omar302
    199
Everything posted by omar302
  1. Generally, Gen 1 & 1.5 (2007-2010 & 2011-2014) Edge's HVAC system, in my opinion, have a weak blower design. A lot of other cars have a noticeably stronger blowers which you can feel, even the 2015+ model is much better. With that said, did you replace the cabin air filter recently? If not, it will help considerably. Also, consider going OEM (Motorcraft) as from my personal experience it will give better airflow than other aftermarket (at least from what I have tried).
  2. Check the parts diagram in this link. Might help you pinpoint it.
  3. 2009 uses the old type regular drain plug. https://www.tascaparts.com/oem-parts/ford-drain-plug-9l8z6730a The gasket for the plug also comes seperately: https://www.tascaparts.com/oem-parts/ford-drain-plug-gasket-f75z6734aa
  4. I noticed that the ST's interior also has black pillars & roof. The Sport had a light color off-white or tan (not sure what it is called), which in my opinion is better than all black.
  5. The electric motor is still there, if you close the hatch manually it will take last part & close the hatch.
  6. At ~10:33 it shows the tire pressure, and they are at 38-39 psi, don't know why that high, but they definitely don't help the ride. Also at around 10:40, there is a boost gauge!
  7. This might be the 1st video review:
  8. Welcome. Just the other day I saw this video on the effect of bigger tires:
  9. Your being a 2015, the TSB is applicable, they will change the TED (the cooling/heating element & blower) from the seat back & replace it with an updated one that has a "Sock" to get the intake air from under the seat (unless it was already done for the previous owner). It will improve compared to the old one, but for a better solution there is Tim's fix.
  10. MyFord Touch updates have been the same for Lincoln & Ford. Same update files & versions. The difference was only the ABD that set which theme to use, Lincoln or Ford.
  11. Did the passenger seat yesterday & got some more photos, might be useful. 1 & 2: Show under the seat before removing the 2 connectors. 3: Shows were the strap is after removing the connector. 4: The side airbag connector removed & disconnected. 5 & 6: The J-Clips disconnected & flap partially raised and shows how the connectors are going through the 2 holes. 8 & 9: The seat back TED & intake sock. 10: Close up of the seat back TED, these are the screws that to be removed (T6 torx). 11: The route the hose will be going through. 12 & 13: The exhaust hose pinched at the end with a part cut so when the seat flap goes over it it wouldn't block it. 14 & 15: The exhaust piece & hose installed & routed. 16: A photo of the front how the seat cover is raised. The difference I saw between the driver & passenger seats is that due to the side airbag being on the right, the hose is routing is not as smooth as it was on the driver side (due driver side having the airbag on the other side)..
  12. Attached are the cooling system component locations for the 2.0, 3.5 & 2.7 engines from the 2015 Service Manual. Each one shows the different configuration (Basic, Tow Package and/or Hot market). Engine Cooling - Component Location 20l.pdf Engine Cooling - Component Location 27l.pdf Engine Cooling - Component Location 35L.pdf
  13. I remember I followed mid for the dark car mode (police option) in the 2GFusion sheet. https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true
  14. I'm not sure the 2018 is the same, but for the 2015, fans are the same, but from the service manual it seems for the 3.5L there is an engine oil cooler added while for the 2.0L a transmission oil cooler is added with the tow packages.
  15. omar302
    Cooling fan issue
    Did you change the whole fans & module or only the module? If only the module, maybe the issue is from the fans?
  16. omar302
    Cooling fan issue
    Did you install a MotorCraft fan assembly?
  17. Found a video of the 2019 Mustang's horn:
  18. Just to add, the 2018 Edge & 2019 Mustang now come with a single tone horn! And the replacement parts are relatively cheap. https://ford.oemdtc.com/3839/single-tone-horn-service-replacement-parts-available-2018-ford-edge-2019-mustang
  19. They look nice, but what do they mean by "Flame-Out before installing"?!?
