Cerberus Posted August 14, 2021 Report Share Posted August 14, 2021 On 2/20/2020 at 12:49 AM, CobraRGuy said: My experience with Stop Tech slotted rotors on my '12 Acura TL has not been good. I bought their pads and both front and rear rotors, but the rotor slots created pulsing sensations when braking. They fronts also wore out very quickly and the rears warped to the point where the first pad change required all new rotors as none of the 4 could be turned. I went with non-slotted Akebono rotors all around with Hawk LTS semi-metallic pads and am extremely happy with smooth powerful braking, low wear and so far no warpage. The only downside is, of course, increased brake dust, but that is far less important to me. This was my experience with slotted rotors on my '11 Fusion Sport 1 Quote Link to comment Share on other sites More sharing options...
clegg78 Posted August 23, 2021 Report Share Posted August 23, 2021 (edited) I've been watching this thread a bit, I had some damaged rear rotors I needed to replace and chose to upgrade the entire front and rear (and do the front brake line recall myself, cause all the dealers near me annoy the hell out of me). I went with the Powerstop setup mentioned (slotted/drilled). I've had EBC, StopTech (and Power Slot Cryo rotors they bought), Centric, and a few other brands on other cars, from what I can tell the Powerstop stuff is roughly the same. I've had some real issues with EBC and Centric in the past... with Centric pads being kind of junk and loud AF, and EBC pads either not braking well or being noisy/dusty AF. So I figure I'd try something else. And for the price, shipped via Amazon for free... its a no brainer. I am a tad concerned with the slotted aspect of the rotors, but we'll see how it goes, I've had great success, and some nasty vibrations from certain installs of slotted/drilled rotors on some cars. On another topic I was browsing the Tasca, and was noticing how inexpensive the calipers, rotors, etc... are for the "Performance" big brake kit from the 2019+ Edge ST From my math it seems you could do the full ST Performance brake package for ~ $1000 with the new calipers included. That's WAY cheaper than the $2500 upcharge on an ST to get them added. Anyone retrofitted them? They don't seem to be THAT much of an improvement and do restrict wheel choices a bit. But I found that interesting. Larger / Vented rear brake rotors would be nice, but I am betting you need the larger fronts as well or you'll throw the brake balance/bias all off. Edited August 23, 2021 by clegg78 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 23, 2021 Report Share Posted August 23, 2021 The second set On 3/1/2020 at 1:23 PM, 1004ron said: 7 Months and 9K mile update. When braking at speeds 40 mph and below there's a faint growl and light vibration which changes as the speed peels off and it comes to a stop - not bad enough to make me want to rush out and buy new brakes. The original rotors were definitely warped based on the lower frequency vibration when braking at speeds 60+ mph, but were smooth at lower speed. My wife's 2015 Mustang with the original solid rotors is smooth at all times, so might go back to solid rotors next time. Edit: Sent an information request to Power Stop and within a day they responded by email and called, offering a new replacement kit. The second set of these rotors and pads are a little better than the first set, but I'll be going back to solid rotors before these are worn. I welcome recommendations for solid rotors and pads. Quote Link to comment Share on other sites More sharing options...
