Everything posted by omar302
Speedometer and Cruse not in sync.
omar302 replied to roadkill401's topic in Interior, A.C., Heat, Interior Trim
On my MKX, the cruise set speed & the Speedo match exactly. My guess would be a calibration/software update required. As for akirby's comment regarding the speedo showing a faster speed, you are dead on. This can be confirmed using a GPS, but you can also see that it is actually made in the programming of the cluster, if you enter the engineering/test mode in the cluster, you can see the raw speed displayed which is very close to the GPS reading & higher than the speedometer/cruise speed. Entering the Engineering/Test menu: http://www.explorerforum.com/forums/showpost.php?p=3086315&postcount=2 -
Found this PDF confirming 6F35: https://canada.fleet.ford.com/downloads/Edge%20EcoBoost%20Press%20ReleaseEN%20-%20Aug8.pdf
I believe the 2.0 EcoBoost Edge has the 6F35 tranny.
The Edge with the 2.0 EcoBoost I believe has a 6F35 tranny.
For anyone needing to replace the PTU, I suggest researching for the Middle East version of the PTU with the oils drain plug. http://www.fordedgeforum.com/topic/13533-13m01-middle-east-ptu-extended-warranty/
Could be the wiper switch/stalk. There was a recent member with a nearly similar problem: http://www.fordedgeforum.com/topic/17087-wipers-stuck-on-intermittent/ Edit: If you have rain sensing wipers, it might be a different problem: http://www.fordedgeforum.com/topic/14556-2011-edge-wipers-turn-on-randomly/
- 1 reply
You can also get these, better looking than plain black tire valve stems: http://m.ebay.com/itm/130918503267 Or http://m.ebay.com/itm/131263053788
Check the Owners Manual, there is an AWD Gauge in the Instrument Cluster. If you have the base cluster (with a single display), it should be under information. If you have the 2 screens, it is under Display Mode.
As per owners manual, Edges with push button start call for the BXT-65 battery while for the others BXT-59. So they both probably fit fine.
ABS (with its vibration & sound) will kick in considerably more on snow & low traction situations compared to dry roads. If you want to test it, brake hard on a wet patch or some sand/gravel/mud.
2011 Sport EDGE SIDE MIRRORS
omar302 replied to NexusFFO's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Seems my memory isn't that good. Here is a thread were someone tried the opposite & while the mirrors bolted up fine, he had an issue with BLIS. http://www.fordedgeforum.com/topic/14312-2013-mkx-mirror-size-vs-2011/ -
I don't remember reading any post about someone doing the swap before, but since the mirrors were changed mid year in 2011 (Job 2 maybe), it is highly likely that the mirrors will be swappable directly except for the wiring for the LED signals. I checked my 2011 MKX (May'11 build with the old mirrors) & there are 2 empty slots in the harness. Also note that the new mirrors are considerably smaller, this means less wind noise AND less visibility. -
Try to remove the fuse & see what happens.
If you have "Sony" written below the center speaker, then you have the Sony system. Also some speakers are actually 2 or more speakers together. I couldn't find an image for the Edge's Sony System, but the attached image for the MKX should be similar except for the slot speaker (3 speakers) where it is probably a single speaker in the Edge. Image taken from here: http://www.thx.com/consumer/automotive/2011-lincoln-mkx/
- 4 replies
- Stereo
- aftermarket
(and 7 more)
It would depend, the older type module would be connected at the rear quarter panel while the newer module is installed in front under the steering wheel. Check this post by @candurin for details he provided: http://www.fordedgeforum.com/topic/17035-adding-oem-remote-start-kits-parts-explained-detailed-2011/
Installing Backup Camera in 2013 Edge SEL?
omar302 replied to sagedrummer's topic in Accessories & Modifications
With. You will still use the same screen. Check the installation video to get a better idea of what it is.- 4 replies
- backup camera
- rearview
(and 7 more)
Just a thought, if you don't figure it out, you can still use the Lock-Pic which can add the rear view camera input among many other things. Or even the new MyTouch Air. https://www.coastaletech.com/mytouch2.htm https://www.coastaletech.com/mytouchair.htm- 4 replies
- backup camera
- rearview
(and 7 more)
All-new 2015 Edge using the old MFT hardware/software?
omar302 replied to fastman's topic in Audio, Backup, Navigation & SYNC
I only read in 1 review that it might be upgradeable, but, Ford was clear when Sync3 was announced that older vehicles will not be upgraded due to hardware differences. So unless you get a clear confirmation otherwise, you should expect to remain on the same Sync version that comes with your vehicle. The review was from Car & Driver (http://www.caranddriver.com/ford/edge): -
There are 2 systems included in the front seat belts: pretensioners & energy management retractors. Pretensioners remove the slack in the seatbelts when an accident is detected. These are part of the buckle as thirdgenlxi stated above. Energy management retractors release (or adds some slack) to the seatbelts when a certain load is reached, when a person's chest is pressed hard on a shoulder belt that might cause injury the seatbelts would release a bit to reduce the load. Usually this is part of the retractor assembly.
Random thought
omar302 replied to PrinzII's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Another new option are the Philips Xenon X-tremeVision, which claim up to 50% more light (compared to standard HID), though I've never seen them on a vehicle so I can't say my opinion. http://www.lighting.philips.com/gb_en/application_areas/automotive/xenon-xtremevision.wpd But they are expensive, ~100 USD each bulb! http://hidconcept.com/index.php?l=product_detail&p=223 -
You can try the Philips Xenon X-tremeVision, which claim up to 50% more light (compared to standard HID), though I've never seen them on a vehicle so I can't say my opinion. http://www.lighting.philips.com/gb_en/application_areas/automotive/xenon-xtremevision.wpd But they are expensive, ~100 USD each bulb! http://hidconcept.com/index.php?l=product_detail&p=223
My guess the missing part is the rain sensor cover. Some vehicles faced a problem where the cover falls off in high heat. http://www.fordedgeforum.com/topic/10763-2011-edge-sport-rain-sensor-cover-falling-off/ https://www.parts.com/index.cfm?fuseaction=store.PartInfo&PartNumber=BT4Z17D550A&VehicleID=313538&diagram=MS11335&Title%3DFORD-COVER
WE WANT APPS ON MY FORD TOUCH!
omar302 replied to CinnamonEdge's topic in Audio, Backup, Navigation & SYNC
+Customizable home screen, was there and gone. Ability to set a wallpaper only display, was & gone. Also, don't forget how many years it took Ford to reach version 3.6 with the stability that should have been there from the beginning. Early customers suffered a lot while waiting to reach this point, so Ford should compensate by at least giving more than just stability & at least for several years in the future as much as they made their customers wait for v3.6. And, don't forget all the hassles many went through during each update. All those downloads & dealer visits just to FIX MyFord Touch. YES, I would expect Ford to step UP & give us more features, not just basic fixes. Perhaps a petition should be started.
