I remember reading that new tires will sway at high speeds, until they break in. In a towing situation, others reported lowering tire pressure helped in a sway situation at high speeds. Could try dropping 5 psi and see if it improves.
Interior Bulb Sizes?
enigma-2 replied to CameronDouglas's topic in Interior, A.C., Heat, Interior Trim
LEDs are not bulbs. They are chips soldered onto a circuit board or attached to a plastic backer (they're an integral part of an assembly and not replacable). The actual number of the LEDs used in these assembles are not known (other than to Ford and the supplier who's manufacturing them for Ford. Being a nonserviceable part, Ford doesn't release that information). Even if uou disassembled the lamp, you still wouldn't be able to identify the LED. All of the incandescent and high intensity discharge bulbs used are listed in the chart you posted. All other fixtures are non-replaceable LEDs. -
Tail light Condensation
enigma-2 replied to d0minicano's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Been talked about here and in several other ford forums. It seems that even the factory authorized replacment units mist up. I have never had any problems with my MKX light bar, but - if it were me - I'd drill several tiny vent holes in the bottom of the fixture. It seems that the moisture gets in and, being nearly sealed, can't get out (or do they use some Gortex to vent?) Moisture is a pressure and the sealed lens unit lets it get in (as the interior is very dry, ( i.e. low pressure) but not really enough pressure differential for the moisture to force its self out. I would imagine that a few small holes should fix all that as there has to be a path for the moisture to equalize. -
For those interested in a GOOD radar detector
enigma-2 replied to Ntrain2k's topic in Accessories & Modifications
Radar detector have been discussed here in the past. No doubt you chose a good one. Personally I use an Escort Passport Max 360c. Shows which direction the police beam is coming from (front, back, left, right), displays several radar lock-ons, frequency, beam strength and other stuff. Excellent false rejection filtering and auto memorizating of existing doors, etc. Also have the ability to show what other Escort owners are picking up on their units (units sends detections from any particating unit to the cloud and downloads to others. You see a map (like Google maps) of the area your driving in an where the cops are). Also updates database and firmware via wireless connection. (I also use a Mirrortap harness and Blend mount).- 1 reply
No surround signal being received ? (Ok, I'm guessing). On my THX system, the surround stays locked on, but reverts back to stereo as I rarely play any surround sound DVD's. (If fact I only own a few disks. Too difficult to find, too expensive. But great sound in 96 kHz/24 bit).
Sensor failure is somewhat common, so I'd recommend changing the sensors. But while he's got it apart, I think there are others more knowledgeable than me who would also recommend changing an additional part. (Let them chime in). I think your mechanic is being honest, but conservative. As the tranny wasn't maintained, other maintenance may have been neglected. To be safe, I'd recommend to change the coolant. (Very important). There's a new coolant being used by Ford and you'll need to do a flush as the 2008 used gold. I'd recommend switching to the new light green coolant. Note that not changing coolant on the 2008 has been linked to water pump failure. If you notice coolant low in the overflow reservoir, or the oil looking "milkly" on the dipstick, you may have a failed water pump. This would need immediate attention to prevent engine damage. Repair runs under couple grand. And spark plugs if you can't verify when they were changed last. (Old plugs have wider gaps, which draw more current to spark across, which create more heat. The additional heat will cause coil(s) failure and (possibly) ignition computer failure (if a coil shorts when it fails). (Very important). Dealer cost around $300. If yours is an All Wheel Drive, change the fluid. Your transmission mechanic can do this by pumping out the old and pumping in new. (Very important). Dealer cost around $90. All used cars require certain upkeep, and the Edge is a great car. Given care, there's no reason it couldn't see 300k.
- 1 reply
Rearview mirror always dark
enigma-2 replied to BarryK3's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Went through the exact same thing myself. Welcome to the club. Be warned, next week we are going to test you on Sync commands. Closed book! -
They reported something similar to this in the Explorer forum and it was traced to the 120 volt inverter. There's a TSB out on it. MC-10140282-9999.pdf
Try your other key to isolate if the key is no longer recognized by the system. Other than that, it could be several items. You may have to take the instrument cluster apart again and check all connections like bucketheadisgod2 suggested. (Where in the hell did you come up with this name, grin). Unfortunately the system cannot be diagnosed by anyone other than the dealer (protective measure).
May be damaged pump from loss of fluid. But still; https://itstillruns.com/stop-steering-pump-whining-noise-7500731.html
- 6 replies
- steering noise
- power steering
Almost sounds like a defective ignition switch.
