enigma-2
    303
  1. Forgot to add the product I use on the filter to improve its efficiency. (Use it on my furnace filter as well). PuraClean Filter Spray https://www.amazon.com/dp/B0145I072I/ref=cm_sw_r_cp_apa_dtHaAbYFE7QR6
  2. Personally I would never consider reusing a filter. The fine pores will retain molds and pollens. I prefer using charcoal filters, regular filters take out the pollen and other small stuff that get through the exterior filter, the charcoal will help on some other pollutants like diesel exhaust, burning leaves (doesn't eliminate the odors, but everything helps as wife has ashma). I also use a filter enhancer to turn it into a low-micron filter. For puroses of comparison, you can buy Motorcraft filters for under $14 https://www.amazon.com/dp/B000LPTGAE/ref=cm_sw_r_cp_apa_zFlaAbR8V90E4 These are the filter I use: https://www.amazon.com/dp/B004A6NBO2/ref=cm_sw_r_cp_apa_-HlaAbHNM48M5
  3. This link describes how to program a 2017 MKX with a Linear opener. http://www.homelink.com/program/video
  4. Excellent how-to-do-it video. Liked the fact that your were able to get good camera angles and show everything. ?
  5. The correct replacment is a number HIR2 for Halagen bulbs & D3S for HID bulbs. Here's an excellent video from Mactfordedge on changing headlights.
  6. Sounds like you blew a strut. If you forcefully rock the car up and down does to continue to rock on? Have to do this on all four corners to be certain.
  7. Tell us WHEN this occurs, ei when your turning, accelerating or braking? Is it coming from the front or the rear? That being said, the most common cause of creaking noises in the suspension are sway bar bushings. With age and cold weather the rubber hardens and the sway bar tries to bind on the rubber. This will cause creaks, groans, squeaks, etc. You can fix this by lubricating the sway bar bushings with grease (synthetic) or by replacing them. If you choose the lube them you may have to so annually. Best to just replace. Try pushing down real hard on the top of each front fender and note if you can hear the noise. If you can, most likely it's the sway bar bushings. Other causes can be tie rod ends, control arm through bolt bushings , ball joint sockets, etc.
  8. Takes me ~1 minute to get mine out (09 MKX). My guess is they changed it deliberately so owners will take it back it to dealer for service (they really rip you off - $12 if you do it yourself, who knows what they would charge in your case).
  9. Try <$12. Motorcraft FP-65 Pollen Filter https://www.amazon.com/dp/B000LPTGAE/ref=cm_sw_r_cp_apa_A8w-zb8RT6H4D
  10. Believe that's what I said. The FMVSS applies only the manufacturers of motor vehicles, and state DOT laws apply to motorists, how the operate their cars, how and whit what they can modify, etc. All state DOT laws mirror the FMVSS as to what every car must meet as a minimum. In exceeding the Federal Standards, states have differing laws as to light flashing, colors, max luminosity, etc. For example, here in Indiana, the state code address neon underlighting (which is not addressed in the FMVSS). The state law limits the neon license plate lighting to white only, and the underside, all combinations of red, white, blue and amber are illegal. (Purple is a combination of red and blue). .
  11. The owners manual starts the lighting chapter by addressing condensation. "Condensation in the Exterior Front Lamps and Rear Lamps Exterior front lamps and rear lamps have vents to accommodate normal changes in air pressure." (This is on page 85 in the 2017 manual). They go.on to say "Examples of acceptable condensation are: The presence of a fine mist (no streaks, drip marks or large droplets). A fine mist covers less than 50% of the lens." Based on the pictures you uploaded, I would say your lenses don't exceed the Ford requirement for replacment. If the scratch goes deep enough to penetrate all the way through the plastic (no cat is going to scratch all the way through the plastic), you could reseal it with some clear fingernail polish or brush applied topcoat. Under normal conditions, warm, moist air enters the lens through the vent hole in the lens, and condenses in the cool night air. If you want to get ahead of this, you could get the water vapor out (hair dryer?) and close the vent with a piece of heavy, plastic sealing tape. .
  12. As the vehicle has been sitting overnight and cold, it seems to me that it's related to combustion cycle during the warm up mode. About the only thing that comes to mind during early warm up is a burning off in the catalytic converter. I would get it into the Dealership immediately as it's definitely not supposed to do this. May have to leave it overnight to pull the codes during a cold start.
  13. Actually they don't. The federal FMVSS applies only to vehicle manufactures; while state DOT laws (which mirror the FMVSS) govern the operation of your vehicle on public thoroughfares.
  14. This site might may selection easier. https://ikeyless.com/keys-and-remotes/Ford?gclid=Cj0KCQjwm9vPBRCQARIsABAIQYcv0azEbxDlkRGb9rZw2nUhfMCMMNsAaqsXIdvxlDELL0xnpzMh7LcaAtkNEALw_wcB&type=Keys
  15. Here's a manufacturer that offers a turn-key solution (for a price of course). At least you know that everything will work properly afterwards. https://www.infotainment.com/collections/all/products/myford-touch-sync-2-to-sync-3-upgrade Have you thought about how you're going to get updates, inasmuch as Ford will not supply them to you?
  16. Service manual requires the engine to be dropped out of the car for service. Do you have coolant in the engine oil?
  17. Philips 9005 VisionPlus Upgrade Headlight Bulb, 1 Pack https://www.amazon.com/dp/B00Y9VZLB4/ref=cm_sw_r_cp_apa_8-H9zbGKDZ1DM
  18. What I would recommend are the Philips VisionPlus headlights: https://www.amazon.com/dp/B00TNMMZ8Q/ref=cm_sw_r_cp_apa_got9zbWPW3BNW (These are what I use in my MKX, much better distance vision the standard Halagen's and better than Sylvania Silverstar's). I would not recommend the blue tone lights as you can't see as far (the blue coating on the bulb attenuates a lot of the light) and the blue alters your focus (blue focuses in a different plane than yellow, more glare for the driver). I've read that these are also equally good, but I've never used them: OSRAM - Night Breaker Halogen Bulbs (Germany). https://www.amazon.com/dp/B00G4L1V1Q/ref=cm_sw_r_cp_apa_Kwt9zb3CPA8V9
  19. Did they retrain the sensor's? Simple procedure, the walk around to each wheel with a handheld device and it trains (teaches) the receiver to recognize each sensor). If one or more is not trained you will get this alarm.
  20. Your battery has crystal buildup on the plates. It will continue to read good voltage until the end. Has voltage, but not the capacity. A new battery is the fix. --- Unrelated, CTEK wrote me back last night and told me that their charger's cannot demineralize a battery that has good (24+) voltage. My CTEK refused to start in level one (the desulphating phase). They suggested I hunt down a "local battery workshop" who may have "profesdional equipment" that can "revive" a battety. 《Snort》
  21. Like jmr061 said, you have to call Sirus and subscribe. Forget exact price, guessing around $24/year but could be off. They are the only ones who can turn it on.
  22. Yes. They have batteries in them, but should last more than five years. Do you have OEM wheels or aftermarket? Possible that someone put on aftermarket and cheaper out by not using sending units in each wheel.
  23. Most likely a slow phase-in over th he next 10-20 years. Makes sense, higher voltag means smaller conductor sizes, saves bookoo dollars.
  24. I would be more concerned as to why the fuse blew. It's under warranty, take it to the dealer, let them figure it out. No fuses listed for exterior lighting (other than headlights), so they may have switched to in line auto-reset circuit breakers. .
