enigma-2
    294
  1. Print out the internet offer and have your local dealer match it. Then tell him you'll sign if he will give you $0 deductible if you agree to have all your service done there ($100 is done at any other Ford dealer). I used the inspection they did at a The Works oil change to qualify on the latest warranty.
  2. I paid $100 on my MKX for an inspection (a few years ago). Worth every penny. You could also consider purchasing an extended warranty inasmuch as your getting a full Ford inspection. (Can purchase the warranty online, or print out a quote and take to dealer to match. Also ask for waver of $100 deductible if all service done at this dealer).
  3. Car following but 1/4 mile off after power disconnect. First try a radio reset. Disconnect all fuses powering radio (3-sync, 28-radio, 39-radio, 41-delay). Or pull cable from battery and wait a few minutes. If radio still doesn't reset, try master reset. (Thru radio menu). One or the other shoud force nav to reset inner time and correct (think inner clock is off, interpreting satellite info wrong). If this fixes nav error and it goes bad again, possibly a apim going bad.
  4. Was tow harness connected when the OEM headlight fuse blew? (Assume it was for high beams). If yes, I'd then suspect its finding ground through the tow connection wiring. If no, I'd suspect for bad ground wire/connection to headlights.
  5. CF5V. If it were me, I'd contact technical support at Forgestar and talk it over with them. Dont forget to ask about alignment and AdvanceTrec problems when you alter the offset. techhelp@forgestar.com or 800-788-9353.
  6. Before you head to the dealer, check to see if Sync is working (ties into tbe sound system of the APM). If Sync is out, check the APIM fuse.
  7. Thinking about this, I can only imagine one point where both circuits are in common. In the turn signal switch. It's there where you trigger the brights AND the turn signals (coupled to the tow lights). (Just a thought, could be wrong).
  8. Ford coolant doesnt evaporate quickly. My 09 mkx doesn’t use any to speak of between oil changes. (3.5 Cyclone). Hope your dealer found the problem, my initial guess would center in on the water pump failing (if outer seal is leaking, its dumping coolant overboard through weap holes. If inner seal leaks, it dumps coolant into oil pan. They can test for water in oil to confirm). Could also be a hose leaking or head gasket. Coolant in oil will turn the oil a tanish cream color. Read this as well. https://fordauthority.com/2020/12/new-lawsuit-targets-ford-ecoboost-four-cylinder-coolant-leaks/
  9. Battery condition, CCA test reading? If CCA reading below 50% battery is bad. Tightness of battery connections? Corrosion? Battery light indicates battery not charging. Did they check the condition of the belt? Tensioner good? How is it they replaced the alternator but didn't find the problem? Not much of a mechanic.
  10. May not be an answer, but I remember reading in another forum where a related problem was traced to "profiles". He found if he deleted his profile, then made his setting selections as a guest, then reset his profile, they stuck. Seems that whatever you have once you create a profile, gets "stuck" into memory.
  11. Motorcraft are rated at 100k miles. Can't go wrong with OEM.
  12. Looks like a 5 or 6 mm box or open end wrench can undo it. (Or use a small, 5" adjustable wrench). How about unhooking the pipe support strap and pushing the pipe out of the way?
  13. Which phone, which model, carrier? Latest phone software update? (Jan 27, 2022). Sync up to date? Try clearing the cache on your phones android connection app. (Settings -> apps -> storage -> clear cache). Try to reverse pair your phone with the car. https://www.ford.com/support/how-tos/sync/sync-with-myford-touch/how-do-i-reverse-pair-a-phone-with-sync-with-myford-touch/
  14. It appears that no one really knows the difference (other ford forums as well). Looking at a Ford level 3 horn, it "appears" that it may be dual horns in a single housing. (Two separate horns feeding into a single output). In a level 2 horn, each is replacable. But in a level 3 horn, if either fails, the assy must be replaced. It "appears" that a level 3 assy can replace dual level two horns (same size wire and relay rating).
  15. You said the dealer found the issue to be the oil pump. Your 2021 is still under warranty and Ford will repair. Let them fix it and see if there are any other problems after the repair. These engine certified technicians know what they're doing, what to look for and how to repair. If its a known problem, they know what to do. (P.S. the fun wasn't being directed towards you. Just having some fun to keep things light).
  16. What exactly is it doing? Have you tested for codes? If it's the radio, put it in tbe test mode and check the codes. (To enter test mode, put the radio in AM or FM, press the "right seek" and "eject" buttons at the same time. Hold until it recognizes the request then let go. The radio will go into the speaker all around text. It's loud so be prepared for it. Press "end test" and the radio will go into a mode allowing you to select which test to run on the acu and apim. Exit digonistics will show you what was found.) One other thing to suspect is your battery. Low voltage can cause all kinds of problems. Its not enough to just run a voltage test and say its ok. You must test the battery Cold Cranking Amperes capacity test (CCA). You need a battery that's strong enough to withstand starting without the voltage drop to a too low level. Any battety that tests below 50% of original CCA rating should be replaced. (Even if it still can start the car.) Reason is, the voltage drops too low to support the logic modules and they act like a computer that gets hit by a line spike. Also check for loose or corroded battery terminals.
  17. Ahhhh, you don't work for Frontier Airlines, do you?
  18. Stang is not close to Edge or Nautilus Never really liked it because wheelbase too short and too difficult to see behind when driving. (Last one I drove was the convertible and years ago, but left impression. Ended up buying the Sebring convertible instead). Wondering about the 3rd gen Edge & what changes gor 2023. So far no determination has been made, but still .... Article; https://fordtrend.com/2023-ford-edge/?amp
  19. NHTSA Campaign Number: 22T002000 Manufacturer Bridgestone Americas Tire Operations Components TIRES Potential Number of Units Affected 10,380 Summary. Bridgestone Americas Tire Operations (Bridgestone) is recalling certain Firestone Transforce HT, size LT275/70R18 with DOT code VN15TH71821and Transforce AT, size LT275/70R18 with DOT code VN15TR91821. The tires were manufactured with an incorrect inner liner compound, which could cause increased inner liner permeability or cracking, resulting in belt separation. Belt separation could lead to loss of vehicle control, increasing the risk of a crash. Bridgestone will notify owners and replace the affected tires with a comparable Bridgestone or Firestone brand tire, free of charge. Owner notification letters are expected to be mailed April 1, 2022. Owners may contact Bridgestone customer service at 1-800-847-3272.
  20. You could try going to the Motorcraft website, enter your VIN and download the "as built" data file from there. https://www.motorcraftservice.com/AsBuilt Or you could have your local dealer do it.
  21. What did they find?
  22. The rise of a new Frankenedge. Could always call er the "edgenator"? ... Groan