Test it. Put your finger over the sensor (in the plastic opening under the glass). If this sensor is blocked, the mirror thinks all's dark and will turn light. (I used this method to verify my mirror is working). -
Uh huh. https://www.urbandictionary.com/define.php?term=rusty pipes (chuckle)
Aftermarket hitch and drilling
enigma-2 replied to thesavo's topic in Cargo, Hauling, Roof Racks & Towing
Not sure. Why not give them a call and ask? 800-298-1624 -
Looking Beyond Edge being discontinued
enigma-2 replied to enigma-2's topic in Buying, Leasing & Ordering
Was at local dealer today, only had 2020's in stock. Having major problems getting 2021 Nautilus. (Did have a 2021 Mustang on the floor. Think it was called "Puke Orange". Oh my lord what a ugly car. Ugly, ugly, ugly). Production started in March, way behind schedule. Anyway, still no Nautilus, .... but willing to "take my name and call me when one comes in". -
IK, had the new Pirelli Scorpion Verde's put on today and my initial assessment is 10 out of 10! Quieter and much smoother than the Bridgestone's. Granted the Bridgestone's had 10k on them but they were never this quiet or smooth as these Pirelli's. (I'd give the Bridgestone's an 8.5 out of 10). But there's no question the Pirelli is better. They matched TireRack price, $70 rebate, used Ford Card so I have one year to pay with no interest, also had new pressure senders installed, road hazard warranty ($125 for 4 vs. $200 for one tire and these 20" tires, just scrape a curb and the sidewall blows out - experience talking), and a four-wheel alignment. Also had the tire glued on with rim sealer. (Sick of slow leaks). Anyway, yes, I strongly recommend the Pirelli Scorpion Verde's. Excellent tire if you like a quiet, smooth ride.
Yea, I think it has to do with whether the switch is active or not, not what happens afterwards. If memory serves, it's the left button ln the steering wheel and you thumb down to settings, vehicle and liftgate, on/off (i think). Easy enough to check and eliminate this possibility.
As you seem to have addressed everything, I'll offer a wierd suggestion. Reset the KAM.
No drilling required https://www.etrailer.com/Trailer-Hitch/Ford/Edge/2014/75728.html?VehicleID=2014307578 -
Any possibility that the liftgate has been turned off? When off, it will not work with the external switch, but will still open with the FOB.
Trim between Vista roof and windshield rust
enigma-2 replied to simlarock's topic in Exterior & Body
Material Dow Urethane Adhesive Betaseal™ Express Dow Urethane One Step Glass Primer Betaprime™ 5500 / 5500A / 5500SA Sika Urethane Adhesive Sika Tack ASAP Sika Urethane Metal and Glass Primer Sika 206 G+P Removal Position the roof opening sliding glass panel to the fully OPEN position. Remove the antenna. For additional information, refer to Section 415-00 . NOTE: A new roof opening panel front trim seal is supplied with the new front trim panel. Remove the roof opening panel front trim seal. WARNING: Always wear eye protection when servicing a vehicle. Failure to follow this instruction may result in serious personal injury. WARNING: Wear protective gloves when handling components or parts that have pointed or sharp edges. Failure to follow this instruction may result in serious personal injury. NOTICE: Make sure the cutting blades are changed where the cutting depth changes to avoid damage to the body, trim panels or windshield moulding. NOTE: Lubricate the urethane adhesive with water to aid the Deluxe Windshield Removal Tool when cutting the urethane adhesive. When using the Deluxe Windshield Removal Tool, place the flat side of the knife against the front trim panel. Refer to the urethane adhesive path illustration and begin cutting at the center of the front trim panel and work through towards the opposite corners. Rotate the trim panel up and forward to clear the side trim panel. Cut off or bend the 2 steel alignment tabs if necessary. Remove the front trim panel assembly and discard. Installation NOTE: For additional urethane adhesive guidelines, refer to the manufacturer's installation information. 1. NOTE: Avoid scratching the painted surfaces. For minor scratches or exposed metal, see the manufacturer's recommendations. Using an appropriate tool, trim the urethane adhesive and pads leaving no more than 0.5 mm (0.01 in) base of original equipment urethane along the roof opening module surface. 2. NOTE: Make sure the water channel is free from any foreign material. Using a soft brush or vacuum, remove any dirt or foreign material from the roof opening panel module. Clean residual adhesive tape from the housing using a suitable cleaner. 3. NOTICE: Be sure to use the same brand of cure-rate products for the urethane adhesive and primer. Do not mix different brands of urethane adhesive and primer. Incompatible products can result in seal failure. For additional information, refer to the Material chart in this procedure. Cut the urethane adhesive applicator tip to the specification. 4. NOTE: Use either the Air Caulking Gun or a high-ratio, electric or battery-operated caulk gun that will apply the urethane adhesive with less effort and a continuous bead. Apply urethane adhesive on top of the existing trimmed urethane adhesive bead, making sure there are no gaps in the bead. 5. NOTICE: When installing urethane adhesive-installed parts, the vehicle must not be driven until the urethane adhesive has cured. Adequate cure time is specified on the drive away chart for each urethane adhesive product as the temperatures and humidity vary. Inadequate or incorrect curing can adversely affect the retention of the trim panel. NOTICE: Make sure the windshield moulding does not get pinched under the front trim panel. The windshield moulding should be pulled over the top of the leading edge of the trim panel during installation. NOTE: Position front trim panel to best overall appearance. Apply the front trim panel assembly to the roof module. Work the trim panel down using only vertical pressure. Install the antenna. For additional information, refer to Section 415-00 .