Linmon Posted October 30, 2021 Report Share Posted October 30, 2021 On 8/23/2021 at 9:00 AM, clegg78 said: I've been watching this thread a bit, I had some damaged rear rotors I needed to replace and chose to upgrade the entire front and rear (and do the front brake line recall myself, cause all the dealers near me annoy the hell out of me). I went with the Powerstop setup mentioned (slotted/drilled). I've had EBC, StopTech (and Power Slot Cryo rotors they bought), Centric, and a few other brands on other cars, from what I can tell the Powerstop stuff is roughly the same. I've had some real issues with EBC and Centric in the past... with Centric pads being kind of junk and loud AF, and EBC pads either not braking well or being noisy/dusty AF. So I figure I'd try something else. And for the price, shipped via Amazon for free... its a no brainer. I am a tad concerned with the slotted aspect of the rotors, but we'll see how it goes, I've had great success, and some nasty vibrations from certain installs of slotted/drilled rotors on some cars. On another topic I was browsing the Tasca, and was noticing how inexpensive the calipers, rotors, etc... are for the "Performance" big brake kit from the 2019+ Edge ST From my math it seems you could do the full ST Performance brake package for ~ $1000 with the new calipers included. That's WAY cheaper than the $2500 upcharge on an ST to get them added. Anyone retrofitted them? They don't seem to be THAT much of an improvement and do restrict wheel choices a bit. But I found that interesting. Larger / Vented rear brake rotors would be nice, but I am betting you need the larger fronts as well or you'll throw the brake balance/bias all off. I used to think that Raybestos was to way to go, but not after taking the suggestion from an experienced mechanic told me about EBC. I installed the best rotors on my '09 Escape along with "Orange Stuff" pads (semi Metalic) and like... WoW! These brakes really grip and as you push further into the pedal they progressively bite even harder. I now have full confidence in the brakes knowing that I can rely on them. Granted there is more brake dust as result of me choosing the semi-metalic option. As for the $2500 performance brake option from a factory order, this is obviously over priced for what you are getting. I live in Canada and we do not have that option when ordering a new Edge St... From what I have read, the difference is size of discs and performance pads along with red calipers. Otherwise, the calipers are the same model. You can paint your calipers red for that "wow" factor with a kit for approx $60 on Amazon. I have a 2022 Edge ST on order, "Agate Black" and plan to paint my calipers soon after taking delivery and upgrade rotors to EBC on first brake change so it may be a while on the change. 3 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 1, 2021 Report Share Posted November 1, 2021 Yeah, the EBC OrangeStuff (or heavy duty/SUV pads) does work well, but it will eat the "cheaper" rotors from even Wagner/Raybestos alive. ask me how i know, lol. Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 4, 2022 Report Share Posted June 4, 2022 (edited) I got tired of the growl and vibration of the StopTech drilled & slotted rotors, so yesterday I installed Centric Hi-Carbon rotors and Centric PQ ceramic pads, and so far very pleased with the results. They come with a black coating on the outside - I painted both sides and the edge with high temp caliper paint. Bought from RockAuto Rotors $95 each Pad set $50 CENTRIC 12561120 {125.61120, 125-61120} (High Carbon) High Carbon Alloy Front; 345mm Front Disc https://www.rockauto.com/en/parts/centric,12561120,rotor,1896 CENTRIC 50018180 {500.18180, 500-18180} (Premium) PQ PRO Front https://www.rockauto.com/en/parts/centric,50018180,brake+pad,1684 Edited June 5, 2022 by 1004ron 6 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 4, 2022 Report Share Posted June 4, 2022 same company, different product lines. glad the new setup is doing well for ya. 2 Quote Link to comment Share on other sites More sharing options...
rod.charlie Posted November 24, 2022 Report Share Posted November 24, 2022 Could someone please help. I need to replace my front brake pads on my 2016 Ford Edge Sport. I need the full procedure of doing the job above. Thanks. Quote Link to comment Share on other sites More sharing options...
snmjim Posted November 25, 2022 Author Report Share Posted November 25, 2022 22 hours ago, rod.charlie said: Could someone please help. I need to replace my front brake pads on my 2016 Ford Edge Sport. I need the full procedure of doing the job above. Thanks. Get an electronic copy of the factory service manual, it's awesome, best I've ever seen! 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted November 25, 2022 Report Share Posted November 25, 2022 56 minutes ago, snmjim said: Get an electronic copy of the factory service manual, it's awesome, best I've ever seen! Last time I considered that, the price was a bit of a shocker - where do you advise getting this? Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted November 26, 2022 Report Share Posted November 26, 2022 19 hours ago, 1004ron said: Last time I considered that, the price was a bit of a shocker - where do you advise getting this? YHM! Quote Link to comment Share on other sites More sharing options...
1004ron Posted November 26, 2022 Report Share Posted November 26, 2022 I found this: Brake Pads R and I Front.pdf 3 Quote Link to comment Share on other sites More sharing options...
rod.charlie Posted December 6, 2022 Report Share Posted December 6, 2022 When doing a front pad replacement, would I need to release the cap on the brake fluid reservoir, as I’m pushing back the pistons in the calliper? Quote Link to comment Share on other sites More sharing options...
