Everything posted by omar302
Cooling fans running all time with AC
omar302 replied to Obeidat87's topic in Interior, A.C., Heat, Interior Trim
Where are you located? In the Middle East, the Edge will have its fans run on full speed if the A/C is on and the outside temperature is higher than a certain limit. I think it was 32 or 34 C. Or thereabouts. -
30-45 minutes. You can do update while driving, you just won't have access to the infotainment screen.
Airbag removal (adaptive steering model)
omar302 replied to papinist's topic in Interior, A.C., Heat, Interior Trim
Sorry, can't help with the slits. Couldn't find where I had read it before. For the steering wheel recall, it was actually a satisfaction recall, only those built between June 25, 2014 and September 14, 2016. Also, the program seems to have had an expiry date on 29/02/2020. https://ford.oemdtc.com/4337/satisfaction-program-19b04-steering-wheel-replacement-2015-2016-ford-edge-2016-lincoln-mkx -
Sorry, I don't. All I have is for the 2015. Courtesy of https://www.mactgarage.com/. For the recall, there were two. Airbag & steering wheel. If the did the steering wheel recall after the airbag, which they should have, then the new steering wheel wouldn't have the slits because they are only required for removal. -
If it was a 2018 or 2019 Edge built on or before 1-Aug-2019, then it has has the old sealing method & TSB 19-2837 addresses that with a new oil pan equipped with a press in place gasket. Howerver, if it was a 2020 (or 2019 built after 01-Aug-1019), well.... (more insult?) Link: https://static.nhtsa.gov/odi/tsbs/2019/MC-10169894-0001.pdf
You need to also remove the top steering column cover to expose the other torx screw. See the attache procedures. You don't need to remove the Airbag. For information, the 2016-2018 Edge Sport has an adaptive steering, so removing the Airbag is slightly different. The holes for removing the Airbag (same location) are covered. You would need to make slits to the steering wheel trim at the same location where they would be. You would know if it was removed or not earlier. I know this because my 2016 Sport first had the driver Airbag recall (replacement), so the dealer had to make the slits. Then I had the Adaptive Steering wheel recall (also replaced). So now the slits are gone. Good as new. Steering Column Shrouds.pdf Steering Column Multifunction Switch RH.pdf Steering Column Multifunction Switch LH.pdf Edit: This Fusion Video I think is clearer: -
Congratulations & welcome to the Forums.
You have a 2013, the MKX speedo upgrade refereed to in @TXFRDOwner & @onyxbfly posts wouldn't work (changing the Edge's speedo to the newer Lincoln style). I think there is a misunderstanding here. I believe your question is whether the right screen on your stock speedometer will still work after upgrading to Sync 3. In this case, yes, the screen will work with Sync 3.
2016 3.5 towing. Pls confirm for me...
omar302 replied to kone's topic in Cargo, Hauling, Roof Racks & Towing
Without the factory tow package, the 3.5 Edge is rated to 2000 lbs. The rating will not change even if you put a class II hitch. Sway control is one part, but the tow package usually also has additional cooling capacity like an engine oil cooler. -
As stated above, two other ways to know, if it is equipped with rain sensing wipers the wiper stalk will have "Auto" written on it and there will be this plastic cover behind/above the interior rear view mirror.
If you want cool, these lights are very cool replacements. https://drivebright.com/shop/ford-edge-led-drl-kit-with-built-in-led-turn-signal-with-black-accent-color/
2016 Ford Edge Strut Mount - how to?
omar302 replied to shumax's topic in Brakes, Chassis & Suspension
Attached. Credits to https://www.mactgarage.com/ Cowl Panel Grille.pdf Cowl Panel R and I.pdf -
Attached is from service manual procedure. Front Strut and Spring Assembly RI.pdf -
Heated and Cooled Seats
omar302 replied to Wedgeamatic's topic in Interior, A.C., Heat, Interior Trim
I had earlier went through As Built Data for a 2019 MKX and a 2018 F-150, both with ventilated seats, and the ABD blocks structure look similar to the 2019 Edge I poster earlier (with the additional blocks), so I was thinking it might be ventilated only after all, until your post proving they are still cooled. Can anyone who upgraded from a 2016-2018 Edge with cooled seats to a 2019-2020 Edge with cooled seats confirm their experience? -
Looks sharp. Do you have the factory front camera? If so, how did you keep it with the Honey comb grille? when looking for the grille there doesn't seem to be an offering with the camera hole for it. -
On the F-150 they changed the design starting with the 2018 model. F-150Forum has a thread on the cooled seat fix issue & the new mechanism is pictured in this post. The 2019 Nautilus Parts listing does show the new blowers. So maybe they only changed them on the Nautilus and not on the 2019 Edge, related to the new for 2019 availability of 22 way adjustable seats and hence the redesign of the seats and new blowers, while the Edge still kept the same seats (minor cover changes). -
This post includes a how to for doing the opposite. It might give you some idea how to do what you need.
I know they did change them starting with the 2018 F-150, but the parts listing for a 2020 Edge ST still shows the same TED part numbers as earlier models. https://www.tascaparts.com/auto-parts/2020/ford/edge/st-trim/2-7l-v6-gas-engine/body-cat/front-seat-components-scat -
Can you share them? -
I had the same idea on my previous 2011 MKX. Had a topic about it here with some wiring diagrams & component locations with help from members. Short answer, I did not do it. There is a wiring difference and you'll need to route the wires for it to work.
@tmarsh Any update on the cooled seats? I have done some research and found that even though the 2019/2020 Edge use the same TEDs (link to bottom & back parts) and same SCME (link to part), the 2019/2020 have extra blocks in the ABD. So there seems to be a software/firmware update for the SCME, I have an old ForScan 2.4.0 version (Jan build) but there is no firmware flash option for the SCME. Maybe someone with a 2019/2020 Edge with cooled seats can get temperature readings for the TEDs and see if they are better. Note: The yellow boxes and red text are to highlight the 2018 changes compared to mine. -
I can't really give an answer. From my readings, there is no clear proof that a catch can will prevent it, nor that without it you'd actually get carbon buildup on EcoBoost engines. But regular maintenance and using good oils will definitely help, especially considering that new oils are getting better to tackle the issue. Here are some interesting related articles I found searching online if you are interested: Valvoline explaining there oils: https://team.valvoline.com/diy/truth-behind-carbon-buildup Oil standards, GF-5 being common & GF-6 about to be available: https://www.oilspecifications.org/ilsac.php. (There is an interim oil, labeled API SN Plus that kind off is between GF-5 & GF-6, Ford has already started specifying it for their vehicles starting 2018 I think). Others: https://www.enginelabs.com/news/video-is-running-your-engine-up-to-redline-actually-good-for-it/ https://www.mustangecoboost.net/threads/direct-injection-catch-cans-oil-changes.17251/
As @onyxbfly stated above, the Edge still uses Direct Injection only. The F-150 got dual injection in 2017 for the 3.5 EcoBoost only, then in 2018 the rest also got it. But all other EcoBoost Engines (AFAIK, and as per Ford's website as of today 07/07/2020) are still Direct Injection only, even the new Explorer, which was a clean new 2020 model & the first application of the 3.0 EcoBoost in longitudinal form. Edit: The 2018+ Expedition is also PFI+DI like the F-150, although Ford's website states its only DI. So there goes relying on Ford as a credible source ?.
It doesn't seem you need to remove the glove box. See the attached procedure. Blower Motor R and I.pdf
