded" struts. Reading tbe article from August, they don't include the Edge or MKX yet. (Probably next year). http://www.moderntiredealer.com/product/724751/ford-has-new-line-of-motorcraft-loaded-struts
Google: $63.50 ea. https://autoplicity.com/3937454-motorcraft-ast913-strut-assembly
Several of us here in this forum are using a Solar BA-7 battery tester. Much more accurate than what the use at the dealership. Also tests the alternator & regulator to see if it's working properly. https://www.amazon.com/dp/B0015PI7A4/ref=cm_sw_r_cp_apa_yKV0zbEMGKJ2W
Nice. But What about the engine cover? lol
Not to steal the thread, but I seen an add in a magazine for Motorcraft quick struts (fully assembled strut assembly with new springs).
Have you tried turning them back on? > Menu > Vehicle > Rear View Camera The fixed guideline options are ON and OFF.
If your talking about the blowout around 13 minutes, notice he's putting the air tube all the way into the cylinder and then blowing it out. The air and any debris is being ejected out of the cylinder, not into it. Also notice that he did a blowout around 10 minutes while the plug was still in. I don't see any appreciable dirt being added into the cylinder after he removed the plug.
enigma-2 replied to ben senise's topic in Accessories & Modifications
This the one I use with my Android. ScanTool 426101 OBDLink MX Bluetooth: Professional OBD-II Scan Tool for Android & Windows https://www.amazon.com/dp/B006NZTZLQ/ref=cm_sw_r_cp_apa_GhTZzbR0P8B0F Can't modify the car's internal settings (need laptop for that), but you can monitor hundreds of values. -
Another route that one could follow in refilling a cooling system would be the use of a premixed coolant. Such as Peak Global Lifetime 50/50. Meets Ford ESE-M97B44-A and Ford WSS-M97B51-A1 standards and doesn't change OEM coolant color. The water used in the mix is deionized water, which is better than distilled and reverse osmosis water. Just pout it in and your done. Easy/peasy. No matter what's used, the warranties on the coolants always require a full drain and flush. I would also think that if a change in coolant is performed, the flush should also include a neutralizer as well. The problem with flushing a coolant system usually figuring out how to drain tbe entire system. The closed thermostat presents a formidable blockage in completely draining the engine. In the past I've used a Prestone flush kit where you install a garden hose tee connector in the 3/4" heater hose. It flushed the system using the garden hose by back-flushing the engine and heater core.
According to the owners manual the lines in the 2014 are fixed (pg 201, 202). You might be thinking of a later year.
Honestly no, probably have to pop the inside hatch cover. Perhaps someone who's done this will chime in.
N. Indiana, I just replaced a set of Bridgestone Dueler H/L 422 Ecopia's 245/50R20 with a new set. Very satisfied with them. Reasonably quiet even when well worn. Quiet, smooth, energy efficient. Definitely not cheap. Local dealer price matched to Tirerack.Com + got Ford rebate for credit AND Bridgestone rebate, and interest free for one year.
One other thing I would check is to check the camera connector for any corrosion, particularly around the ground wire pin. (Simple, no-cost option before laying out any $$$).
I have an existing extended warranty which is due to expire in October. Been working with two on-line dealers on obtaining a new extended warranty to cover for another 3 years. Just been informed that most (not all) warranties will be going up as of October 5th. No one seems to know how much, but last time the average for the Edge/MKX platform was ~$200. Ford has announced that none of the plans will be going down. Anyway I printed out the best offer (Lombard Ford) & took it to my local dealer. He shot me a price and then I sprung the on-line price on him. Instantly matched. And then he bettered it by offering a $0/deductible if I bring it to their service department for service (as I do anyway). Plan I'm going to go with is the $0/deductible ($100/deductible at other dealers), BASE CARE for 3 years/36,000 miles. (Thinking tranny sensors, water pump, PTU & axle seals and parts known to fail around this time/milage). Has car scheduled to inspection on Friday. Just FYI for anyone else sitting on the fence over whether to buy an extended warranty or not. In a few day it may cost $hundreds more. BTW, you can charge it to the Ford Credit Card and take a year to pay it off with no interest!!! (Can apply for a credit card right at the service desk).
1st genFord Edge/Lincoln MKX secret menus
enigma-2 replied to Viktor Breeden's topic in Accessories & Modifications
Good to know. In addition, you can run a test on the gen 1 EATC module by pressing the OFF and DEFROST buttons together, the within 2 seconds, press the AUTO button. The heat/cool display will show 4 bars indicating the test mode has been enetted and then any codes will be displayed. 88 88 indicates the test passed. When done, it's important to exit the test mode by pressing the DEFROST button or BLUE temp down button (others may work as well).- 2 replies
- engineering menu
- lincoln mkx secret menu
- (and 3 more)
Adding to above, I remember when the dealer changed the coolant in my car (they changed from one color to another, don't recall which), they told me they had to use a neutralizer after the drain and before they used the new fluid.
This Ford brochure coverin the AWD might clear things up ad to how it works. Emailing Ford's All-Wheel Drive 2009.pdf
Pictures - as soon as possible.
They found my seal leaking late last year, I optioned to just have new seals put in. 8k so far and no leaks. Believe if it starts leaking again, I'll have a new unit installed. (Current extended warranty expires in late October, taking it in Fri for inspection on new three-year extended warranty. I am expecting it to fail).
I would have to disagree, there are tens of millions of proud Americans all around us. All walks of life, all colors and both sexes. (Although I was just in Seattle and it appears that's there is a third one blossoming .... ahem). Anyway, I would be proud to shake your hand, one vet to another. I proudly served as a Marine and spent a lovely year in Vietnam Nam. Which branch did you serve in? See any action in Kuwait or Afghanistan?
Forget the exact URL, was years ago. Mobile One filter was best (most $$$), Motorcraft & Delco were 2nd best. If I find it again, I'll post it here. The stuff you put in your gas tank was probably HEET. Gasoline tends to separate allowing water the separate out (also comes from condensation). What HEET Does is to mix with the water and change it's specific gravity to that of gasoline, and allows the water to be drawn into the engine along with the gas. Water left in the tank will freeze at 32°F or 0°C. Getting the water out will prevent a tank or gas line from freezing up. If you car is factory equipped with block heater (thought Canadian units were) the connection location is in the owners nanual. (At least I think it is).