Cerberus Posted December 6, 2022 Report Share Posted December 6, 2022 39 minutes ago, rod.charlie said: When doing a front pad replacement, would I need to release the cap on the brake fluid reservoir, as I’m pushing back the pistons in the calliper? No But if fluid has been added while the pads were worn, you may end up with overfill spillage at the reservoir. And, just for the sake of saying it (although no one does it) you might consider cracking the bleeder on the caliper and pushing the fluid out instead of back up stream. Any thermal aging that has happened is better removed from the system than forced back into service. Think of it as a small scale flush of the brake Fluid. 4 Quote Link to comment Share on other sites More sharing options...
snmjim Posted December 6, 2022 Author Report Share Posted December 6, 2022 When doing a brake job, wether big or small we always recommend a full fluid flush, can't go wrong there...??? Note: brake fluid is one of the highest moisture absorbing fluids which in turn leads to caliper, wheel cylinder & master Cyl corrosion and/or seizing. 3 Quote Link to comment Share on other sites More sharing options...
rod.charlie Posted December 6, 2022 Report Share Posted December 6, 2022 Could you give me the procedure to do a full fluid flush. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted December 6, 2022 Report Share Posted December 6, 2022 1 hour ago, rod.charlie said: Could you give me the procedure to do a full fluid flush. I just did this a few weeks ago: https://www.youtube.com/watch?v=n1NvtUwfRJc 1 Quote Link to comment Share on other sites More sharing options...
SlippyNuxx Posted May 20, 2023 Report Share Posted May 20, 2023 On 6/4/2022 at 1:15 PM, 1004ron said: I got tired of the growl and vibration of the StopTech drilled & slotted rotors, so yesterday I installed Centric Hi-Carbon rotors and Centric PQ ceramic pads, and so far very pleased with the results. They come with a black coating on the outside - I painted both sides and the edge with high temp caliper paint. Hey @1004ron, it's been almost a year, so how are the Centric rotors/pads working out for you in regards to performance and rust/corrosion resistance? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted May 20, 2023 Report Share Posted May 20, 2023 6 hours ago, SlippyNuxx said: Hey @1004ron, it's been almost a year, so how are the Centric rotors/pads working out for you in regards to performance and rust/corrosion resistance? I'm still very happy with them - smooth and quiet. I used the same silver paint on the new front rotors and the rear, and as can be seen they still look better than they would if they weren't painted, but could do with a fresh coat of paint. 1 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 5, 2023 Report Share Posted June 5, 2023 On 11/26/2022 at 10:37 AM, 1004ron said: I found this: Brake Pads R and I Front.pdf Don't they recommend applying grease to the guide pins on these brakes? Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 5, 2023 Report Share Posted June 5, 2023 1 hour ago, enigma-2 said: Don't they recommend applying grease to the guide pins on these brakes? I didn't use that doc, but surprised that the Ford service manual doesn't even mention the lube on the slide pins. Quote Link to comment Share on other sites More sharing options...
Cyberdave Posted September 12, 2024 Report Share Posted September 12, 2024 On 6/4/2022 at 11:15 AM, 1004ron said: I got tired of the growl and vibration ... You also mention this in a prior post from this thread, at 40mph and lower braking causing this. My car started doing this the other day. The front brakes were replaced by my mechanic 2 or 3 months ago. Do you know what was causing this for your brakes? Thanks! Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 12, 2024 Report Share Posted September 12, 2024 4 hours ago, Cyberdave said: You also mention this in a prior post from this thread, at 40mph and lower braking causing this. My car started doing this the other day. The front brakes were replaced by my mechanic 2 or 3 months ago. Do you know what was causing this for your brakes? Thanks! I believe that's par for the course with slotted rotors and the lower price range may also be a factor - the high carbon rotors that have been on for quite some time are still performing great. 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted Monday at 01:34 AM Report Share Posted Monday at 01:34 AM On 5/20/2023 at 12:51 PM, SlippyNuxx said: Hey @1004ron, it's been almost a year, so how are the Centric rotors/pads working out for you in regards to performance and rust/corrosion resistance? On 5/20/2023 at 7:48 PM, 1004ron said: I'm still very happy with them - smooth and quiet. I used the same silver paint on the new front rotors and the rear, and as can be seen they still look better than they would if they weren't painted, but could do with a fresh coat of paint. Important update. With ample friction material left, the pads de-laminated. 1 1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted 11 hours ago Report Share Posted 11 hours ago I've had that happen with cheap pads a few times. I've been using Wagner Thermo Quiets for about 25 years and never had any problems. Quote Link to comment Share on other sites More sharing options...
