Help with center console, please!
enigma-2 replied to KeithsKelly's topic in Interior, A.C., Heat, Interior Trim
It soulds like you have to remove the center consul cover. This video shows how to do it on a 2019. -
I stand corrected. Ohio front side windows tint must allow more that 50% of the light in. That's really different than what most states allow. Only concern I can see is if you traveled out of state. A trip to Indiana may earn you a $120-$150 ticket. (Indiana is 30% max on front, side windows). Probably never get pulled over, they would only check if speeding, etc. Michigan is 35% but only on the top 4 inches (of the front, side windows), but only $100 fine. Michigan will pull you over as it's obvious. -
Try pressing the climate control button, the defrost button and the power button at the same time. then press the climate control button again and it should reset.
As it changes with engine speed, it's probably an accessory bolted onto the engine. As your not getting a battery light, probably rule out the alternator. Power steering is a common cause, especially when it runs low in fluid. One way to test is to turn the wheels left and right. If the whine gets louder, its probably the power steering pump. (Only the power steering pump will change sound when turning). Another possible cause is the serpentine belt. Usually presents as a high pitched whine. Usually louder just after the engine is started.
Had the same problem couple of years ago. In mine, only one fan was working. Ford changed the fan assembly and worked fine since. Normally its the fan assembly that failed (very common) but you stated both fans are running. As the a/c works ok when under way, this limits the problem to the fans not working. (Is it possible that the fans were working when you checked but fail while you are driving? Fan controllers can be finicky).
Couple of suggestions. Others reported wind noise traced it to the panels under the car (drivers snd passengers sides). These panels are held on with push pins that sometimes come loose or fall out. This allows the panels to extend into the air flow causing wind noise. Quick check under the car will verify. Another place to check is the trim piece on the drivers mirror. If the piece is out of place, it creates a gap and wind noise.
2008 Ford Edge Remote Start Not Working
enigma-2 replied to ARG's topic in Accessories & Modifications
What did the garage find? -
2012 Edge - Underdash Fuse Panel Tapping
enigma-2 replied to kkernspa's topic in Accessories & Modifications
For my radar detector I used a mirror tap harness. Simply plugs into the back of your mirror and powers on with the ignition. Literally takes minutes to install. Google Mirrortap. Can't recommend the Chineese brands. Cheaply made and wired wrong. -
When I read this I was a little surprised as most involved in the industry will refuse, or at least inform you that a 35% tint on the windshield and front windows is illegal. (In all states). I know what you mean about these geniuses who convert their headlights and throw all kinds of glare. I've had to slap on my sunglasses (at night) a couple of times. -
One other thing I'd check is the conditions on the battery cables (esp the ground chassis connection) and harness connectors from thd alternator. Look for looseness or corrosion.
Never have too much chrome ?
Maestro RR2 for head unit replacement?
enigma-2 replied to redlancer's topic in Audio, Backup, Navigation & SYNC
"Sorry, the product is currently out of stock." -
Hard/cut key test - alarm went off!
enigma-2 replied to Edgingage's topic in Alarms, Keyless Entry, Locks & Remote Start
Page 142 in the owners manual : • Unlock the doors using a key. If you use this method the system will not disarm, but you will have an opportunity to disarm the vehicle once entered. See the Note following. Note: If the driver’s door is unlocked with a key, a chime will sound when you open the door and the message center will display TO STOP ALARM START VEHICLE. When this occurs, you will have 12 seconds to disarm the alarm using any of the actions above, otherwise the alarm will trigger. IE, get in and start the car. -
Motorcraft parts on Ebay are Chineese fakes. (Why do you think they are do cheap)? Buy at your own risk.
Might look over this site. https://www.700r4transmissionhq.com/ford-edge-smells-like-gas/
2010 Edge coolant came out of air intake box.
enigma-2 replied to FrodEdge's topic in 2010 Edge & MKX
One possibility is the water pump has failed. There is a weap hole on the top, right (viewed from the drivers seat) of the engine. Should the inner water pump gasket fail (there's an inner and outer), the coolant is forced out through the weap hole so that it can be detected. 1. Check your oil. If it looks brownish and milkly, coolant is leaking into the oil sump and this will damage tbe bearings and journals. (Watered down, can't lubricate properly). Best to have the car towed to the dealer rather than subject the engine to more damage. 2. If the oil is ok, and you can see coolant leaking from the weap hole, the first set of gaskets have failed. Top off and drive to dealer (no high speed maneauvers). In either case the fix is to replace the water pump. (Quickly). Plan of costs running somewhere in the vicinity of $1600. Here's a video by MACTFORDEDGE describing where the weap hole is located. -
There's also a possibility that the problem concerns the wiring running to the coil. Connection may be corroded or burned.
Dito on the second.
My dealer did mine this last summer. He uses a machine that pumps the old fluid out through a hose (also pumps in fresh) through the fill plug. Uses the same machine pump to change the PTU. The pump is a professional unit designed for these type of maintenance areas. Big hunkerer. They didn't say how much it costs, but looked expensive. On my 09 MKX the recommended change interval is at 105k miles (for DANA units). Also at 3k miles if trailer towing above 70° F with speeds above 45 mph and not using non-synthetic fluid. Personally I feel all fluids should be changed at least by ~100k miles.
2007 Ford Edge Climate control not cooling
enigma-2 replied to wmiller8's topic in Interior, A.C., Heat, Interior Trim
Did you check the mode door actuator ? -
Vents not seeming to blow much heat or ac
enigma-2 replied to Tmajikman's topic in Interior, A.C., Heat, Interior Trim
This video may help locate the actuator (not your car but close) -
I read that you can reset the standard system by removing the hvac fuse for a few seconds. (I also feel that this appears to a mode door actuator problem, not a blend door.) There are two control positions for tbe center vents. One is for the instrument panels vents and center consul vents. The 2nd position sends the air out of the instrument panel vents, center consul vents, floor vents and rear floor vents. (Obviously the more vents open, the less air through each). -
Looking at the Infotainment website, they are offering a headunit replacment thst fits 2011 through 2014. So yes, should be the same radio. But theres more involvef than a simple head unit replacment. You could contact them and ask. They sell complete upgrade kits, 4" to 8" with nav. Sync 2 sells for $1699, Sync 3 sells for $1899. But those prices cover everything needed to upgrade, modules, cables, completely plug and play. https://www.infotainment.com/collections/all/2012-ford-edge
Motorcraft Wiper Blades
enigma-2 replied to normkol's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Dealer told me years ago that the blades that come with the car are special blades and not the ones you can buy from the dealership. He said (and this was years ago) that the blades Ford installed at the factory were Trico, top of the line. The Motorcraft replacments could be anything as they spec'ed and contracted with several blade mfgrs. (He got this from his area rep). As for me, I've had the same blades on for three years now. Wipe them with an alcohol wipe then spray them with 303 protectant. The alcohol wipe cleans off the dirt and road oil and the 303 protects the rubber from the UV of the sun.
