WWWPerfA_ZN0W Posted February 14, 2017 Report Share Posted February 14, 2017 (edited) G0000119 2016 SYNC 3 Apple CarPlay & Android Auto Upgrade http://www.fordedgeforum.com/topic/20468-sync-3-2016-upgrade-to-carplay/page-7?do=findComment&comment=166021 Edited February 14, 2017 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted February 14, 2017 Report Share Posted February 14, 2017 So bottom line is it worth to upgrade to 2.2 even if you don't have the right hub or interested in CarPlay? What's the benefits compared to version 1.0? Thanks in advance Yes, Yes, Yes. This has been stated multiple times. The biggest improvement is the voice prompts in my opinion. Quote Link to comment Share on other sites More sharing options...
tpm419419 Posted February 14, 2017 Report Share Posted February 14, 2017 Yes. Hopefully a future update will resolve this Quote Link to comment Share on other sites More sharing options...
SmokingGhost Posted February 15, 2017 Report Share Posted February 15, 2017 Well after about an hour of strong language and force I got the USB module out and put the new one in and now have carplay. I think the best thing I could have done was remove the leather side panels and the back shelf cover to help with pushing the module out. I just ran into a little issue where all the sides and top would pop out but the bottom just wouldn't give. Those clips are something else man. I also wanted to thank everyone in here for the feedback and tips to make this as easy as possible to accomplish. 2 Quote Link to comment Share on other sites More sharing options...
rhallett Posted February 19, 2017 Report Share Posted February 19, 2017 Hello all, new to this forum....I have a 2016 Edge Titanium, Sync 3 1.0 NON NAV. I am contemplating upgrading before actual release. This being less than one week before driving from Maine to Key West. I have a OnePlus 3 phone, which is not on the list of phones that are compatible. Will this work with my phone or is it a complete risk for nothing to update? thanks so much in advance for your help with this. It would be really nice to have either Google Maps or Waze show on the screen!! Quote Link to comment Share on other sites More sharing options...
rvcjew Posted February 19, 2017 Report Share Posted February 19, 2017 Your phone should work fine once tethered. And if you want to use it just for the drive without touching the car at all AA now works by itself in the app. Get the AA app off the playstore and you will see what I mean. Malcolm. Quote Link to comment Share on other sites More sharing options...
rhallett Posted February 19, 2017 Report Share Posted February 19, 2017 Thanks so much, Malcolm. yes, i'm using that now for audiobooks. Is it worth taking the risk of voiding warranty? i've only had the car for 4 mos. did you do it to yours? 1 Quote Link to comment Share on other sites More sharing options...
rvcjew Posted February 19, 2017 Report Share Posted February 19, 2017 (edited) Thanks so much, Malcolm. yes, i'm using that now for audiobooks. Is it worth taking the risk of voiding warranty? i've only had the car for 4 mos. did you do it to yours?I have the Nav version update procedure is slighty different but it should not void your warranty as it is an OS update. They were impressed actually at the dealer when I went in for the steering wheel fix. Yours requires 2 updates to complete I suggest you read the thread before doing it. Malcolm Edited February 19, 2017 by rvcjew Quote Link to comment Share on other sites More sharing options...
CampIam Posted February 25, 2017 Report Share Posted February 25, 2017 My two 911 emergency contacts were deleted during the update and I had go in and enter them again. All other program settings & radio stations stayed the same so I didn't think to check that feature until just last night while I was playing with some other settings. I don't know if anyone else noticed this after their updates however if you use that feature & haven't verified yours are still programmed best check. Quote Link to comment Share on other sites More sharing options...
Livestrong16 Posted February 25, 2017 Report Share Posted February 25, 2017 Is OP still accurate that I can't upgrade from V1.0-Nav, if I want to start the CarPlay upgrade process myself? Quote Link to comment Share on other sites More sharing options...
rvcjew Posted February 26, 2017 Report Share Posted February 26, 2017 (edited) No you can it just mentions that it was most likely a dealer upgrade if it went ota. I upgraded from 1.0 Nav. You can do it yourself then swap the usb module. Malcolm Edit: if you upgrade and do not see a CarPlay thing in options you will also need the usb module, if you see the option your module is new enough. Edited February 26, 2017 by rvcjew 1 Quote Link to comment Share on other sites More sharing options...
