Everything posted by omar302
As far as I know, the 22" wheel do not have the cladding. If you want to check, tap on them slightly with a metal object, you'll know if the surface is aluminum or metal.
Wouldn't the screws leave marks in the original plastic paddles in case you decided to remove the extensions?
Also the Explorer got it from 2011.
I noticed that there has been no mention of Adaptive Steering. Even in the reviews & pictures, the steering wheel looks to be the standard wheel (with a pass through in the bottom spoke). Seems like they are not offering it anymore on the Edge. Active Noise Control has been in the Edge Sport since 2015. If you drove the 2017 Sport, then you have already experienced it.
Same here with my 2016 Sport. I was thinking it was from the pedal sticking to my shoe, but reading your comment, it does happen at cold starts at low speeds.
The adjustable height liftagate feature was only added in the 2015+ Edge. Prior models had a fixed height liftgate,
I think Ford's decision to use the ST badge was not correct. Reviews on the Fiesta ST & Focus ST always had high complements on their handling & "fun to drive" factors despite their reasonable pricing compared to more expensive offerings. Guess every was hoping Ford would do the same thing with the ST badged Edge, make it as sporty & fund to drive as more expensive crossovers. The thing is that other manufacturers started using "Sport" names for lesser trim levels, so maybe Ford was pressured into using the ST badge to justify its premium price over the titanium. And not offering the 2.7TT on the Titanium is due to the Nautilus! Ford should figure it out soon before losing more!
2012 Ford Focus Blower Motor Speeds
omar302 replied to 12Edge's topic in Forum Help & Site Suggestions
Generally, Gen 1 & 1.5 (2007-2010 & 2011-2014) Edge's HVAC system, in my opinion, have a weak blower design. A lot of other cars have a noticeably stronger blowers which you can feel, even the 2015+ model is much better. With that said, did you replace the cabin air filter recently? If not, it will help considerably. Also, consider going OEM (Motorcraft) as from my personal experience it will give better airflow than other aftermarket (at least from what I have tried). -
Check the parts diagram in this link. Might help you pinpoint it.
2009 uses the old type regular drain plug. https://www.tascaparts.com/oem-parts/ford-drain-plug-9l8z6730a The gasket for the plug also comes seperately: https://www.tascaparts.com/oem-parts/ford-drain-plug-gasket-f75z6734aa
Yes. Plastic. Link to part.
I noticed that the ST's interior also has black pillars & roof. The Sport had a light color off-white or tan (not sure what it is called), which in my opinion is better than all black.
Power liftgate drops when it is about to close, is it normal?
omar302 replied to redden18's topic in Exterior & Body
The electric motor is still there, if you close the hatch manually it will take last part & close the hatch. -
At ~10:33 it shows the tire pressure, and they are at 38-39 psi, don't know why that high, but they definitely don't help the ride. Also at around 10:40, there is a boost gauge!
This my liftgate: -
This might be the 1st video review:
Welcome. Just the other day I saw this video on the effect of bigger tires:
Your being a 2015, the TSB is applicable, they will change the TED (the cooling/heating element & blower) from the seat back & replace it with an updated one that has a "Sock" to get the intake air from under the seat (unless it was already done for the previous owner). It will improve compared to the old one, but for a better solution there is Tim's fix.
Add me to the list. Also thought it was normal. -
Heated and Cooled Seats
omar302 replied to Wedgeamatic's topic in Interior, A.C., Heat, Interior Trim
Did the passenger seat yesterday & got some more photos, might be useful. 1 & 2: Show under the seat before removing the 2 connectors. 3: Shows were the strap is after removing the connector. 4: The side airbag connector removed & disconnected. 5 & 6: The J-Clips disconnected & flap partially raised and shows how the connectors are going through the 2 holes. 8 & 9: The seat back TED & intake sock. 10: Close up of the seat back TED, these are the screws that to be removed (T6 torx). 11: The route the hose will be going through. 12 & 13: The exhaust hose pinched at the end with a part cut so when the seat flap goes over it it wouldn't block it. 14 & 15: The exhaust piece & hose installed & routed. 16: A photo of the front how the seat cover is raised. The difference I saw between the driver & passenger seats is that due to the side airbag being on the right, the hose is routing is not as smooth as it was on the driver side (due driver side having the airbag on the other side)..
