Perblue
Everything posted by Perblue
Metal oil pans typically have a magnet in the bottom of the oil pan for this purpose, same for transmissions. Ford also has one on the plugs for the rear differential, same as some aftermarket oil plugs, it does actually work even though you have doubts. As for remaining oil it's minimal, when jacked up in the front, and probably less than when the change is done at a place on a hoist or a pit with a standard plug. You can't post something without someone potentially having a counter point. ?
This could be an argument for an after market one, like the ronin, since it actually has a magnet on the back of it that you can clean off occasionally and help prevent the metallic sludge from collecting on an oil pan like I've seen most of the time when dropping one.
Yep all normal signs in these things. They turn off nonessentials when a weak battery is detected, probably in another 2-4 weeks it would have displayed a message on the center screen. You could have had ford replace it for free on warranty and been good for another 2-3 years.
MPG Tanked!!! Any help Greatly Appreciated...
Perblue replied to Pascale007's topic in 2017-2018 Edge & MKX
That sounds about right to me. -
I'm going to go with no considering the fusion and edge are drastically different part numbers, don't look alike and going by photos looks significantly shorter. The fusion sits considerably lower in many ways, even compared to a lowered edge, so this doesn't surprise me. Bilstein B6 Performance Series Shocks and Struts 2019 FORD FUSION Parts & Accessories | Summit Racing Bilstein B6 Performance Series Shocks and Struts 2019 FORD EDGE Parts & Accessories | Summit Racing
Mine did this. Dealer replaced the camera to fix it. No idea on why it happened though.
- 5 replies
- reverse
- 2013 ford edge
(and 2 more)
Nope, took me over a month when I ordered my 19 and that was without a chip and electrical component shortage.
Ford Active Noise Control
Perblue replied to niceonept's topic in Interior, A.C., Heat, Interior Trim
I hear a noise too but it's the fans. Especially the cooled seats, the sound comes from the seat so it's not ANC. -
Adaptive headlights
Perblue replied to Itsdjellz's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
If your headlights shift left to right on startup or vice versa you've got them and don't worry about it. if they don' then hard to say why they aren't there, they could be missed or manufacturers are ending up having to delete features due to the chip shortage. -
The 3.7L in the sport is actually just a slightly bored out 3.5L. If it was turbo charged.....?
I hit a deer - AC not working?
Perblue replied to Witenite's topic in Interior, A.C., Heat, Interior Trim
Yes, the ac condenser is in front of the rad and likely broken.- 1 reply
- 2
You sure it's broken and not just needing the channels in the roof blown out with an air compressor and lubed with some dry graphite spray lubricant? Can't help with price other than have you checked what they go for in your state and surrounding on the used car sites? it would give you an idea of value for your area.
MPG computer any consistency in margin of error?
Perblue replied to ed4pbay's topic in 2.0L EcoBoost
I wouldn't say it's impossible then. I find my gauge relatively accurate when I manually calculate it out. Some find it's out a couple mpg too high. At any rate it's very likely you got around that. -
I doubt it's the cat......unless it's missing or someone stole it. It could be any of these things. Damaged muffler or leaks in the muffler. Damaged exhaust manifold or leaks in the exhaust manifold. Damaged exhaust pipe or exhaust pipe leaks. A misfire in the engine. Oil contamination in catalytic converter. Faulty catalytic converter (most common). Faulty engine coolant temperature sensor. Faulty front oxygen sensor. Faulty rear oxygen sensor. Damaged oxygen sensor wiring. Oxygen sensor wiring that is not properly connected. Damaged oxygen sensor connectors A leaking fuel injector. High fuel pressure. Use of the wrong kind of fuel (using leaded fuel instead of unleaded fuel)
4cyl or 6? Doing that speed in my ST I have had it as high as 34mpg Imp. I could see it with the 4cyl or with a good tail wind. -
Changing destination while driving
Perblue replied to F4Gary's topic in Audio, Backup, Navigation & SYNC
You staring at the screen for an extended period of time, distracted, trying to type in an address that could be who knows how long, while driving is safe? Let me guess you text while driving too. Also reading the guesses in autofill is distracting too. Maybe some have allowed you to do it but people have funny ideas of what is safe while driving like applying makeup or reading a book or peeling an orange it doesn't mean it's safe. -
Under hood temps and hood heat extractor install
Perblue replied to poontanghooligan's topic in 2.7L EcoBoost
I hope I'm proven wrong but I don't think the extractor will help much. You would be better off removing the active shutters and figuring out how to hook up a small front mount cooler for it. The ptu holds a whopping 500ml of fluid, this takes no time to heat up. Ford rated it for towing but unfortunately I don't think they imagined towing a large grade while passing. Hate to say this too but sounds like you should have bought a full size suv or a truck. Just my opinion. -
You get hub centering rings that fill the gap, any shop can order them or likely have them in stock. Most seem to prefer a 38-42mm offset because it makes the wheels more flush with the fenders, especially when lowered.
Great looking edge, but hate to tell you the 3.5L is naturally aspirated. No turbo or intercooler. Still a great engine though and I enjoyed it when I had my 2013.
Some 18s may not fit. I run these in winter with no issues. Klasse Motor Sport Apex Black Satin Wheels (kaltire.com)
Intercooler Outlet/Cold Pipe Upgrade (2015-2018 Edge Sport)
Perblue replied to snmjim's topic in Accessories & Modifications
It was always the one, cold side, pipe.... Unless you mean no with, for meth, or without bung hole option. -
Is this carbon fibre, plastic or rubber?
Perblue replied to kevinmac's topic in Interior, A.C., Heat, Interior Trim
Plastic with a rubberize coating. There is no carbon fiber on the edge or almost any vehicle originally priced under 80k.- 1 reply
The ultimate drain plug, expensive yes but works amazing. FORD EASY OIL DRAIN (roninfactory.com)
For you sure, for most no. I get better mileage out of my 2.7tt than my old 3.5 NA. You are an exception not the general rule as others have said no matter what you believe.
It is a thing but unless H&R put the labeling on the springs upside down his pictures show them being the proper way, that would cause his issue though with these springs.
