I read that it has a class B rating on Gasoline and class A for certain oils and class C for other oils. For the class A oils, butter, castor oil, corn oil. For the class C oils, linseed & mineral oils. It seem exceptionally susceptible to cleaning solvents and certain acids. Petroleum oils were not listed as being tested. Class A for road salt. Class B - Resistant no indication that serviceability would be impaired. Variable resistance, depending on conditions of use. Class C - Unresistant, not recommended for service applications under any conditions. I'd say it was s good choice overall.
- 10 replies
2020 Titanium 20" aluminum wheels with Elite package corrosion
enigma-2 replied to katmus's topic in Wheels & Tires
Do you live near to coast? Salt air can be corrosive. -
camera Front Camera Full view not available error
enigma-2 replied to David1956's topic in Audio, Backup, Navigation & SYNC
Sounds like there's a trip to the service department in your future. Probably an easy fix. In the meantime, you always have the front sensors that start beeping at 28".- 2 replies
- parking
- front camera
Being plastic, how does this board hold up to gasoline and oil?
- 10 replies
?Looks great. Wonder what a "mechanic" will think when he goes to do an oil change? Hack, hack, hack. There. Now I have access. (Sigh). Really does look good however. What material did you use?
- 10 replies
2007-2015 Edge, MKX low brake pedal simple fix
enigma-2 replied to enigma-2's topic in Brakes, Chassis & Suspension
There's one simple test you can try to reset the ABS. Try backing up, say 15 mph and stomp on the brakes. This has to be done only in reverse. Really mash the pedal. You may have to do this 2 or 3 times. But there's a chance the module will reset if you can get the brakes to go into auto pulsate. -
Steering wheel will not turn in cold weather.
enigma-2 replied to Johnboy23's topic in Brakes, Chassis & Suspension
The first thing I would suspect is a weak vehicle battery. You need to test the battery's CCA capability. If the battery is getting weak, it loses capacity and voltage in the cold. After the car starts, the voltage comes up due to the alternator and the steering will begin working again. -
Radio now turns on by itself on every start
enigma-2 replied to Davidoo's topic in Audio, Backup, Navigation & SYNC
Hope you specified a Ford Approved windshield as Ford is denying warranty on several areas with aftermarket windshields. As far as radio, there was a guy on F150 forum that had several electrical problems after windshield replacment. Traced to water entry at bottom on glass, corroded electrical connectors in instrument consul. -
Parking brake limited function
enigma-2 replied to sjskowron's topic in Brakes, Chassis & Suspension
Probably wouldn't qualify as it's not a safety issue (I'm not aware of any FMVSS standard on parking brakes). Definitely a bad design however. Wonder if you complained directly to Ford, that they would offer some assistance (inasmuch as it's obviously a design failure). -
Sounds like a PTU. Check the PTU vent for puke. Think I read in a message here, instead of replacing the PTU (rebuilt units are cheaper than new, but the new Gen 1 replacments are modified to last longer), where someone removed the PTU and driveshaft. Essentially converting the car to FWD.
Headlight replacement
enigma-2 replied to edgemaster's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Only thing that comes to mind is new bulbs pull too much current for existing relay. I'd try substituting a different relay (that's rated to handle the current of the new bulbs), contacting the manufacturer for advice (have they had this happen before) or replacing the original bulbs to see if it fixes the problem. -
Rear Differential Assembly from 2011 fit a 2014 ?
enigma-2 replied to NNV's topic in Brakes, Chassis & Suspension
Would something like this work? https://www.rigidaxle.com/products/1981-2014-ford-8-8-10-bolt-ring-and-pinion-gear-set-w-master-bearing-kit -
Another item to consider, mpre so in older cars, but ... have your mechanic look at the hoses. If the hose swells when the brakes are applied, a lot of the force is being disappapated in the hose. On my car, had a similar issue. Finally took my car in and ordered new brakes, all around. 130k and back brakes still only 1/2 pads???? Pads, rotors, new fluid, master cylinder check, check hoses, abs for air and power brake vacuum unit. Rock solid brakes now. Turned out it was the back brakes seized on the pins. (Think that's what he found, there was several minor things found, but definitely back brakes was problem).
Sounds like a relay isn't getting the signal to drop out. Perhaps if you could post a schematic of what wiring you changed. We're assuming that everything worked properly before the modification. -
Fluttering Noise from Undercarriage and Dashboad Rattle
enigma-2 replied to CCMAYES72's topic in Brakes, Chassis & Suspension
"Pushnut" comes to mind. Should be able to find these (or something close) at Advanced Auto in their fastener display isle.- 91 replies
- dash noise
- dash rattle
(and 4 more)
Have you tried a manual open/close to test for binding? Havevyou tried lubing the hinges?
That's not good sign. You losing cooant? -
Need Help -- 2008 Limited Battery Drain Problem
enigma-2 replied to Peveto's topic in 2008 Edge & MKX
14.2 volts when running shows the charging system is working. Test battety voltage when the car is off (tests just the batterys voltage). Should be getting 12.2 to 12.6 volts. If it's less, assume the battery is not taking a charge. Could be a bad new battery. New batteries need a full charge to srart off. Freezing weather and a short drive home may not be sufficient to get an adequate charge. In really cold weather, batteries not charged will freeze and short the plates together. And it's been really cold in certain parts of the US last week. -
2020 Edge Se Remote Start Fob
enigma-2 replied to GT86's topic in Alarms, Keyless Entry, Locks & Remote Start
I was looking at the FordPass app. Did you see the info it collects and distributes? INFORMATION THAT'S SHARED: Precise location. Email address User ID User interactions Device ID "Other" stuff DATA THAT'S COLLECTED: Full name Email address User ID Address Phone number Sexual orientation ??????? And "other" stuff ????????? Health and fitness information Copies of your photos Files and docs, and Interactions of user with app. I *think* we've discovered who Big Brother really is! -
Must be something you hate about your car. That IS the object of this post after all. (Can't get off that easily). lol
What? I have it on my 2009! (Although it works a little differently). With mine, I simply kick my foot on the bottom of the cargo area and yell "Hey Linda, open the hatch". Pop's right open.
Could be cheaper ones, didn't really look very closely. But then again, isn't anything you really need. (Esp at those prices).
In addition to the directions Haz published, a guy in tbe explorer forem wrote about disconnecting the antenna and the exact procedure to do it (what panels to pry, etc. Now tbis is for the explorer but could be similar. Might be useful. https://www.explorerst.org/threads/tailgate-disabling-the-kick-to-open-or-close-motion-feature-full-pictures.1938/
Yes. But you'll need a resistor to prevent what's known as hyper-flashing. Your current bulbs are 3137NAK. These bulbs are CANBUS compatible and should work fine (there are others, you may wish to shop around). https://a.co/d/5QPylyk
