enigma-2
    303
  1. This is a part thst rarely fails. How did you reach the conclusion that its failing? (Curious as to what to look for).
  2. Dealer can do thi$$$. Which version of Sync did you upgrade from and to? (Would determine which version of Sync files you're looking for).
  3. Couple of thoughts on this. As your FM is runnimg below the FM quieting level, the reception via the antenna is suspect. This is particularly true if your also experiencing poor reception on the AM band (AM is weaker and more directly influenced by a bad antenna). How's your AM reception ? The second possibly is your vehicle battery is going bad (low voltage). (Some radio's are sensitive to input voltage).
  4. It's part of the fuel pump. (I think, I don't think there's a 2nd one). This video may help. (Did you do the test?)
  5. I believe its actually kerosene. (Only it smells better .. smile). But covering is definitely faster and easier. ?
  6. Many codes are stored and can be read later. Perhaps Auto Zone? If it is the EPV I'd expect to see codes like P0446 or P0455 stored and the most likely condition would be a rough idle or rough running right after you fill up with gas. Probably get a check engine light as well. (Still, I really don't know if it could cause a no start on first try or not. Doesn't seem like it, but ..). Honestly I still suspect that its fuel related. Perhaps a bad check valve allowing the fuel to drain back. After the first try the fuel rail is pressurized and starts on the 2nd try. One way to test this theory is to turn the ignition "on" but not start. Leave it this way for a few seconds (to allow the pump to pressurize the line) then turn to start. If it starts, I'd zero in on a check valve (but it's not the only possible possibility).
  7. Sorry, the video was entitled "how to remove stickers from cloth visors". Thought it would work. (He used 81% alcohol, I wonder how Goo Gone would work)? I've never even noticed the labels on mine. Can't even tell you what they say, but then again my interior is Camel. (Blends).
  8. Doubt it's the filter (internal to the tank). You need to pull the codes and see what's stored. Often can do this at a local auto parts store, O'Reilly, Auto Zone, etc.
  9. Ummmm, as I remember it, the color was closer to adamantium.
  10. Could be so many things. The best start is to check for stored codes. Based on age, I would suspect either the fuel pump or its relay. When you first turn the key (run, not start) do you hear the fuel pump running? If yes, check valve may be leaking and fuel prime lost. If no, turn off and on again. Running now?
  11. Righr. And while you're at it, eliminate the owners manual and let them figure out Sync on their own. (Doesn't it bring a smile just thinking about a blonde trying to turn on the wipers without a manual)?
  12. Ahhhh, I may have reached an embroidered conclusion. Perhaps "wise, experienced, strong and leaky" would better describe our circumstance. (I hated Warfarin when I was on it. Cuts were fun ...)
  13. (I know it's old, just seen it and thought I'd respond in case someone else mistook its meaning). "Convoy" is a transport company. They hull for GM, Volvo and Ford. The car was transported on a carrier.
  14. You know what they say about guys who answer their own postings, don't you? Edit: their smart, great looking, manily and hung.
  15. OK. No front plate. Pinstripping instead! DFO.
  16. Heh. Amazon.com: Skeleton Hand Fender Ornament: Handmade
  17. Don't like the sound of your exhaust. Change it by using electronic exhaust.. How about a jet aircraft, or Jingle Bells or (ohhhh yeaaaa) a Corvette C7? Or others, selectable by your cell phones. THOR - electronic exhaust (thor-tuning.com)
  18. What's amazing is that we cannot longer make the F1 (Saturn V) engines today. (In fairness they can build better engines today, but the the technology used in the 1950's has been mostly lost). https://ourplnt.com/remake-rocketdyne-f-1-engine-humans-moon/ When i was a early teen, me a two of my friends were walking down an alley. I noticed a box sticking out of a trash barrel and looked in as we passed. There were some strange pieces inside, so we stopped and pulked them out. They were advanced, carefully machined and had a wierd coating. So being curious kids, we took them. Played with them, burned them (an acetylene torch didn’t affect them). We passed them out to the neighbors. The neighbor across the alley worked at Bendex Corp and took one into work and asked if anyone knew what it was. His supervisor called the plant in a neighboring city that built classified missile parts and described it. Within an hour the FBI was at the plant interviewing my neighbor. Of course he told them that "I" was passing highly classified missile parts around the neighborhood. Anddddd they showed up at the house an hour after that. Turns out it was the most classified part of the Talos Missile. The missile used several of these at the front as the antenna. It's exposed the extremely high heat during flight and has to continue to broadcast all the way to its target. Of course I told them everything including showing them which house where we found them. Turns out he was an employee of the Bendix facility where these parts were being made. The agent said they would "take him at work" as it was still during working hours. Never seen anything in the newspaper. Point of all this, (think it around 1959) I've never seen anything published on what this material was or how it worked. It's really amazing just how advanced we were back in the 50's.
  19. Its possible to "over-condition" leather and cause stickness. (Also, parts of the seat is leather, and other parts are "synthetic" leather. Plastic. Before you proceed, read the site and see if helps. (If you do go with a cover, be observant where it seams fall on the backside. The seams will rub against the seat and cause abrasion). https://leathermilk.com/tacky-leather-conditioned-leather
  20. It's been that way since sync-1. I never seen this as a being a problem.
  21. Did you remove the plate holder or just black it out? (Looks like its still there.)
