Keep in mind that aluminum is magnetic field permeable. This can be seen in many Android phones which incorporate aluminum case backs. Charges right through the aluminum. Probably better off just disconnecting the pad.
Little confusing. Is it the socket on the radio or the plug on the end of the cable that buggered up? A better picture (close up) of the actual damage might be if help. You need to accept that neither are easy to find as a repair item. You will probably need to make a jury-rigged connection to remake the connection. Or send the radio into a repair service. I doubt these sockets are readily available to the public. If it's the plug end, you'll probably have to get a partial cable (a cut off) from a junk yard and splice it onto your existing cable assy.
- 4 replies
- wiring
- electronics
(and 2 more)
On my Samsung Galaxy, I can turn off wireless charging. I'd imagine IPhone has same setting. Settings>Device Care>Battery>Charging>(uncheck) Fast Wireless Charging. Then put phone on pad and see if phone is ignored.
The Mandatory In-Car Breathalyzer Is Only a Few Years Away
enigma-2 replied to macbwt's topic in Multimedia
I doubt that auto manufacturers will adopt breath detectors. Most likely they'll use touch-based systems. Manufacturers claim they can be ready by 2025. It reads drivers' blood alcohol level below the skin surface using touch sensors in the car's ignition button or gear shifter. The sensor shines a beam of light onto a person's finger and uses near-infrared tissue spectroscopy to take measurements. I have mixed feelings about these. The more complex a car gets, the more prone to failure. But In reality, drunk driving kills ~32 people per day in the U.S (that's one person every 45 minutes and more than 10,000 per year). Most automobile accidents are alcohol and drug related. -
Tried wireless charging with my Samsung and never liked it. Takes too long. I always use a cable plugged into the power poinnt whenever I'm using Escort Live (displays a map of my location and shows where cops running radar and laser are located) or when I have cable TV or YouTube playing. Wireless charging would never keep up with these apps. The wireless pad is just a set of coils projecting a magnetic field. Anything that spaces to phone above this field would stop magnetic coupling. Or a piece of metal would shield the phone.
Gets worst when accelerating and bad at 60. Most common cause is worn tires, wheels out of balance or bent. If tires may get better when doing 70 or 80 mph. As you've changed cv axles, tires and struts, so those good. Also possibly is worn wheel bearing. Lift car off wheels, spin tires and listen at bearing area with stethoscope. (Back in the day we used a long, wood handled screwdriver. Ear to wood handle, blade on car part being listened to. Length amplifies sound so 18"-24"). While front end off ground, shake wheels top and bottom to test ball joints, side-to-side to check tie rod ends and steering links.
I used to work with an automotive engineer. He told me the tire manufacturers run a spin balance on all tires at the end of production. The best are sent to OEM because they require less lead to balance. Anything out speck by a 1/2 oz or more went to aftermarket. There's no way to purchase tires intended for OEM as their under contract to deliver. I suppose if the tire mfgr had met their quota, you might get an OEM quality tire. No difference other than balance.
2017 Edge - Pirelli Scorpion STR All Season
enigma-2 replied to edge2017_513's topic in Wheels & Tires
8 ratings with 1 review on Amazon. All ratings were 5 out of 5 stars. Problem with TireRack and Amazon ratings are ratings were done when the tires were new. I prefer reviews on tires with 5k on them. Not possible on new models however. Pirelli has a good reputation. I run Scorpions on both my cars. No complaints with several thousand miles each. -
Windshield Replacement
enigma-2 replied to 1004ron's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
They honoring the warranty? -
My manual recommends placing the liftgate in manual mode, then it can be manually opened or closed. I have closed it manually whole still in auto mode, without problems.
Lots of YouTube videos on repairing dents. Methods, materials, fillers, etc.
Inasmuch as this showed up after a transmission fluid change, one thing that comes to mind is a low transmission fluid level. Low fluid causes a feeling that the car is in neutral, as there's insufficient fluid to drive the vehicle under certain road conditions. Then corrects when fluid replenishes. Easy enough to check (and correct if found).
check engine Check Engine Light w/ABS or Traction Ctrl
enigma-2 replied to Sunnyorlando's topic in Brakes, Chassis & Suspension
Transmission speed sensor or harness, is about the only thing that I can think of that would be common to both systems. -
number pad on door - can it be added?
enigma-2 replied to Bravo19's topic in Alarms, Keyless Entry, Locks & Remote Start
Just use your cell phone. Not as convenient but who doesn't always have a cell on them? -
There are options to do this, but all of them are aftermarket. Here's an example of one company that offers it: https://www.bestcaraudio.com/can-i-add-keyless-entry-to-my-car/#:~:text=Your local mobile enhancement retailer,integrated with a remote system. -
Well they replaced the passenger seat bottom TED unit. Wife used the cooling function this weekend. Stayed on 30 seconds and shut off. No heat, no cool. Same thing I took it for last week. Called 1st thing Tuesday morning and got it in Wed. They were able to work it in today and found the passenger seatback TED has failed. Another $800 (but still covered by extended warranty). Parts will be in next week. (Ya gotta love technology). At least it's gonna get fixed and that's the only thing wrong with the car. Need to get it detailed this year. Overdo for a good clay bar and polishing. -
Makes ya wonder what's lurking 'inside' da car. ? ? daaa ? da ? dum ? dum -
13,000 lbs. That hurts just thinking about it. -
USB played in a shuffle mode?
enigma-2 replied to Chipster's topic in Audio, Backup, Navigation & SYNC
Can't say if it's the same for Sync 3, on Sync 1 with usb connected: press sync, say "user device" then say "shuffle". -
Took my 09 mkx in to dealer on Wednesday, for a no-heat/cool on passenger seat. Mechanic found the TED unit failed. Around $850. Covered by PremiumCare, no cost. On Thursday they replaced the TED, pumped out the refrigerant, replaced all three Schrader valves, put in dye and refilled. No cost, covered by PremiumCare. Had them do a full 172 point inspection. Requires a special diagnostic technician. (Same inspection they do for Ford Certified used cars). $150. Checked everything and found all kinds of problems. Had to order parts so kept car overnight. (Told them to find everything thar needs repair, wanted to have everything repaired before my PremiumCare runs out in June). Friday, changed transmission fluid, $194, drained coolant, full flush with cleaner and flush with distilled water and refill with coolant. $190. (Mostly labor). Replaced power steering hose, and some other p/s parts. No charge. Replace left and right tie rod ends. No charge. Car hand washed and sent back to re-clean interior (WeatherTech floor mats weren't cleaned completely). No charge. Car drives like new. No thump-thump when I drive over rough pavement. Nice and quiet, smooth, tight. Passenger seat heats quickly and can hear seat fan running again. A/C ice cold. Think they told me they put a little over $2800 on the warranty. (Already had the PTU replaced under warranty, was hoping the water pump wound need replacing under warranty before it ran out). Only thing I forgot was to have a PTU drain and fill, but haven't put 30k on new unit yet, so should be ok. Car has 132k miles. -
PremiumCARE ESP, Heated Steering Wheel Covered?
enigma-2 replied to Odrapnew's topic in Recalls, TSBs & Warranty
Not listed, but It's covered. (Not exempted). I've used my premiumcare for things like seat lumbar replacment (both seats). Not listed but still covered. In-fact I just used it this week and they told me that the bill was just over $2800.
