onyxbfly
    40
Everything posted by onyxbfly
  1. No one can say for sure. The ST should get the Explorer Platinum IPC at a minimum. I do hope that the 2020 models get a new IPC. But something tells me that Ford simply just doesn't care and we will be looking at the same cluster since 2011. If your referring to the SYNC/ Navigation screen I don't think well will see any significant changes until the Edge gets a full refresh. By full I mean inside and out! The only change of note is that the 2020 + will not have a CD player.
  2. Sounds like you are doing everything right. Have you tried with your phone in USB Dubugging mode? If not go to Settings/ about phone/ build number/ tap build number about 10 times and it will say that you are now a developer. Go into options and turn on USB debugging. Also change USB type from charging to MTP. MTP mode will allow your phone to transfer data and media. I should have asked which OS are your running. Its been a while since I've used Nougat. Or is it Marshmallow? You might need to go into apps then settings..... Try upgrading your OS as well. I think Oreo might be compatible with your phone.
  3. What type of phone are you using? Do you have android auto installed on your phone? It may seem like an odd or rudimentary question but I have seen some instances where if android auto is not installed it is very easy to miss the prompt to install it etc.
  4. Congrats and welcome to the forum. Glad to hear that your husband is doing well. @vega Ping @TXFRDOwner He can source you a kit that is significantly less than the 4Dtech kit.
  5. The OEM Michelins are rated for 60k miles. The first layer is a softer compound and is good for 15-20k. The second layer is harder and subsequently firmer and are noisier. Unfortunately they remain that way for the duration.
  6. Oh Hell no! That answer is simply UNACCEPTABLE! "Keep cleaning your garage floor" GTFOH They can clean up the garage floor or wherever they park it till they get you an oil pan. I bet if it was on their lot they would put pressure on FORD to source one. They would give me a loaner and I'd patiently watch the clock till I could initiate the buy back process.
  7. Welcome to the forum. You have a sweet ride I hope she creates a cult following and becomes collectible some day!
  8. Here is a possible solution. Its just a matter of how important having a smaller keyfob is to you. This will allow you to lock and unlock and remote start via your cell phone. This way you can lock your keyfob in your car with your phone and go about your business. https://www.ebay.com/itm/1-Plug-Install-MyCar-App-Plug-Play-Remote-Start-fits-2015-2018-Ford-Edge/142799828813?hash=item213f88774d:g:CqwAAOSw7Bda63Bl There is a factory ford remote start open and lock via phone kit available but it is really old and hard to get. Personally I feel that Ford removed them from inventory when they started conceptualizing and or marketing smart link. Or you can buy Fordpass Smartlink but I'm not sure on the availability on that as well.
  9. It's sexy just for the same reasons why you like chrome... instead of chrome its black!
  10. It will not shrink if you put a case on it.....
  11. Welcome to the forum. Unfortunately your post is in the wrong section of the forum. Welcome to the forum. @akirby Can you please move these post to the correct section.
  12. Congrats! Welcome to the forum!
  13. A car is an extension of ones personality....... Variety is the spice of life.....
  14. Welcome to the forum. You're sporting my favorite color combo!
  15. Welcome to the forum! Congrats! Pics whenever you can. We like pics!
  16. Congrats! She's a beauty! I see you found yourself a unicorn! She doesn't have the sunroof. Welcome to the forum!
  17. onyxbfly
    Edge ST MPG
    CTFU When in Rome do as the Romans do. I think they are called frites? I haven't been to Paris in about 20 years give or take. The oddest things you remember from vacations. Do they still serve them with mayo or mustard? No one was offended when I called them french fries.. People usually smiled, or chuckled when I called them french fries.
  18. Welcome to the forum! 2013 with 26K on the clock. Just about 5K per yea. She has lots of life left in her. She will serve you well!
  19. I brought the one I have towards the beginning of the year. We may have the same model, my brother uses the same one with his iPhone. It also includes updates to different manufacturers.
  20. Ideally a hardwired solution is the way to go, a lot less moving pieces involved when establishing a connection. I use the bluetooth reader you linked. It is fully compatible with windows.
