Everything posted by WingNut
I have see one other 2015 and it was in my neighborhood. But I only saw it once and it hasn't returned. Your location says Ashburn so that is how I know we are "neighbors"
The narrowest point in the cargo area is 45". Here is a picture of a 48" piece of cardboard in the cargo area. You could tilt the plywood sideways but that would limit the # of pieces you'd get in there.
Just got the keys to my 2015 Ford Edge Titanium
WingNut replied to kaushen79's topic in Welcome Forum!
According to the Curtis website it will work on on Edge trims. EDIT: Nevermind. The site now says "Except Edge" -
Sounds like you need to find another dealer if they accommodate you for 2 weeks on a car that is leaking water.
I think this will have more to do with the tires than the actual 20" rims. And hello to a fellow "Asburn-ian"?
I wonder if that hitch would work with the Sport models. -
If for later. Will want to do something similar with a dash cam
New DRL Bulbs
WingNut replied to built2prfctn's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Is it only when you have the lights set to auto? -
New DRL Bulbs
When are the DRLs on? -
No problem. Let me know when you are up closer to DC with your canoe. We'll be on the potomac this weekend. Just got my rack in time.
I went out and checked some measurements. The shark fin looks to be 2.75" tall. From the bottom/center of the rear crossbar to the top of the roof is 2.5". As you get closer to the sides, that measurement increases. Plus you have the width of the bar. From the 2nd pic compared with the Yakima installation pic above you may be able to determine the height of the factory roof rails
I have the Yakima Q-Towers on mine. Just installed today. I don't have the rails so I had to go that route. The bars seem to just clear the shark fin. Here is a pic from yakima's site of the factory rails and the Q-towers
picking up new 2015 sport edge what should i inspect
WingNut replied to sideswipe's topic in Buying, Leasing & Ordering
The only issues I have seen on this forum that seems to have been a problem for multiple members are: 1. Water Leak 2. Rattle from behind driver. (resolved. easy fix) 3. SunRoof rattle while open. -
Check the front and rear foot areas for any sign of a water leak or musty smell. -
Driver floor is SOAKING WET
WingNut replied to Blue_Edge15's topic in Interior, A.C., Heat, Interior Trim
No clue. I'm just guessing based on that guys question and what his dealer told him. Here is your pic. Seems the same. But I'm on my phone so not sure.- 480 replies
- missing floor grommet
- new Ford owner
- (and 3 more)
The sealant is definitely not welded. This seal feels rubbery like you describe. If you wante to post your picture, email it to redwingsot at gmail.com- 480 replies
- new Ford owner
- (and 3 more)
I haven't found any TSBs online for a leak. But I did find this question and the perspm mentions his dealer said the seal is around the A pillar. I went outside, popped my hood, and found the seal seen below. Looks to be painted the same color as the body. I have no leak issues. You can see the seal running horizontally. This is my driver side near where the hood hinge is. http://www.justanswer.com/ford/948ge-i-ve-owned-brand-new-2015-ford-edge-2-5.html- 480 replies
- new Ford owner
- (and 3 more)
I want those fogs too. Need retrofit stat
The cargo net is small for the edge in my opinion. The stock one in my Mustang is larger. You can hold maybe two grocery bags in it. I like the cargo cover....I'm just trying to find a reason why I need it. Please someone convince me.
Did you check your seals yet?- 480 replies
- new Ford owner
- (and 3 more)
Sloshing would be the fuel in the tank- 480 replies
- new Ford owner
- (and 3 more)
Do u have the part numbers for the individual pieces?
Towing / Luggage Rack questions
WingNut replied to Chipster's topic in Cargo, Hauling, Roof Racks & Towing
I dont know exactly what the cross rails with that part # include. But be aware that the roof rails can not be added on after it leaves the factory. So make sure you get that option. Then I'd go to Thule directly for the cross rails since im pretty sure they are the supplier for the cross rails. It looks like the square bars would be around $400, the aeroblade $475 or the Aeroblade edge for $514 (which looks stock). But remember you must get the roof rails from the factory. Dont let a dealer tell you they can be added after the fact like they could with previous years. They can't. -
If the car is built, hard to imagine there is a parts hold keeping it there.
I checked my '15 Sport last night after a hard rain and there is no sign of water inside or water being in there in the past.. It has rained a few times since I've owned it.- 480 replies
- new Ford owner
- (and 3 more)