Livestrong16 Posted February 26, 2017 Report Share Posted February 26, 2017 Where can I get that file to upgrade? Do you recall where you got the file? I've ordered the module, but obviously can return if I don't need it. Quote Link to comment Share on other sites More sharing options...
rvcjew Posted February 26, 2017 Report Share Posted February 26, 2017 (edited) --------------------------- Checksum information --------------------------- Name: SYNC3 NAV V1 TO V22.zip Size: 1728118492 bytes (1648 MB) SHA1: 38C41ECD34D85F4B69DCCAF0505CFA580A456E78 SHA256: 5C725E1E261CA59E6E643D3D4CDE1677D41F2A559448F81499 E342954C351B49 CRC32: 4F7B9C95 CRC64: 9451E65177117035 Make sure you have the same hashes when downloading and here is my link. https://mega.nz/#!GhZRyDgb!AAM04HkOIQK4Rq89gUffnOB95vCSNvQOyyq5tubBUss . Make sure to follow the instructions. Malcolm Edited February 26, 2017 by rvcjew 1 Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted February 26, 2017 Report Share Posted February 26, 2017 https://drive.google.com/file/d/0Bxlap1Uv4Q55NnhBMjdEaUtfZms/view And there is mine... Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted February 26, 2017 Report Share Posted February 26, 2017 Make sure you have the same hashes when downloading and here is my link. https://mega.nz/#!GhZRyDgb!AAM04HkOIQK4Rq89gUffnOB95vCSNvQOyyq5tubBUss on mobile so sorry for bad formatting. Make sure to follow the instructions. Malcolm FYI, ALL of the links except your own are no longer available...Please edit your post so people don't click on them unnecessarily. 1 Quote Link to comment Share on other sites More sharing options...
Livestrong16 Posted February 26, 2017 Report Share Posted February 26, 2017 I plugged the usb into my car and nothing shows up that it's doing anything, is this normal? Should something appear on screen Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted February 26, 2017 Report Share Posted February 26, 2017 I plugged the usb into my car and nothing shows up that it's doing anything, is this normal? Should something appear on screen Yes, There are instructions inside of the ZIP file. If not, you must copy the contents of the ZIP file to the root of a FAT32 or EXTFat formatted flash drive. Quote Link to comment Share on other sites More sharing options...
Livestrong16 Posted February 26, 2017 Report Share Posted February 26, 2017 Yes, There are instructions inside of the ZIP file. If not, you must copy the contents of the ZIP file to the root of a FAT32 or EXTFat formatted flash drive. Yup extracted the file to the root of my drive. I'm using EXTFAT... there is only 2 files the sync my ride and the auto file Very strange. The USB light is blinking , just nothing on screen. Quote Link to comment Share on other sites More sharing options...
rvcjew Posted February 26, 2017 Report Share Posted February 26, 2017 FYI, ALL of the links except your own are no longer available...Please edit your post so people don't click on them unnecessarily. Thanks for letting me know the hashes are very important though. Malcolm Quote Link to comment Share on other sites More sharing options...
Livestrong16 Posted February 26, 2017 Report Share Posted February 26, 2017 What do you mean by the hashes? Quote Link to comment Share on other sites More sharing options...
Livestrong16 Posted February 26, 2017 Report Share Posted February 26, 2017 Tried a different USB stick and it's now updating , who knows what happened Quote Link to comment Share on other sites More sharing options...
rvcjew Posted February 26, 2017 Report Share Posted February 26, 2017 What do you mean by the hashes? It is used by databases to look things up quickly or in this case to make sure you have a non corrupt file to flash to your Sync 3 system. https://en.wikipedia.org/wiki/Hash_function https://en.wikipedia.org/wiki/SHA-1#SHA-0 I personally use this Shell extension to check them on my machine if your using windows. http://code.kliu.org/hashcheck/ Malcolm Quote Link to comment Share on other sites More sharing options...
Ray Heath Jr Posted February 27, 2017 Report Share Posted February 27, 2017 It is used by databases to look things up quickly or in this case to make sure you have a non corrupt file to flash to your Sync 3 system. https://en.wikipedia.org/wiki/Hash_function https://en.wikipedia.org/wiki/SHA-1#SHA-0 I personally use this Shell extension to check them on my machine if your using windows. http://code.kliu.org/hashcheck/ Malcolm Non-corrupt, or more importantly, non-hacked or changed. With that said, not really an issue. It is not easy to screw with these install files. Quote Link to comment Share on other sites More sharing options...
Rocketboots Posted February 28, 2017 Report Share Posted February 28, 2017 So my 8 month old car with 7,000 miles on it went in to have the drivers seat track mechanism replaced under warranty as it had already started to feel disconcertingly loose; not a good sign. I asked the dealer if they could try to upgrade my Sync 3, which is currently at V1.0. They said that their IDS system shows my car to be completely up to date at 1.0. I see responses on this forum that the 2016's will be upgraded by the end of 2016, now changed to sometime in 2017; why do you think that I don't believe that they will ever do this upgrade? After avoiding Ford's products for literally decades, I came back and purchased a top of the line 2016 Edge Sport, loaded with expensive options, that has a supposedly brand new Sync operating system that is actually already out of date. It's not like I bought a low spec Fiesta with thin profit margins. Please forgive the rant, but it seems like a Cavalier attitude to take with their customers. Unless there is some good old fashioned customer service oversight, it doesn't bode well for repeat business potential. Quote Link to comment Share on other sites More sharing options...
akirby Posted February 28, 2017 Report Share Posted February 28, 2017 Are you having a problem or you're just upset that it says 1.0 instead of 2.2? Why not update it yourself if you're that concerned about it? Quote Link to comment Share on other sites More sharing options...
